1stacoma build page
Discussion in '2nd Gen. Builds (2005-2015)' started by 1stacoma, Jul 24, 2012.
  1. Aug 16, 2013 at 6:47 PM
    #41
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    2013 DCLB SR5 4X4 Nautical Blue
    Check out my Build
    What did the 2" AAL give you for lift in the rear? Did you have the 4 leaf pack on you're 12'?
  2. Aug 16, 2013 at 6:52 PM
    #42
    1stacoma
    1stacoma [OP] Well-Known Member
    Austin
    2012 MGM SR5 DCSB 4.0
    5100's front and rear, front 2.5" rear 2" AAL, 18% tint front and rear, color matched grill. SCS wheels 275/70/17 BFG AT KO's. DTRL toggle switch.
    I did notice that I had a slight increase with the wheels and tires also BFG's have a decent amount of tread that probably give a little height. And a 275/70 is a fairly larger tire than what you have maybe an inch taller is my guess. I did not want to cut so that is why I went 275 instead of 285.
  3. Aug 16, 2013 at 6:55 PM
    #43
    1stacoma
    Austin
    I had the 3 leaf pack and I got a sold 2". I would say that is completely level.
  4. Aug 16, 2013 at 6:55 PM
    #44
    josepenajr
    josepenajr Well-Known Member
    Laredo , Texas
    13 Texas Edition Double Cab
    3 inch lift, Painted black rims, black bull bar, black bug deflector, Black PlasTi Dipped Emblems, 275/70/17 Tires
    oh okay thanks so tje 275/70 are a lil taller then
  5. Aug 16, 2013 at 7:05 PM
    #45
    1stacoma
    Austin
    Non scientific measurement I held the tape measure across the top of my tire with the yard stick and it looks to be a little under 31.5" and that is with 15k on the tires.
  6. Aug 16, 2013 at 8:13 PM
    #46
    teneighty
    Check out my Build
    Cool, thanks
  7. Sep 30, 2013 at 6:11 PM
    #47
    FSUtaco
    FSUtaco Well-Known Member
    Cody
    Tallahassee, FL or Texas
    13 Reg Cab 4x4
    Eibachs, 5100s, 7089s and 265s
    Do you still have a rake with the 2" aal and billies @ 2.5"?
    Also how is the ride with the billies set @ 2.5"?
  8. Sep 30, 2013 at 7:00 PM
    #48
    1stacoma
    Austin
    No sits level, the ride is stiff but livable. I will be getting OME 885 pretty soon.
  9. Oct 25, 2013 at 11:13 PM
    #49
    chkthis1
    chkthis1 Well-Known Member
    Bucks Co, PA
    "06" TRD Off Road
    TRD Gray Beadlock Rims, 265/70R16 BFG's Rugged Terrain, Wheelers lift Kit - Bilstein 5100's @ .85, Eibach 620lb Springs, 2.0''AAL 3 multi-leaf HD, w/3degree rear axle shim, LF 1/4"spacer, CB drop kit.
    How does it Ride & Handle?
    I am doing the same lift on a 2006 trd. but with 275/70R16 BGF Rugged Terrian.
  10. Oct 26, 2013 at 9:42 AM
    #50
    1stacoma
    Austin
    It's stiff but not to bad I have been on it like this for over a year. I will probably bet ome springs soon.
  11. Nov 18, 2013 at 5:26 PM
    #51
    nikkopz
    nikkopz Member
    Nick
    NC
    DCSB TRD OR 4x4
    Are you running stock coils with billies at 2.5?
  12. Dec 4, 2013 at 9:29 PM
    #52
    Ice Road Trucker
    Ice Road Trucker Member
    Hans
    Anchorage,Ak
    TRD
    I have toy tac 2013 lifted 3" with 275 70r 17 stock wheels.
    I would like to get aftermarket wheels doesn't stick out edge fender. What's should be the offset of the wheels?! Neg or positive?!
    Hans
  13. Apr 11, 2015 at 8:25 PM
    #53
    clh850
    clh850 Well-Known Member
    Cody
    PCB, Florida
    '14 TRD Sport
    Nice truck!
  14. Jul 31, 2015 at 9:38 AM
    #54
    1stacoma
    Austin
    Its a sad day I traded in the Taco. It was a fun ride while it lasted.
  15. Jul 31, 2015 at 1:06 PM
    #55
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    Say it aint so!!:annoyed:
    What did you get?
