2.4 5 lug towing
Discussion in '1st Gen. Tacomas (1995-2004)' started by chadd925, Apr 27, 2011.
  1. Apr 27, 2011 at 10:29 AM
    chadd925
    chadd925 [OP] Active Member
    Bay Area, CA
    Bed Liner, Window Tint, Aftermarket Stereo
    So I just bought a new three seater sea-doo. The ski weighs around 800 lbs, And with the trailer everything is probably around 1300 lbs. I have a automatic 2.4 ltr. Tacoma that I know will haul it without a problem, but my question is: Do I have to buy and install a trailer hitch? Or can I just bolt the tow ball onto my bumper where there is a plug... Thanks for your time!
  2. Apr 27, 2011 at 2:47 PM
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    If you plan on hauling this jet-ski very often you should probably invest in a receiver hitch. The bumper hitch would work but I wouldn't recommend it. It's up a little too high and isn't near as strong as a receiver hitch would be. Besides, a good receiever hitch is maybe $120.
  3. Apr 27, 2011 at 3:08 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    ya im not even sure why they have a spot for a ball to go on the bumper... you cant really tow much with it and it's not a good idea IMO. If you tow once in a great while it MAY be ok, but why risk $5000 worth of stuff for a $120 hitch? and if it helps i got mine from jcwhitney for around $130.
  4. Apr 28, 2011 at 6:11 AM
    tacosuprem
    tacosuprem Well-Known Member
    Florida
    4x4
    The bumpers are rated to 3500lbs tow weight and 300lbs tongue weight. I tow 900 lbs with my bumper. But if i was to tow more i would think about a hitch.
  5. Apr 28, 2011 at 7:00 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Get a hitch.
  6. Apr 28, 2011 at 7:23 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
  7. Apr 28, 2011 at 7:27 AM
    chadd925
    Bay Area, CA
    So a bumper with a 3500 lb. tow weight capacity is questionable hauling a 1300 lb. total weight rig? The Bumper will actually bend? Something is not adding up here to me... Tacosuprem: Have you ever had any problems hauling that 900 lbs. off your bumper? Bending?
  8. Apr 28, 2011 at 8:15 AM
    tacosuprem
    Florida
    4x4
    Tows perfect. I cant even tell im towing. Bumper holds up fine, no bending. Just be careful when making tight turns going forward or backing up. The trailer will hit the bumper.
  9. Apr 28, 2011 at 8:32 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    X2 the max is 3500 with a tounge weight of 350...they have thoes numbers there for a reason. A 1300 lb wave runner is fine,
  10. Apr 28, 2011 at 8:41 AM
    STLharry
    Harry
    VT
    I still wouldn't trust a jet ski and trailer (not cheap!) to a bumper for towing.
  11. Apr 28, 2011 at 10:26 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    1300 lbs is nothing. You will be absolutely fine towing off the bumper.
  12. Apr 29, 2011 at 7:34 AM
    chadd925
    Bay Area, CA
    Thanks for your help, and here is what I'm working with! Stoked!
  13. Apr 29, 2011 at 7:43 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    not nothing, it can happen under any ammount of weight. i have a 1700 lb trailer and i bent mine. got a hitch the next day. spend the money and be safe. it will tow better too
  14. Apr 29, 2011 at 10:10 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I towed my mowing trailer for quite awhile on the bumper with no real issues (i have the same truck as you in an xtracab). It handles the weight fine, but it's easy to damage when backing. I put a dent and a huge scrape in my license plate with the tongue (really not a big deal but something to think about). I also jack knifed it once in a tight cul de sac and dented the bumper. It's probably fine with the bumper but be super careful. A jet ski trailer is really short and easy to jack knife on the ramp.take it slow.
  15. Apr 29, 2011 at 10:27 AM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2003 DC TRD v6, auto
    Stock - built correct from the start.
    Just get the hitch. I provides many options besides just a ball mount. With the receiver you can use bike racks, extra cargo carrier, adjustable height ball mount, etc.
  16. Apr 29, 2011 at 5:20 PM
    DanglingFury
    Keith
    2006 4Runner 4x4
    ^ My license plate is BEAT TO HELL. The only reason I don't have a receiver hitch is . . . I don't pull a trailer very often . . at all. but it's still BEAT TO HELL.
