2.4l 2RZ No Spark Help
Discussion in '4 Cylinder' started by luisbmx, Sep 2, 2014.
  1. Sep 2, 2014 at 6:49 PM
    luisbmx
    luisbmx [OP] New Member
    luis
    san antonio tx
    97 base
    So I recently rebuilt the engine on my 97 taco, replaced just about everything except the short block. About after a week of driving it it died out on me one day and wouldn't start. No fuel or spark so I replaced am1, am2, and 80a fuses. Started right up and worked fine for about a month.
    Recently while driving the engine died while driving, I didn't even notice until I took a turn and noticed the power steering wasn't working. Wouldn't start for about 10 minutes then I was able to drive it home. Started it up later that night and drove it around fine.
    A few days later I went to start it up and nothing. It's not getting spark. It is getting fuel. Went ahead and replaced those 3 fuses again and it didn't help. Checked my grounds and everything seems fine. Stumped :confused::confused::confused:
  2. Sep 2, 2014 at 6:53 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Just guesses (and I'm probably WAAY wrong) maybe fuel pump relay, ignition switch or relay, coolant temp sensor or worse try another known good ECM. I don't know. Good luck.
  3. Sep 3, 2014 at 6:54 AM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    Maybe the block ground loosened up? Just spitballing here...
  4. Sep 3, 2014 at 5:42 PM
    luisbmx
    luis
    san antonio tx
    97 base
    Went ahead and tried the engine block ground since I didn't give that one as much attention as the others. The bolt wasn't loose but I went ahead and loosened it and rotated the ground some and made sure to tighten it well. She fired right up :) glad it wasn't anything big. I was thinking I was going to have to trace a short or replace the igniter or something
  5. Sep 4, 2014 at 5:51 PM
    fittvr
    fittvr Member
    Vern
    Florida
    Taco 4x4
    Great info but it would help knowing the engine and where the ground was located. Maybe a picture. Just a thought.
  6. Sep 7, 2014 at 5:21 PM
    luisbmx
    luis
    san antonio tx
    97 base
    Alright, here's the location of the ground. The engine is the 2.4l 2rz. It's underneath the intake kind of near the starter / slave cylinder
    Hupptacular likes this.
