1st try, no click, 2nd try stalls, 3rd try starts
Discussion in '4 Cylinder' started by Crooked Beat, Jun 2, 2013.
  1. Jun 2, 2013 at 8:02 AM
    Crooked Beat
    Crooked Beat [OP] Well-Known Member
    GTA
    2021 Tacoma DCLB SR
    Once in a while my truck won't start.
    No click, no nothing.
    I then retry start and it starts but sometimes stall out.
    On the third try it starts.
    This happens once in about 10 starts.
    I have replaced starter and battery.
    Leaking fuel system? Losing pressure?
    No click means bad electrical? switch?
  2. Jun 2, 2013 at 9:28 AM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    Looks like you have a 2wd. If you have a 4x4, I would say try it with the "Clutch Start Cancel" switch to rule out the clutch safety switch. Sounds to me like it's either that or the ignition switch in the column. That's where I'd start...
  3. Jun 2, 2013 at 9:30 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Sounds like 3rd times the charm.
  4. Jun 2, 2013 at 9:31 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    I'm leaning towards a loose connection somewhere.
  5. Jun 2, 2013 at 9:56 AM
    Crooked Beat
    GTA
    2021 Tacoma DCLB SR
    I have the 2wd 5 speed manual.
    So there is no clutch cancel button/switch? But there still could be a clutch cancel safety feature?
    I am leaning towards the ignition switch?
  6. Jun 3, 2013 at 9:15 AM
    WHPLSH3
    Vance
    Alberta
    The only 2wd to have a "Clutch Start Cancel" switch is a Prerunner Off Road, I think. All the manual transmission ones have a clutch safety switch, though. It's the one that won't let you start it unless the pedal is all the way to the floor. 3/4 of the way down, and nothing... But it definitely is an electrical problem
  7. Jun 3, 2013 at 9:52 AM
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    Can you flood the engine with a fuel injected engine? My old Datsun used to be finicky, but we're talking 1970s techno...
  8. Jun 3, 2013 at 11:11 AM
    WHPLSH3
    Vance
    Alberta
    Absolutely. When you turn the key to start on a cold engine, the fuel injectors "batch fire"- they all fire at once until the ECU reads that the RPM is >400, then they fire sequentially depending on which cylinder is next firing-order wise. In cold climates, trying to start an engine that has sat all day/overnight and letting the key go before it actually catches will flood it nearly every time.
    To clear a flooded engine on a fuel injected vehicle, only hold the throttle open halfway, not to the floor like a carburator.
  9. Jun 3, 2013 at 11:20 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    ^ that's not how it works in a tacoma but you can think it works this way in fantasy land
    his symptoms are between:
    key-battery-starter-crankshaft position sensor-engine immobilizer
    if it were fuel-related the engine would always turn over...he states sometimes -nothing- happens on key turn
  10. Jun 3, 2013 at 12:30 PM
    WHPLSH3
    Vance
    Alberta
    His isn't fuel related. Someone else asked the fuel question. I think you're probably right about the engine immobilizer, though.
    Perhaps you could correct me about what goes on with the fuel injectors in these trucks? The info I gave may be out of date, so if you know better I'm all eyes. The tech stuff always interests me...
  11. Jun 3, 2013 at 1:04 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    IIRC...it is always sequential,
    no batch fire system used by toyota
  12. Jun 3, 2013 at 2:20 PM
    Crooked Beat
    GTA
    2021 Tacoma DCLB SR
    Going to check on the clutch safety switch. Thank you!
  13. Jun 3, 2013 at 2:21 PM
    Crooked Beat
    GTA
    2021 Tacoma DCLB SR
    That makes sense.
    Battery and starter taken care of.
  14. Jun 3, 2013 at 2:23 PM
    Crooked Beat
    GTA
    2021 Tacoma DCLB SR
    Engine immobilizer? I will try starting with the spare key. Never thought about that.
    Thank you!!!!!
  15. Jun 21, 2013 at 1:15 PM
    Crooked Beat
    GTA
    2021 Tacoma DCLB SR
    Switched keys and no problems for almost 3 weeks. Perhaps it was the Engine immobilizer.
  16. Jun 21, 2013 at 1:49 PM
    WHPLSH3
    Vance
    Alberta
    Glad it was a simple fix!:cool:
  17. Jun 22, 2013 at 7:02 AM
    Crooked Beat
    GTA
    2021 Tacoma DCLB SR
    Simple after about $300 on starter and battery!! :)
