2.0 fox shock air valve broken
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kauai808boy, May 20, 2012.
  1. May 20, 2012 at 1:35 PM
    kauai808boy
    kauai808boy [OP] Member
    icon/fox 3inch lift, flow-master super 40, jba shorty headers
    just got in a pair of 2.0 fox proseries shox and as i was installing one of them it sliped out and fell right on the air valve and broke and all the air leaked out see attached image
    so im asking do i have to send it in to get it fixed? or can i just fix it myself with a new valve and if so how much pressure do i filll it back up with
    07toyota tacoma 3inch lift
  2. May 20, 2012 at 3:35 PM
    seric007
    seric007 Well-Known Member
    trashed, just send them to me. :D
  3. May 20, 2012 at 3:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You should be able to fix them yourself. Contact Fox for Nitrogen pressure specs, and adjust accordingly. Use Nitrogen, not compressed air.
  4. May 20, 2012 at 10:02 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    150psi of nitrogen, just get a new valve. Motorcycle shops will have the nitrogen, ditto on NO AIR! air has oxygen and will rust the guts of the shock.
