2.1 surround sound any good?
Discussion in 'Entertainment' started by coffeesnob, Apr 22, 2011.
Thread Status:
Not open for further replies.
  1. Apr 22, 2011 at 5:58 AM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Does anyone have 2.1 surround sound? If so what is your opinion on it? What brands are recommended? I know 5.1 and 7.1 are the way to go but all I want is a little better sound than what the TV plays. I read a review that sony has a good system but it looks like everything gets plugged into the subwoofer and I don't want those wires and cords showing. :)
  2. Apr 22, 2011 at 7:22 AM
    buck
    buck Don't sweat the petty - pet the sweaty
    Ontario, Canada
    15 DC V6 4x4 TRD Magnetic Gray
    High-flow coconut smiley-face air freshener.
    A nice 2.1 system will most likely sound better than your TV speakers. 2.1 would also be good for lots of music listening. If you're going to be watching movies, maybe investigate a sound-bar. I know a couple of guys with them and they appear to like them.
  3. Apr 22, 2011 at 7:30 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Anything will sound better then TV speakers so I guess a 2.1 would be fine for just TV but if you really want it to sound good and get true surround sound I would go with at least 5.1
  4. Apr 22, 2011 at 12:04 PM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    i dont think 2.1 can be considered surround sound can it? just basically stereo with a sub. i know they can "simulate" surround sound but its never very good
  5. Apr 22, 2011 at 12:09 PM
    JLee
    Jerry
    Grass valley CA
    X2 I have the 321 system in my garage and is sounds pretty dam good but I only use it for music.
  6. Apr 23, 2011 at 5:25 AM
    coffeesnob
    VA
    thanks, i think the bose system is pretty pricey though.
  7. Apr 24, 2011 at 12:58 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    whats your budget? you can score a decent 5.1 for pretty cheap now a days.
  8. Apr 25, 2011 at 1:06 PM
    coffeesnob
    VA
    my concern is that I don't want all those speaker wires all over the place. I have a small living room
  9. Apr 25, 2011 at 1:15 PM
    JLee
    Jerry
    Grass valley CA
    Do you own the house?
  10. Apr 25, 2011 at 1:20 PM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    For decent sound from a home a/v theater system, the most important speaker is your center channel, as most of you sound comes from there. At least get a 5.1 system, and just use the three front channels plus the sub. You can use a sound bar to simulate surround. They work okay IF you have th proper room and placement (need walls for the simulated sound to bounce off of). Even if you don't have the perfect room, it will still probably be good enough for you.
  11. Apr 25, 2011 at 1:40 PM
    smithrw
    smithrw Well-Known Member
    wichita, kansas
    09 tacoma sr5
    I tried sound bars and was not that impressed for what they cost. Imo the Bose is way over priced but thay seemed to sound good. I finally just went with a good Clipsch powered sub and it's been great. Will definatly shake the floors.
  12. Apr 25, 2011 at 7:24 PM
    Toph
    Toph Addicted to V8s
    Virtual surround works well in square rooms with walls to bounce sound off of. For my place, I just ran wire through the attic and walls. I wanted a beefy stereo with 5 speakers and a sub.
  13. Apr 25, 2011 at 7:31 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i have a surround bar that i think is 2.1 or something like that. i like it
  14. Apr 25, 2011 at 7:34 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    I have 2.1 for my computer. Great for general purpose, louder, higher quality listening. 99.9% of my speaker use is music and from my experience, nothing beats the traditional ol' two speakers and maybe a sub for in house music listening.
  15. Apr 25, 2011 at 8:56 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    x2
    do you rent or own? if you own, just run the speaker wire through the walls/ceiling.
    if your dead set on 2.1, go to bestbuy or something and check them out.
  16. Apr 25, 2011 at 11:13 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Buy the 5.1 & only hook up 2 sides, 1 center, & the sub. So one day when you want the 5.1 surround, you don't have to buy something else. Also if a speaker goes out, you have backups.
    They make wireless systems so you don't have wires running all over the place. Best buy sells one. Rocketfish wireless speaker kit
    I currently have my 7.1 Denon hooked up with 2 side speakers (spaced at opposite corners, diagonally from the seating area), a center, & a sub. Never got around to hooking the back speakers. My living room in my new house is small & I really don't need to hook them up. With the 2 speaker diagonally I get good surround sound for the space. You will be much happier if you get the 5.1. You can play with your setup & maximize your sound for your space.
  17. Apr 27, 2011 at 2:32 PM
    coffeesnob
    VA
    Yes I own my house er...well..the bank does. My thinking was if I could get a decent 2.1 I would get it instead of having to run all those speaker wires, receiver to tv, wires to ps3, wires to direct tv or does on cable do it all now.
  18. Apr 27, 2011 at 4:18 PM
    genxer36
    Sean
    Bethlehem,GA
    No matter what system you get. You will have to run a cable(wire) from the receiver to the cable/directtv box, & then another to the PS3.
    For Sound - I have Digital optical (Fiber optics-do not bend the cables, they are glass) cables for my sound from my receiver:
    to my PS3, to my PC, & to my cable box. - 3 cables/wires
    For Video - My TV is connected via HDMI cables.
    From my PS3, Cable box, & PC. - 3 cables/wires
    Then I have Monster speaker wire running along the baseboards for my speakers.
  19. Apr 27, 2011 at 4:31 PM
    schleygo
    schleygo Well-Known Member
    Daniel
    Ft Worth TX
    07 Dbl Cab Radiant Red
    Bilsten 5100s, Eibach Coils, 2" toytec AAL, LR UCAs, SC5 Matt Bronze
    I have a sony soundbar w sub. It is 200watt and has 2 right, 2 center, 2 left speakers in the soundbar and a sub box. It sounds 10x better than my 55inch flat screen. It was 350dollars and worth every penny.
    The sound is full and rich, but it is no 5.1 Bose. It makes my PS3 wake up and looks good.
    I really like it because it is compact and not obnoxious like all the dam speakers in a 5.1.
  20. May 6, 2011 at 12:41 PM
    coffeesnob
    VA
    Do you have the small square room people have mentioned you need for a soundbar?
Thread Status:
