2 0 1 6 THE [ R E C H E L O N | AESTHETICS ] TACOMA RETROFIT HL GROUP BUY
Discussion in 'Group Buys' started by RECHELON, Mar 11, 2016.
  1. Mar 11, 2016 at 9:46 AM
    RECHELON
    RECHELON [OP] RETROFIT HEADLIGHTS
    RECHELON AESTHETICS
    SoCal to Portland
    DCX2
    R E C H E L O N AESTHETIC
    THE RETROFIT GROUP BUY
    Our Passion is to Handcraft Custom Detailed Headlights
    Driven to Balance Aesthetics w/Performance
    [ STARTS MARCH 11TH TILL APRIL 5TH ]
    HOW TO ORDER
    EMAIL US AT RECHELON.AESTHETICS@GMAIL.COM
    INCLUDE YOUR TW USER NAME
    INCLUDE THE STAGE # & ADDITIONAL OPTIONS
    We only use Parts from
    Toyota / The Retrofit Source / Diode Dynamics / Led Concepts
    Have your own OEM Headlights?
    Contact us directly as we can work out the details
    * * DOES YOUR RETROFITTER PROPERLY LEVEL YOUR PROJECTORS? * *
    ALL LIGHTS ARE AIMED, LEVELED, & MOUNTED ON A STOCK TOYOTA TACOMA TO ENSURE ACCURACY. YOU'RE NOT BUYING A RETROFIT FOR JUST THE AESTHETICS. THE PERFORMANCE SHOULD BE THE MOST IMPORTANT OF THE BALANCE
    Follow us on Instagram at
    [ RECHELON.AESTHETICS ]
    [ 2005-2011 STAGE I $925 SHIPPED ]
    - Brand New OEM Genuine Toyota Headlights * Updated Clear Glass Version by Toyota *
    - Brand New H1 7.0 Mini Projectors
    - Shroud Design of your Choice / Check The Retrofit Source's website@ (http://www.theretrofitsource.com/components/shrouds.html )
    - OEM TRD PRO BLACK SMOKE / CHROME FACTORY COLOR SCHEME
    or
    - Blacked Out Paint Work ( BEZEL / BOWL / SHROUD / DTRL BLINKERS )
    - You can request to leave certain parts of the headlight chrome
    - Smoke Amber Reflector ( Can Leave Stock Amber )
    - Brand New 35W Morimoto ballasts
    - Brand New XB35 Morimoto Bulbs (We Recommend 4500k or 5500k)
    - Brand New Morimoto H4 Wiring Harness
    [ 2012-2015 STAGE I $925 SHIPPED ]
    - Shroud Design of your Choice / Check The Retrofit Source's website @ (http://www.theretrofitsource.com/components/shrouds.html )
    or
    [ 2005-2011 STAGE II $995 SHIPPED ]
    - Brand New FX-R 3" Projectors
    or
    [ 2012-2015 STAGE II $995 SHIPPED ]
    or
    [ 2005-2011 STAGE III $1290 SHIPPED ]
    - OEM NiSSAN MURANO / OEM ACURA TL PREMIUM PROJECTORS ( FINELY TUNED )
    or
    [ 2012-2015 STAGE III $1290 SHIPPED ]
    or
    [ ADDITIONAL OPTIONS FOR ALL STAGES ]
    - Passive Demon Eye / Subtle color accent inside the projector lens / Does not light up ( Color of your choice ) +$50
    - LED Demon Eye / Lights up inside the projector lens. (Color of your choice - Red, Blue, Green, Amber, or Purple) +$80
    - Halos (White or Amber / Front or Rear mounted) +$100 For One Set / +$180 For Both Front & Rear
    - RGB Color Changing Halos +$150
    - RGB Color Changing LED Demon Eye +$150 ( Recommend to Wire them to a Switch/Button )
    +$270 For Both RGB HALO & RGB LED DEMON EYE
    - Clear / Light Clear Smoke / Dark Clear Smoke Replacement Reflectors
    Replaces Stock Amber +$45
    - Black Chrome or Chrome Parking Light Corner +$30
    - Custom Color Matched Paint work / Our Professional Painter uses the best paint & clear product by GLASURIT. ( Pricing Varies )
    - Custom Art/Design Etching in Projector Lens +$45
    - OEM Upgraded Bulbs are Available to compliment your Choice of Projector (Pricing Varies)
    - 50W Ballasts instead of 35W +$10
    - HAWAII Shipping +$45
    RECHELON.AESTHETICS
    Questions/Inquries or Concerns
    rechelon.aesthetics@gmail.com
    rad.rechelon@gmail.com
    FAQ
    Q. Is there a warranty?
    A. Yes. We offer a six month warranty on workmanship. TRS components follow the TRS warranty period. For example, 5Five Ballasts carry a 24 month warranty. 3Five ballasts carry a 60 month warranty. Etc... No hassle warranty. Shipping cost will be taken care of by TRS for U.S. transactions. For owners outside the U.S., you will be responsible for the shipping cost per TRS.
    The cost of shipping the headlight(s) to to me is the original owner's responsibility. I will be responsible for the cost of returning the warrantied headlight(s) to the original owner within the U.S. Sorry, if you are outside the U.S., you pay shipping both ways. This warranty is NOT transferrable. Any modifications and/or tampering of headlights will void the warranty.
    Q. How hard is it to install the headlights and wire harness once I receive them?
    A. If you have a slight bit of mechanical skills, then the installation will not be difficult. The wire harness is plug 'n play, no splicing of the OEM harness is required (unless your lights are equipped with LED Angel Eyes). The new, retrofitted headlight bolts up the same way your old one was removed. Wire harness instructions are included with your shipped headlights as well as online.
    http://www.theretrofitsource.com/pdf/trs_tech/Bi-Xenon MotoControl Relay Harness.pdf
    The OEM headlight aiming mechanism remains fully functional. After your retrofitted headlights are installed, some fine tuning will be required utilizing the OEM adjusters. Fine tuning is defined as matching both the left and right cut-off so that they are level with each other. As a rule of thumb, I recommend aligning the height of the cut-off to be horizontal with the upper trunk line of the average sedan.
    Q. Where can I learn more about retrofitting, projectors and HID bulbs?
    A. The Retrofit Source (TRS) has a tremendous amount of online material to enhance your retrofitting knowledge.
    http://www.theretrofitsource.com/trs_tech.php
    Q. What's the difference between the bulb colors?
    A. Kelvin Ratings: 3000K - Has a golden yellow output perfect for use in fog lights. The yellow light penetrates through snow, rain, and fog more effectively than white or blue light. 4300K - Has a slightly off-white output similar to that of sunlight. Most cars that come equipped with HID headlights from the factory use 4300K bulbs. If you want the most usable light, 4300K is the Kelvin rating for you. 5000K - A pure white output, no tinge of yellow, and no tinge of blue. 6000K+ As you move into the higher kelvin ratings, your light output will appear more bluish-purple in hue, but the bulbs won't be physically as bright. I do not offer 6000k bulbs. As HID bulbs age, they go through what is known as "color-shift". When the bulbs are brand new, the output is whitish-yellow and as physically bright as it will ever be. As the bulbs age with use, their output turns more pure white/bluish and also starts to dim a bit. That's why cars with factory 4300K bulbs that are 5+ years old look like they're running 5000K or higher bulbs.
  2. Mar 11, 2016 at 9:47 AM
    RECHELON
    RECHELON AESTHETICS
    SoCal to Portland
    DCX2
    * @DefconBrix SEMA 2015 | R E C H E L O N BLACK CAMO RETROFIT *
    IMG_3389.jpg IMG_20150923_080716.jpg 1429388949075.jpg 1438699890088.jpg 1432317312088.jpg JDMC14xRECH.jpg 1431891147102.jpg 1430858443608.jpg 1431891147102.jpg 1438810571001.jpg 1438810893761.jpg IMG_40011.jpg IMG_43941.jpg
    Sect0r - brand new OEM headlights, G37R shroud with white halo in rear, flat black paint, smoked reflector
    temper - Brand new OEM headlights, G37R shroud w/ RGB halo, flat black paint, smoked reflector
    Idaholandho - brand new OEM headlights, anodized blue demon eye, bullet shroud, flat black paint, smoked reflector
    w/ flash on
    Dave P - Brand new OEM headlights, Panamera shroud with front and rear mounted amber halo, flat black paint, smoked reflector
    almoss - brand new OEM headlights, DTRL and Apollo 3.0 shroud left chrome, smoked reflector
    iHacker - Brand new OEM TRD Pro headlights (black chrome finish), Apollo shroud, everything left alone for an OEM look
    Flat black bezel, Shroud, Bowl, DTRL, and corner bowls all left chrome, amber halo, Apollo shroud
    TACOMAA6 - Brand new OEM headlights, Apollo 3.0 with white front mounted halo, red passive demon eye, smoked reflector, flat black paint
    Toyota Technical - Brand new OEM headlights, Panamera shroud with front and rear mounted amber halo, flat black paint, smoked reflector
    IMG_20160223_154339.jpg IMG_20151221_113130.jpg IMG_20151222_114329.jpg IMG_20150828_101348.jpg IMG_20150824_100345.jpg IMG_20150805_130413.jpg IMG_20150707_104356.jpg IMG_20160224_134537.jpg IMG_20160301_122030.jpg IMG_20151203_133303.jpg IMG_20160302_112824.jpg
  3. Mar 11, 2016 at 10:13 AM
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    Looking good. :bowdown::drool: Wish I had the extra. :(
  4. Mar 11, 2016 at 10:34 AM
    RECHELON
    RECHELON AESTHETICS
    SoCal to Portland
    DCX2
    ^ TY for the kind words Johnathan
    We Hope to Craft with you one Day in the Future
    There are plenty of creative ideas on our Instagram account [ RECHELON.AESTHETICS ]
    Give us a Follow! :thumbsup:
    ChadsPride likes this.
  5. Mar 11, 2016 at 12:02 PM
    NateMob
    NateMob Well-Known Member
    Nathan
    South Ogden
    1997 Land Cruiser
    Triple Locked
    "- Brand New OEM Genuine Toyota Headlights * Updated Clear Glass Version by Toyota *"
    What is this all about?
  6. Mar 11, 2016 at 12:06 PM
    _gray_knight_
    _gray_knight_ Well-Known Member
    SoCal
    '18 Mall Crawler
    Just washed
    Old DTRL lense had an issue of melting or cracking (MY 2005-2011), TSB where updated DTRL lense is now clear glass.
  7. Mar 11, 2016 at 12:11 PM
    NateMob
    Nathan
    South Ogden
    1997 Land Cruiser
    Triple Locked
    Same thing is listed under the 2012-2015 section.
  8. Mar 11, 2016 at 12:13 PM
    _gray_knight_
    SoCal
    '18 Mall Crawler
    Just washed
    Yeah '12-15, That I'm not sure on...but previous year models yes.
  9. Mar 11, 2016 at 12:37 PM
    RECHELON
    RECHELON AESTHETICS
    SoCal to Portland
    DCX2
    ^ Just a typo on the 2012-15. That will be removed & edited right now. Thanks for noticing that as the 2012-15 don't have the glass feature. Sorry for the mix up on that and all is well now.
    Kind regards,
    RAD
  10. Mar 11, 2016 at 2:35 PM
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
  11. Mar 11, 2016 at 2:40 PM
    Buell
    Buell Instagram: @thebuell
    Michael
    Brooklyn, NY
    1970 Chevy Nova
    :annoyed: just spent so much money but now......:popcorn: thinking about spending more...
  12. Mar 11, 2016 at 2:42 PM
    RAD
    Rad
    LAX & LOGAN
    ^ Didn't I do your BHLM Michael? This was like what, 4-5 years ago? Hope all is well with you and its been quite awhile.
  13. Mar 11, 2016 at 2:43 PM
    Buell
    Michael
    Brooklyn, NY
    1970 Chevy Nova
    Yes you did and yeah like 4 years ago.
  14. Mar 11, 2016 at 2:44 PM
    RAD
    Rad
    LAX & LOGAN
    :thumbsup: I lost track as I did so darn many back then.
  15. Mar 11, 2016 at 2:49 PM
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
  16. Mar 13, 2016 at 1:43 PM
    RAD
    Rad
    LAX & LOGAN
    All Inquires responded through our Email this morning.
    Thanks guys and we look forward in Crafting these sets!
    Enjoy your Sunday
    Kind regards,
    RAD
  17. Mar 13, 2016 at 6:56 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
  18. Mar 15, 2016 at 10:47 AM
    RAD
    Rad
    LAX & LOGAN
    * * Emails all answered this Morning * *
  19. Mar 17, 2016 at 10:19 PM
    RAD
    Rad
    LAX & LOGAN
    * * Thanks for emails and questions guys * *
    I've locked down a few more orders and I am looking forward to a busy month in April. All builds will start then and ship out asap.
    _gray_knight_ likes this.
  20. Mar 19, 2016 at 11:51 AM
    RAD
    Rad
    LAX & LOGAN
    We've got a few more added into this Group buy pricing. :thumbsup:
    * ALL EMAILS RECEIVED & ANSWERED
    HAVE A WONDERFUL WEEKED EVERYONE
