2” Rough Country Level/Spacer Kit
Discussion in 'Suspension' started by Preamz, Aug 7, 2025 at 6:32 PM.
  1. Aug 7, 2025 at 6:32 PM
    Preamz
    Preamz [OP] Member
    Yesterday
    Tyler
    2022 Silver Tacoma SR5
    Putting the 2” Rough Country Leveling Kit on my 2022 Tacoma here soon, wanting to know what’s the biggest size tires I could run with stock rims? Currently have 265/70R16 on it wanting to see about getting 285/75R16. Anybody else done similar or have better recommendations to achieve a bigger size?
  2. Aug 7, 2025 at 7:14 PM
    BigCarbonFootprint
    BigCarbonFootprint Well-Known Member
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    I am concerned you haven’t done your due diligence with respect to planning ahead.
    General consensus around here is the RC two inch leveling kits are junk.
    I would recommend you send those RC spacers back to where ever you ordered them from.
    Ask for a store credit.
    And come up with a more better plan.
    My two cents
    Jakerou likes this.
  3. Aug 7, 2025 at 7:25 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Put some skinnies on it - 255/85/16
    285s would probably rub the upper control arms
  4. Aug 7, 2025 at 7:30 PM
    Preamz
    Preamz [OP] Member
    Yesterday
    Tyler
    I have done my research, the spacers are just fine for daily drive with no off roading. Would the bilstein 5100 or even the ready lift be a better option yes I don’t disagree with that. Have seen just as many people say they’re fine and have no issues as people saying the same thing you said. But thanks for your two cents buddy
  5. Aug 7, 2025 at 7:32 PM
    BigCarbonFootprint
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    Smart reply! Best wishes!
    AE
  6. Aug 7, 2025 at 7:39 PM
    Preamz
    Preamz [OP] Member
    Yesterday
    Tyler
    skinnies are no fun, I want to go as wide and tall as possible without adding spacers or any more than just the spacer leveling kit
  7. Aug 7, 2025 at 8:04 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    What else is new haha. Your question has been asked a million times on this forum
    It's not that simple. You need to read and research more if you want any kind of ride quality. Those spacers really are going to ride like ass. Stock wheels won't have enough offset to get the wider tires away from the UCA.
    I suggested skinnies because theyll have the best chance of fitting without cutting or too much rubbing
    You're in the right section.. read more of the threads on this topic.
    Everybody new says the same thing as you.. "I've done a bunch of research already" .. but then they're still in here asking the same old question.. "what's the biggest tire I can fit with this or that lift?"
    All these trucks are different. Some people rub with 285s, some people don't. Some people wheel and need suspension travel and clearance.. some people don't.
  8. Aug 7, 2025 at 8:27 PM
    Preamz
    Preamz [OP] Member
    Yesterday
    Tyler
    Just curious have you ever had the rough country spacer kit on your truck?
  9. Aug 7, 2025 at 11:02 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    I'll say this:
    2" lift is 2" lift.
    As far as tire fitment goes, it does not matter whether it comes from cheap spacer lift pucks, or high-end Fox or King 2.5 race shocks. The tire will still fit (rub) the same (so don't be thinking they will fit any differently than they would on anyone else's 2"-lifted truck).
    285s on stock wheels will rub the UCA. If you want to your keep stock wheels and run 285s, then you'll need ¾ inch or 1 inch wheel spacers.
    You may also need to max out your caster angle to get the tire away from rubbing the back of the fenders.
    Lots of info on this subject... Hopefully that gives you something more to go on.
    TVH475 likes this.
  10. Aug 8, 2025 at 1:09 AM
    Preamz
    Preamz [OP] Member
    Yesterday
    Tyler
    So would a 265/75R16 fit?
