2.4L 2RZ-FE 1997 Tacoma Rattling Shield Near Manifold
Discussion in '1st Gen. Tacomas (1995-2004)' started by sporatica, Apr 18, 2023.
  1. Apr 18, 2023 at 3:32 PM
    sporatica
    sporatica [OP] Member
    SS
    1997 Tacoma Xtra Cab, DLX
    N/A
    I've been chasing a rattle in my engine compartment and finally found the culprit, but I don't know the name of the part. It's a shield just below the manifold on the passenger side. It looks like two of the nuts have worked their way through the bolt-holes and are no longer securing the part.
    I was thinking about adding large washers to secure the nuts.
    I have three questions.
    1. What is the name of this part
    2. Is it ok to just add washers or better to replace the part?
    3. How difficult do you think it will be to remove these nuts?
  2. Apr 18, 2023 at 3:49 PM
    JoeT4R
    JoeT4R I don't have a Taco
    Joe
    NOVA
    '01 4R, SR5 4WD
    Heat shield I imagine. Washers might do the trick or you could yank it altogether. That's what I did with one of the heat shields on one of my catalytic converters
  3. Apr 18, 2023 at 4:23 PM
    sporatica
    SS
    N/A
    I'm hesitant to remove any heat shielding because I'll be driving this Tacoma through the desert in about a month on my way to New Mexico.
  4. Apr 18, 2023 at 6:12 PM
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
    Soak with PB blaster or ATF on those nuts/bolts before you try to remove them. They will snap off. A couple washers and it'll be fine till stress fractures work further out. Plenty run without heat shields on headers anyway.
    sporatica[OP] likes this.
  5. Apr 18, 2023 at 8:18 PM
    Lucky_Gargoyle
    Lucky_Gargoyle Well-Known Member
    96 DLX 2.7 4x4 5spd
    Toytec coil-overs, SPC upper, OME CS019 leafs w/ 5110 bilstein, LCE header
    I replaced a cracked manifold w/ LCE long pipe header. My colorado heat shield came right off. Still have it. Wishes I keeped the old manifold and extension pipe to the cat but, nope.
    I would washer that boy and them nuts don't look as bad as I've seen on some from the east coast. I beat they wrench right off.
