2-4 select to j-shift conversion help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trash_Shakes, Jul 31, 2023.
  1. Jan 10, 2024 at 1:28 PM
    #41
    Danny.kalps
    Danny.kalps Well-Known Member
    Danny
    Spokane, wa
    2004 Tacoma dbl cab 3.4
    DF07875E-2C50-4A80-8254-42B5A36654D6.png DF07875E-2C50-4A80-8254-42B5A36654D6.png I have this, but need a little more
  2. Jan 10, 2024 at 3:22 PM
    #42
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I didn’t have to build a separate harness, as I was just swapping from a push button t-case to a j-shift. I was able to use the existing wiring in the harness. For your purpose, I would imagine that you’ll just need to build a stand alone harness with the 8 leads for the transmission control relay, 5 of which will go to the ADD actuator motor and the others are either power, ground, or the wires from the 4wd switch on the t-case.
    I know there are a number of good write ups on a 4x4 swap, perhaps @Area51Runner or @BartMaster1234 could shed a little light on what you need to do in your situation.
    CA-Taco and Danny.kalps[QUOTED] like this.
  3. Jan 10, 2024 at 4:27 PM
    #43
    Danny.kalps
    Danny
    Spokane, wa
    Great thanks for that!
  4. Jan 10, 2024 at 5:27 PM
    #44
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Dan is right. You’d have to figure out the correct signal flow utilizing the t-case sensors. I rarely see anyone doing a 4WD swap with ADD, because of the electrical you have to do to get it to work.
  5. Jan 10, 2024 at 7:52 PM
    #45
    Danny.kalps
    Danny
    Spokane, wa
    Yes I agree with that. I was on the looks for a 03-04 trans for over a year and couldn’t find anything decent priced. Then an 03 parts truck popped up on marketplace that I jumped on that had everything I need. But has the add front diff
  6. Jan 11, 2024 at 12:32 PM
    #46
    Trash_Shakes
    Trash_Shakes [OP] Member
    2004 Tacoma TRD
    I think I figured it out. @drr ,on the relay plug I'm supposed to run a jump wire from pin 3 to pin 9, to supply power to the 4wd position sensor. I saw that note as I was quadruple checking that we built it right.
  7. Jan 11, 2024 at 12:33 PM
    #47
    BartMaster1234
    Tyler
    Flux Capacitor
    Why do you want the 03-04 trans? That will have the electronic throttle, given it's an automatic.
  8. Jan 11, 2024 at 12:35 PM
    #48
    YungSprung
    YungSprung Well-Known Member
    Why would you do this and NOT convert to Multi-mode...?
    Aka 2WD+4WD+AWD
    They're crushed daily across the country.
    Get the T-case, Attached Harness,
    the Front shaft, and shorten the rear shaft.
    Boom Done.
  9. Jan 11, 2024 at 2:15 PM
    #49
    Trash_Shakes
    2004 Tacoma TRD
    Yup. Forgot to connect 3 and 9. It works!!!
    drr likes this.
  10. Jan 11, 2024 at 2:24 PM
    #50
    YungSprung
    AWD circles on dry pavement.
    Pairs nicely with 2 Helical diffs,
    front and rear.
    "Get Some!"
  11. Jan 11, 2024 at 4:02 PM
    #51
    Danny.kalps
    Danny
    Spokane, wa
    Sorry for the confusion, I just updated my profile. I have a 2004 double cab prerunner that I just completed a 4x4 swap. I also swapped over the ecm and the entire harness for that computer
