$2,100.00 repair
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WESTERN308, May 7, 2025.
  1. May 7, 2025 at 12:54 PM
    WESTERN308
    WESTERN308 [OP] Member
    My 2022 TRD sport 4x4 with 36,600 miles has a leak at the spool valve seal. To fix the dealer needs to: Steering Gear Box Assembly Remove and Replace. I've owned several Toyota trucks and never had an expensive repair until they were high in miles & years. Is this normal? Any information is welcome.
    HondaGM likes this.
  2. May 7, 2025 at 1:00 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    While some may be more common than others, unless it's a Ford, there are no "normal" leaks @ 36K
    SandyTaco4x4, StihlToyota and HondaGM like this.
  3. May 7, 2025 at 1:07 PM
    jgarverick
    jgarverick Well-Known Member
    2021 DC SR
    I don’t understand how they get away with this. There has seemingly been an epidemic of steering rack failures. Hasn’t happened to me yet but I’m at similar mileage and age.
    But also there are guys out there with 200k miles with little to no issues. So it makes me wonder if all the racks manufactured on Friday afternoons are trash.
    WESTERN308[OP] and HondaGM like this.
  4. May 7, 2025 at 1:10 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    At 36,600 miles Toyota should extend some type of goodwill assistance with that repair IF you are the original owner.
  5. May 7, 2025 at 1:18 PM
    WESTERN308
    It was a lease return. First registered April 2022, I purchased from the dealer September 2022.
    SandyTaco4x4 and HondaGM like this.
  6. May 7, 2025 at 1:20 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW...
  7. May 7, 2025 at 1:23 PM
    Big Cole
    Big Cole Well-Known Member
    How bad is the leak and how often do you have to add fluid to power steering reservoir?
  8. May 7, 2025 at 1:24 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    If it isn’t warranty, then drive it as long as you can before fixing if. No sense in going through all that trouble and expense to fix a leak or seep. Sadly, Toyota still either can’t figure it out or doesn’t care to learn how to build a steering rack that doesn’t leak.
    Rusty66, Chew and CrashZone like this.
  9. May 7, 2025 at 1:32 PM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    First, ask the dealer if they will fix it for you under good will warranty. If they are persistent that they won't help, politely call corporate and let them know what is going on. They will assign a case manager and will most likely help with all or most of the repairs. The key here is to remain polite but somewhat firm. Start asking for complete reimbursement...they won't pay the dealer but they will pay you to pay the dealer. If they say no, start negotiating help with the fix. I wouldn't want to drive a truck that new with a leak but that's me. I would be willing to bet you will have to pay under $500 if you pay anything at all.
    Ngneer, vme, RustyGreen and 2 others like this.
  10. May 7, 2025 at 1:36 PM
    WESTERN308
    Adding power steering fluid about once a month.
  11. May 7, 2025 at 1:37 PM
    Big Cole
    Totally agree. My Jeeps leak fluid consistently and I just replace fluid as needed. This is what jeeps do.
    Tocamo likes this.
  12. May 7, 2025 at 1:39 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    A 2022?... 36,600 miles.... wow.
    Original issue most likely was occurring at or below 36,000....
    I'd call Toyota Corporate or ask the dealer to open a ticket or whatever they do and see if Toyota won't do the right thing.
    WESTERN308[OP] likes this.
  13. May 7, 2025 at 1:56 PM
    545 Well-Known Member
    2015 Access Cab
    Toyota corporate is pretty understanding of these slight out of warranty issues
    Contact them
  14. May 7, 2025 at 1:58 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    I dunno, I feel like any repair at dealership is going to be 2k+ no matter what it is....
  15. May 7, 2025 at 2:02 PM
    jgarverick
    2021 DC SR
    I don’t think he was complaining about the price but rather the failure itself.
    Rusty66 and WESTERN308[OP] like this.
  16. May 7, 2025 at 2:24 PM
    WESTERN308
    Thanks for the advise. Just got off the phone with Toyota Brand Management. Said they will contact the dealer to see if something could be done with pricing...? This weekend I planned to pull the trigger on heavy duty rear springs and a set of BF Goodrich A/T tires. That will be on hold :-( Untitled (1).jpg Untitled.jpg
  17. May 7, 2025 at 2:31 PM
    WESTERN308
    I'd be okay with this if the truck was 6 or 7 years old, But 3 years and not even 50k miles!:mad: Thanks again for the replies. I'll post the outcome when it comes.
    Chew and NAAC3TACO like this.
  18. May 7, 2025 at 3:00 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There are lots of threads about weeping racks. I have posted a lot about Mazda PS fluid (ATF) helping.
    The oil pan pic looks like a leaking drain seal?
  19. May 7, 2025 at 3:48 PM
    Rusty66
    Rhode Island
    Yes the rack boot is damp…..adjust the fluid level and watch it…..and check out that drain plug it’s wet.
  20. May 7, 2025 at 4:33 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Toyota don’t make the rack , I would call corporate and see if they can help
