2.4/2.7 fuel filter mounting location delete & relocation
Discussion in '1st Gen. Tacomas (1995-2004)' started by keakar, Oct 20, 2014.
  1. Oct 20, 2014 at 1:03 PM
    keakar
    keakar [OP] Well-Known Member
    karl
    louisiana
    ok, I have studied the fuel filter replacement videos
    https://www.youtube.com/watch?v=3hXO2ph9XCY
    and one thing is crystal clear, its just dumb IMHO to put the filter back on in that hard to get to and work on location so my plan is to just remove the old filter and bracket and then remount it onto the drivers fender well, down under the fuel line connection and run a new rubber fuel line to the fitting for the fuel rail. to do this I will just cut off and peel off the hose crimp collars to add a new line to it and clamp it in place.
    I have done things like this to replace dried up worn hoses before and its easy to dremel off the crimp collars and then cut and peel the old hoses right off to replace the hose with a new one. the only unknown is the size of fuel line I need which I will find out when I cut it.
    all the stock connecting points and fittings will be reused so everything is still stock connections and a new stock replacement fuel filter will be installed.
    why would you want to mount something back in such a hard to reach area when there is a better option?
    im asking if anyone out there has any thoughts why this isn't a good idea to do it?
  2. Oct 20, 2014 at 4:37 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    I don't have anything really helpful to add except that I paid a shop to do the fuel filter. Knew it was a bitch to do. Even the shop had minor issues replacing it.
  3. Oct 20, 2014 at 9:47 PM
    knuckleduster271
    knuckleduster271 Well-Known Member
    Baron Longrod Von Hug€nschlong
    ohio
    98 sr5 xtra cab
    881's, 5100's, soft 8's, elocker, matrix seats, smittybilt xrc8.
    I did my 3rz taco over the summer. It wasnt fun but i didnt think it was that,big of a deal.
    Im getting ready to do the one on my tunda and it looks like a piece of cake. Its on the frame rail right under the drivers door.
  4. Oct 21, 2014 at 6:53 AM
    keakar
    karl
    louisiana
    yep, that's what makes me so mad is the 6 cylinder trucks have them under the drivers seat too but in the 4 cylinders they make us play wheres waldo :notsure:
