2-3" Lift for 2011 DC LB 4x4
Discussion in 'Suspension' started by Rhody76, Dec 28, 2010.
  1. Dec 28, 2010 at 8:00 PM
    Rhody76
    Rhody76 [OP] Well-Known Member
    Rhode Island
    2011 SR5 DCLB 4x4
    Rear leaf TSB, Bilstein 5100s set at 1.75",1" blocks, UWS low profile toolbox in black, husky liners, tint, LED interior and reverse lights, yellow fogs
    Hi All,
    I am looking into a lift for my new double cab LB 4x4 and would like to get opinions/advice on what route I should go. I am not looking for a lot of height, 3" max, and do not do serious off roading although I do load her up with heavy material quite often and also tow a 4000 lb boat from time to time. Mainly I am just looking for a more agressive stance and don't want too stiff of a ride.
    I also am wondering if there are limitations because I dont have a TRD. Most of the lifted trucks I have seen on this forum have the TRD package.
    I would love to see some photos of any lifted long beds out there.
    Thanks in advance for any advice
  2. Dec 29, 2010 at 8:01 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    All the kits that work for the TRD models also work on all 6-lug tacomas.
    I would recommend Bilstein 5100's. They are a shock with an adjustable spring perch that preloads your factory springs to get different amounts of lift. You can set them to 0.85", 1.75" or 2.5".
    They are under $200 for the fronts from Down South Motorsports and Wheelers Offroad.
    Plenty more info on them if you do a quick search. There's also a few threads around here that are exclusively pictures of lifted DCLB's.
  3. Dec 29, 2010 at 12:53 PM
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    Can they be installed on front and rear for a level appearance or are more components needed? I thought there was more to it. Thanks
  4. Dec 29, 2010 at 12:55 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    check my build thread by clicking the truck below. Lots of pics with different lifts, all 3".
  5. Dec 29, 2010 at 1:07 PM
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    Whats the rear TSB? Is that an add a leaf?
  6. Dec 29, 2010 at 1:09 PM
    H0LLYW00D
    H0LLYW00D Well-Known Member
    I just lifted my 09 dc lb 4x4 and I used Icon front coilovers and rear shocks, Dakar leafs and Total Chaos upper control arms. Ride is great and have had not issues at all so far. had the truck back a week and been driving as much as I can.
  7. Dec 29, 2010 at 1:24 PM
    KPT
    09 Prerunner
    No the rear shocks do not provide lift. You will need an add-a-leaf to level.
    It is a entirely new leaf pack, provided by toyota. Sear "leaf tsb" to find out more.
  8. Dec 29, 2010 at 2:35 PM
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    Thanks guys. This info gives me a good starting point.
    BTW. sweet FJ SE wheels. How do you like em?
  9. Dec 30, 2010 at 9:26 AM
    kansay
    kansay Well-Known Member
    dude
    Twin Cities, MN
    08 tacoma dbl cab 4x4 sport
    Bilstein shocks front and back.
    Hi Guys, I'm new here and I just have a question about my lift. I've just done the rear leaf TSB done by toyota and it seems that I got a 1.5 in lift. I've ordered a 2.5 in front end lift, will it be different for the front and back, or will it level my front to back. I haven't put it in yet but wanted some info b4 starting. Anything will help.
    Thanks
  10. Dec 30, 2010 at 1:31 PM
    KPT
    09 Prerunner
    Welcome to TW. The 1.5 out back will settle to 1" pretty soon.
    You will be nose-high if your lift is 2.5". Check out my build thread in my sig. I have the TSB and bilstein 5100's set to 1.75 and I'm perfectly level.
  11. Dec 30, 2010 at 1:53 PM
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    Kansay which front end lift did you get? How did the new springs affect the ride?
  12. Dec 30, 2010 at 6:35 PM
    kansay
    dude
    Twin Cities, MN
    Rhody76,
    The car seems very stiff after the TSB replacement. Don't know if it's the new leaf spring that's giving me that issue so will have to see when it settle down. Going over bumps I can feel every inches of the roads and I really like a smooth ride.
    KPT,
    I just got the 2.5 inch add-on on the top of the spring and don't know if that's really good way to go. I just wanted to try it out and see how it is but still waiting to see. Like your ride that you got, and that's the way that I want to go. Got it off ebay for 50 bucks so I wanted to try it on. It came in today and I measure it and it's only 1 and 1/4 height. Don't even know if it'll even raise my truck up as i like.
  13. Dec 30, 2010 at 6:48 PM
    KPT
    09 Prerunner
    Hate to tell you but that's the worst possible type of lift IMO. All it does is force the whole shock and lca assembly downward. It really stresses the ball joints. Also by lengthening the shock like that, your bump stops are now useless. You will bottom out the shock before hitting them.
    On the height issue, spacers lift twice their thickness, so the 1.25" spacer will give you 2.5" of lift.
  14. Dec 30, 2010 at 6:50 PM
    kansay
    dude
    Twin Cities, MN
    KPT,
    So what do you recommend on getting for the front shocks?
  15. Dec 30, 2010 at 6:56 PM
    KPT
    09 Prerunner
    If you are on budget, you can't go wrong with bilstein 5100's. They have an adjustable spring perch that preloads your stock springs to lift the truck. You can set them at 0.85", 1.75", or 2.5". They are under $200 at down south motorsports and wheelers offroad.
  16. Dec 30, 2010 at 6:59 PM
    kansay
    dude
    Twin Cities, MN
    So these shock doesnt come with new spring and it should fit right in with my stock spring?
  17. Dec 30, 2010 at 7:01 PM
    KPT
    09 Prerunner
    Yep they were designed to be used with stock springs, and to dampen the added stiffness of preloading the springs.
  18. Dec 30, 2010 at 7:25 PM
    kansay
    dude
    Twin Cities, MN
    cool man, so it's the 5100's right, not anything else that i needed to get this to work?
  19. Dec 30, 2010 at 7:29 PM
    kansay
    dude
    Twin Cities, MN
    I see there are the [FONT=Arial, Helvetica, sans-serif]Bilstein 5100 Series Monotube Gas Struts and the [/FONT][FONT=Arial, Helvetica, sans-serif]Bilstein 5100 Series Monotube Gas Adjustable Struts. Which one i should go with?[/FONT]
  20. Dec 30, 2010 at 7:33 PM
    KPT
    09 Prerunner
    The adjustable ones.
