2"/1" lift - spacer/block
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 18' TACO TRD, Oct 18, 2018.
  1. Oct 18, 2018 at 1:28 PM
    18' TACO TRD
    18' TACO TRD [OP] Well-Known Member
    Florida
    2018 TRD Cement
    Does anyone have a ready lift 2" front with 1" rear block. I'm assuming this is a 1" thick front spacer.
    I have 1.5" factory difference (1.5" higher in the rear).
    https://www.readylift.com/2-front-leveling-kit-toyota-tacoma-6-lug-2005-2018.html
    https://www.readylift.com/1-rear-block-kit-toyota-tundra-tacoma-1995-2018.html
    This should put me level or maybe .5" higher in the rear which I'm wanting. I was looking at the 3/2 lift but I'd rather have little less wheel gap.
    I'm trying to achieve a 285/70 R17 or 285/65 R16 Tire. I believe it's possible without rubbing if I select the proper rim offset (+6 or 0 offset)
    Says the leveling kit can fit the following wheels;
    33" Maximum tire diameter
    33x11.50 for no rub on a 9" wide wheel with +6 offset
    17" - 295/70R17
    18" - 295/65R18
    20" - 285/60R20
    22" - 285/50R22
