2.4 Oil Pump Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2003Tacoma2020, Sep 18, 2021.
  1. Sep 18, 2021 at 5:09 AM
    2003Tacoma2020
    2003Tacoma2020 [OP] Member
    2003 Tacoma 2.4
    Where can I find good instructions/video on replacing the oil pump in a 2003 2.4 Tacoma? Is there any special things to know such as lining up any markings etc. Thanks for the help.
  2. Sep 18, 2021 at 1:28 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Why do you need a new oil pump? I bet Timmy the tool man has a video!!
    Don`t forget to prime the oil pump!
    Since you need to remove the timing chain your going to need to line that all up again How many miles?? since it is apart install a new one??
    You might need a tool to hold the crank shaft till you break the 193 or so foot pounds of torque also to retorque that bolt.
    You need the correct puller to get the pulley off
    Being careful not to scratch the crank or the oil pump bore removing the oil pump seal
  3. Sep 19, 2021 at 5:26 AM
    2003Tacoma2020
    2003 Tacoma 2.4
    i'm about to drop a 166,000 junkyard engine in my work truck. Just a peace of mind thing.
  4. Sep 19, 2021 at 9:25 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    With the engine out its a piece of cake....
    most any video on the 2rz is same 3rz (2.4L/2.7L) with very few exceptions....
    (1178) Change a 3rz engine oil pump # toyota - YouTube
    Lc eng and toyota dealer sells whole kit....and this may be better than the vid... And here's that tool....
    Amazon.com: for Toyota/Lexus Crankshaft Damper Pulley Holding Holder Harmonic Tool with 2PCS Crank Bolts : Automotive
  5. Sep 26, 2021 at 5:26 AM
    2003Tacoma2020
    2003 Tacoma 2.4
    This is perfect. Thanks for the help. Another question is what are the two "dimples" on both gears? Do they have anything to do with alignment or timing?
