2 0 1 6 THE [ R E C H E L O N | AESTHETICS ] TACOMA RETROFIT HL GROUP BUY
Discussion in 'RECHELON AESTHETICS' started by RECHELON, Mar 10, 2016.
  1. Mar 10, 2016 at 11:02 PM
    RECHELON
    RECHELON [OP] RETROFIT HEADLIGHTS
    RECHELON AESTHETICS
    SoCal to Portland
    DCX2
    THE RECHELON RETROFIT GROUP BUY
    Our Passion is to Handcraft Custom Detailed Headlights
    Driven to Balance Aesthetics w/Performance
    [ STARTS MARCH 11TH TILL APRIL 5TH ]
    HOW TO ORDER
    EMAIL US AT RECHELON.AESTHETICS@GMAIL.COM
    INCLUDE YOUR TW USER NAME & FULL NAME
    INCLUDE THE STAGE # & ADDITIONAL OPTIONS
    We only use Parts from
    Toyota / The Retrofit Source / Diode Dynamics / Led Concepts
    Follow us on Instagram at
    [ RECHELON.AESTHETICS ]
    [ 2005-2011 STAGE I $925 SHIPPED ]
    - Brand New OEM Genuine Toyota Headlights * Updated Clear Glass Version by Toyota *
    - Brand New H1 7.0 Mini Projectors
    - Shroud Design of your Choice / Check The Retrofit Source's website@ (http://www.theretrofitsource.com/components/shrouds.html )
    - OEM TRD PRO BLACK SMOKE / CHROME FACTORY COLOR SCHEME
    or
    - Blacked Out Paint Work ( BEZEL / BOWL / SHROUD / DTRL BLINKERS )
    - You can request to leave certain parts of the headlight chrome
    - Smoke Amber Reflector ( Can Leave Stock Amber )
    - Brand New 35W Morimoto ballasts
    - Brand New XB35 Morimoto Bulbs (We Recommend 4500k or 5500k)
    - Brand New Morimoto H4 Wiring Harness
    [ 2012-2015 STAGE I $925 SHIPPED ]
    - Shroud Design of your Choice / Check The Retrofit Source's website @ (http://www.theretrofitsource.com/components/shrouds.html )
    or
    [ 2005-2011 STAGE II $995 SHIPPED ]
    - Brand New FX-R 3" Projectors
    or
    [ 2012-2015 STAGE II $995 SHIPPED ]
    or
    [ 2005-2011 STAGE III $1290 SHIPPED ]
    - OEM NiSSAN MURANO / OEM ACURA TL PREMIUM PROJECTORS ( FINELY TUNED )
    or
    [ 2012-2015 STAGE III $1290 SHIPPED ]
    or
    [ ADDITIONAL OPTIONS FOR ALL STAGES ]
    - Passive Demon Eye / Subtle color accent inside the projector lens / Does not light up ( Color of your choice ) +$50
    - LED Demon Eye / Lights up inside the projector lens. (Color of your choice - Red, Blue, Green, Amber, or Purple) +$80
    - Halos (White or Amber / Front or Rear mounted) +$100 For One Set / +$180 For Both Front & Rear
    - RGB Color Changing Halos +$150
    - RGB Color Changing LED Demon Eye +$150 ( Recommend to Wire them to a Switch/Button )
    +$270 For Both RGB HALO & RGB LED DEMON EYE
    - Clear / Light Clear Smoke / Dark Clear Smoke Replacement Reflectors
    Replaces Stock Amber +$45
    - Black Chrome or Chrome Parking Light Corner +$30
    - Custom Color Matched Paint work / Our Professional Painter uses the best paint & clear product by GLASURIT. ( Pricing Varies )
    - Custom Art/Design Etching in Projector Lens +$45
    - OEM Upgraded Bulbs are Available to compliment your Choice of Projector (Pricing Varies)
    - 50W Ballasts instead of 35W +$10
    - HAWAII Shipping +$45
    * * ALL LIGHTS ARE AIMED & MOUNTED ON A STOCK TOYOTA TACOMA TO ENSURE ACCURACY * *
    * @DefconBrix SEMA 2015 | R E C H E L O N BLACK CAMO RETROFIT *
    IMG_2791_zpss8kkutnr.jpg IMG_2805_zpstmsjjbbc.jpg IMG_2810_zpsoojlopfb.jpg IMG_2820_zps7wfcvlhm.jpg IMG_2825_zpsmxi7x3xr.jpg
    sect0r - brand new OEM headlights, G37R shroud with white halo in rear, flat black paint, smoked reflector
    temper - Brand new OEM headlights, G37R shroud w/ RGB halo, flat black paint, smoked reflector
    Idaholandho - brand new OEM headlights, anodized blue demon eye, bullet shroud, flat black paint, smoked reflector
    w/ flash on
    Dave P - Brand new OEM headlights, Panamera shroud with front and rear mounted amber halo, flat black paint, smoked reflector
    almoss - brand new OEM headlights, DTRL and Apollo 3.0 shroud left chrome, smoked reflector
    iHacker - Brand new OEM TRD Pro headlights (black chrome finish), Apollo shroud, everything left alone for an OEM look
    Flat black bezel, Shroud, Bowl, DTRL, and corner bowls all left chrome, amber halo, Apollo shroud
    TACOMAA6 - Brand new OEM headlights, Apollo 3.0 with white front mounted halo, red passive demon eye, smoked reflector, flat black paint
    Toyota Technical - Brand new OEM headlights, Panamera shroud with front and rear mounted amber halo, flat black paint, smoked reflector
    RECHELON.AESTHETICS
    Questions/Inquries or Concerns
    rechelon.aesthetics@gmail.com
    rad.rechelon@gmail.com
  2. Mar 10, 2016 at 11:20 PM
    RECHELON
    RECHELON AESTHETICS
    SoCal to Portland
    DCX2
    FAQ
    Q. Is there a warranty?
    A. Yes. I offer a six month warranty on workmanship. TRS components follow the TRS warranty period. For example, 5Five Ballasts carry a 24 month warranty. 3Five ballasts carry a 60 month warranty. Etc... No hassle warranty. Shipping cost will be taken care of by TRS for U.S. transactions. For owners outside the U.S., you will be responsible for the shipping cost per TRS.
    The cost of shipping the headlight(s) to to me is the original owner's responsibility. I will be responsible for the cost of returning the warrantied headlight(s) to the original owner within the U.S. Sorry, if you are outside the U.S., you pay shipping both ways. This warranty is NOT transferrable. Any modifications and/or tampering of headlights will void the warranty.
    Q. How hard is it to install the headlights and wire harness once I receive them?
    A. If you have a slight bit of mechanical skills, then the installation will not be difficult. The wire harness is plug 'n play, no splicing of the OEM harness is required (unless your lights are equipped with LED Angel Eyes). The new, retrofitted headlight bolts up the same way your old one was removed. Wire harness instructions are included with your shipped headlights as well as online.
    http://www.theretrofitsource.com/pdf/trs_tech/Bi-Xenon MotoControl Relay Harness.pdf
    The OEM headlight aiming mechanism remains fully functional. After your retrofitted headlights are installed, some fine tuning will be required utilizing the OEM adjusters. Fine tuning is defined as matching both the left and right cut-off so that they are level with each other. As a rule of thumb, I recommend aligning the height of the cut-off to be horizontal with the upper trunk line of the average sedan.
    Q. Where can I learn more about retrofitting, projectors and HID bulbs?
    A. The Retrofit Source (TRS) has a tremendous amount of online material to enhance your retrofitting knowledge.
    http://www.theretrofitsource.com/trs_tech.php
    Q. What's the difference between the bulb colors?
    A. Kelvin Ratings: 3000K - Has a golden yellow output perfect for use in fog lights. The yellow light penetrates through snow, rain, and fog more effectively than white or blue light. 4300K - Has a slightly off-white output similar to that of sunlight. Most cars that come equipped with HID headlights from the factory use 4300K bulbs. If you want the most usable light, 4300K is the Kelvin rating for you. 5000K - A pure white output, no tinge of yellow, and no tinge of blue. 6000K+ As you move into the higher kelvin ratings, your light output will appear more bluish-purple in hue, but the bulbs won't be physically as bright. I do not offer 6000k bulbs. As HID bulbs age, they go through what is known as "color-shift". When the bulbs are brand new, the output is whitish-yellow and as physically bright as it will ever be. As the bulbs age with use, their output turns more pure white/bluish and also starts to dim a bit. That's why cars with factory 4300K bulbs that are 5+ years old look like they're running 5000K or higher bulbs.
  3. Mar 10, 2016 at 11:53 PM
    SoCal_Yotas
    SoCal_Yotas Well-Known Member
    Elias
    Santa Clarita
    2015 Toyota Tacoma TRD-Sport 4x4
    What is the price of we send our own OEM headlights?
  4. Mar 11, 2016 at 3:58 PM
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    I've been building crafted headlights since 2008 and I absolutely enjoy creating for and with my clients. I recently sat down and went over the logistics of creating a better system at RECHELON. I've now come up with a system that will ensure a quick turn around time without sacrificing quality. I've went over every step of the process to make sure the quality meets my expectations. I've been a long time member of TW and appreciate this community. In my time I've met many great Socal locals and they're able to see the quality of the craft in person. I've built over 250 Sets of lights ranging from simple BHLM to Elite Retrofitted Builds.
    I am confident that my long extensive skill set shows in the final product
    I look forward in Crafting & Creating along side with you.
    Kind regards,
    RAD
  5. Mar 11, 2016 at 4:02 PM
    Manwithoutaplan
    ID
    doing work!
  6. Mar 11, 2016 at 4:24 PM
    RAD
    Rad
    LAX & LOGAN
    @Manwithoutaplan Whats up Ryceps! Ty kindly for all the help over the years.
    Manwithoutaplan likes this.
  7. Mar 11, 2016 at 4:48 PM
    Manwithoutaplan
    ID
  8. Mar 24, 2016 at 11:23 AM
    Maximus
    Maximus Well-Known Member
    North Bay
    11 Tacoma TRD OR 4x4
    Icon Suspension with CDCV, SPC Light Racing UCAs, Wheeler's 3 Leaf AAL, Wheeler's Superbumps, sPod SE BAMF Sliders, All-Pro Skids, AFE Drop in filter, Magnaflow Exhaust, RCI Aluminum LCA Skids, BAMF Bed Brackets, 4X Innovations Rear Bumper, FX-R Retrofit Headlights with Philips 4300k, Custom Nestah Edition Firestik AM/FM Antenna, Famous Fab Hood brackets, FrontRunner SlimLine 2 Roof Rack, Mob Town Offroad tailgate reinforcement plate, Ram A pillar mount, Anti-Dark hood lights, Lots of LED lights,
    This excites me! Is there a minimum number of people needed for this group buy?
  9. Mar 24, 2016 at 6:15 PM
    JHsieh_3
    JHsieh_3 Well-Known Member
    Jeff
    City of Angels
    2018 Tacoma TRD Sport
    Sub'd. Hopefully I can save enough to get in on this group buy before April 5th! I spoke to you on your other thread RAD, regarding sending my own OEM HL. Even though the price is already lowered for this group buy, will it also decrease if I sent my own HL?
  10. Mar 24, 2016 at 11:29 PM
    RAD
    Rad
    LAX & LOGAN
    ^ @JHsieh_3 Yes, I will factor the cost to remove the new oem lights. =)
    @Maximus We're running the discounted price till April 5th and after that, prices go back to normal.
  11. Apr 1, 2016 at 10:45 AM
    RAD
    Rad
    LAX & LOGAN
    FRIDAY IS HERE & ALL EMAILS HAVE BEEN ANSWERED
    I'LL BE BUSY DURING THE WEEKEND IN PREPARATION TO HEADING BACK TO PORTLAND
    ALL EMAILS / COMMUNICATION MAY SLIGHTLY BE DELAYED
    WE'VE GOT SOME UNIQUE/CREATIVE BUILDS BEING REQUESTED ALONG WITH SOME NEW PRODUCTS TO DISPLAY
    :thumbsup:
    * * NEW VEHICLES AS WELL :D * *
    I AM EXTREMELY EXCITED
    * * OUR GROUP BUY PRICING WILL BE ENDING SOON ON APRIL 5TH * *
    ENJOY YOUR WEEKEND GUYS! THANKS FOR THE SUPPORT
    RAD
    thatlastone likes this.
  12. Apr 1, 2016 at 11:16 AM
    avh128avh128
    avh128avh128 Well-Known Member
    Los Angeles
    I can not wait for mine to arrive. thank you Rad.
  13. Apr 1, 2016 at 11:17 AM
    RECHELON
    RECHELON AESTHETICS
    SoCal to Portland
    DCX2
    ^ You're welcome ARMEN. . .
    We have quite a bit of SOCAL Guys getting work done
    1truckdriver likes this.
