2 1/2" rear lift needed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by barbell, Apr 2, 2010.
  1. Apr 2, 2010 at 8:33 PM
    barbell
    barbell [OP] Member
    jason
    saluda sc
    white 2009 tacoma 4x4
    3" revtek front lr ucas 1 1/2 block and aal in rear ome rear shocks colormatched grill grillgraft grill and bumper insert bhlm other misc paint mods line-x rear bumper n-fab step bars debadged tailgate door emblems painted black black cam-locker toolbox
    i have a 3" revtek spacer lift up front w/ 1 1/2" blocks in rear. im exactly 1" low in the rear. how can i get 2 1/2" on lift in the rear?? also adding 5100's to the rear. are all of the 5100's the same length?? which do i need w/ 2 1/2" rear lift??
  2. Apr 2, 2010 at 8:51 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    5100's are intended to only accommodate 2" of rear lift.
  3. Apr 2, 2010 at 9:03 PM
    barbell
    barbell [OP] Member
    jason
    saluda sc
    so what rear shocks should i get??
  4. Apr 2, 2010 at 10:16 PM
    nick11
    nick11 Member
    07 Prerunner
    3" lift, full stereo system with 2 amps and sub behind the rear seat.
    I have the same revtek 3" in front and 1 -1/4 rear blocks. My trucks sits exactly level. I just put a camper shell on it and with anything else in the bed, it sits lower in the back. I am going to do an AAL to get a full 1-3/4 in the back and increase my load capacity. I am not sure why you are 1" low with the blocks you already have in the rear?
  5. Apr 2, 2010 at 10:21 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    You could go with the OME rear setup. Dakar leafs and OME shocks. Should give you about 2.5-2.75 in. of lift, I've had mine for two days so not much road time, but there reputation speaks for itself.
  6. Apr 2, 2010 at 10:24 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    i think there are 5100,5125,5150 not sure wich one you need to lazy to look. go to bilstein.com and check them out.
  7. Apr 2, 2010 at 10:25 PM
    TacoSupreem
    Hayden
    Kentucky
    you could get a 1.5" aal with a 1" block?
  8. Apr 3, 2010 at 4:14 AM
    barbell
    barbell [OP] Member
    jason
    saluda sc
    i dont know why its low. i added the lr ucas also. think that made a lil diff. kinda wanted to get away from the blocks. guess ill check out the dakar leafs.
  9. Apr 3, 2010 at 6:46 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    You are better off getting front coilovers so you can adjust it than try to put more money in the rear and make the ride even worse than it already is with the spacers/blocks. I ended up with Toytec coilovers and rear 1.5 in blocks, rear bilsteins 5100 shocks and the ride is better than stock !
