2.4L 4cyl 2D normally underpowered or is something wrong?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chicago77, Nov 14, 2022.
  1. Nov 14, 2022 at 2:56 PM
    Chicago77
    Chicago77 [OP] Well-Known Member
    I am curious if the 2.7 4cly is just always underpowered or if my truck is somehow down on power. (No idea why I put 2.4 in the title but now Im stuck wiht that stupidity)
    I have a 2005 2D 4WD 5speed and it seems pretty underpowered, especially on the highway in 5th. I find I have to shift down if Im headed up a modest hill @75MPH, or many times when I am hard down on the accellerator and the truck just stays at the same speed (unloaded). It just feels like its bogging down heading uphill. I feel like I have to hit a 4.5k shift point to keep it lively enough. Moving to 3rd gear at highway speeds is not uncommon.
    The truck is stock accept for slightly larger tires 245/75/17, which I felt no difference moving to from stock. Everything seems to be working well and Im only at 105K. I have recently replaced oil/trans/diff fluids, air filters, and spark plugs.
    I honestly dont even really know how I would test this and I understand that the above it subjective. Id love to hear others opinions and shift points at speed.
  2. Nov 14, 2022 at 2:59 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Is this a new thing?
  3. Nov 14, 2022 at 3:12 PM
    Bishop84
    Bishop84 Well-Known Member
    Are they heavy tires like E rated 10 ply?
    I notice the size up on a v6, so you're not doing an favors to a 4 banger with them.
    4 bangers simply aren't rockets, I enjoy the manual in the city, and manage expectations when on the highway.
    TnShooter likes this.
  4. Nov 14, 2022 at 3:19 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    A few thoughts on how to test:
    1. Cylinder compression check.
    2. Get your truck dyno'd
    3. Ride/drive another similar truck or have a driver with another similar truck drive yours.
    4. Borrow a device that accurately records 0-60 mph and compare with similar truck owners here on TW (flat ground w/a similar altitude.)
  5. Nov 14, 2022 at 3:20 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Sounds normal to me.
    When I had my 2.7 PreRunner 5spd, I had shift to 4th in order to over take other vehicles going up hills.
    This was on the interstate doing 75ish mph just like you said.
    b_r_o and SilverBulletII like this.
  6. Nov 14, 2022 at 3:22 PM
    Chicago77
    They are not E rated tires, just normal. I didnt notice any difference when changing them vs stock. Also, I inherited this turck the way it is, so I cannot speak to if it has been better or worse. That's kindof why I am tyring to figure out if this is how they all are.... or if there are any known issues I should be looking out for.
  7. Nov 14, 2022 at 3:32 PM
    TnShooter
    Deogee
    STOCK
    Like @Bishop84 said, the 2.7 isn’t know for “speed and power”.
    It’s know for being reliable, until the 4.0 came out in the 2nd Gen, there wasn’t a Toyota truck engine that had “power”. And saying the 4.0 has power, is a stretch. I’m comparing the 4.0 with the previous Toyota truck engines.
    Basically, what I’m trying to say is, “You got 5 gears, you need to use all 5”.
    Don’t be afraid to drop a gear. You aren’t going to hurt the engine running it “hard”.
    davidstacoma likes this.
  8. Nov 14, 2022 at 3:33 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    when my cat started going south my truck felt really underpowered. had no cel and got to the point where i would force the issue by downshifting and it would force the spring bolts on exhaust manifold to make a machine gun sound from forcing exhuast out of there. tires are 265/70/16s. It felt great with new catted midpipe and all back to normal. i could hear the brick inside the cat rattling around when parked in garage. dunno if this might be what is starting to go on with yours but mine was a slow degradation over a long time so it wasn't any all of a sudden thing. just one thing i experienced.......
    the other was too much tire and wheel on my old access cab 2.7...remember having to draft an 18 wheeler to keep hwy speed with kayaks on top
  9. Nov 14, 2022 at 3:45 PM
    Chicago77
    This is actually interesting, thank you! I do have rattles from the exhaust I have noticed if I tap the excellerator at a stop. It does sort of feel like its not breathing well, but I already replaced the air intake. Its hard to discribe the boggy feeling. Its like there is no power difference between 3/4 throtle and full throttle. I'll investigate this a bit further.
  10. Nov 14, 2022 at 3:52 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    My only point of reference is my '01, but what you typed sounds about right to me. It was probably close to the same weight, and I'm guessing when it comes to the highway that the extra size of a 2nd gen did no favors in the aerodynamics department.
    I had about the same size tires (32x11.5) and accelerating in 5th was hit or miss... on flat ground. Forget it on an incline, and yeah, grabbing 4th (or even 3rd if steep) was a normal thing. I loved the reliability, but man, that engine did not have much left beyond 'move truck acceptably quick.' Life starts at 3k RPM with that one.
  11. Nov 14, 2022 at 4:02 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    oh, and.....i went back with a bosal catted midpipe for $360 shipped. fit perfect and just put my same o2 sensor in with new gaskets on both ends. has been just fine and no cel or problems passing inspection. hopefully no precious metal in it either. doesn't look like oem squarish cat. my oem fail one got left on curb for garbage man...shoulda sold it at recycler lol.....no way was doing $2k oem. good luck widdit
  12. Nov 14, 2022 at 4:14 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I have a similar truck to yours. Yes, typically if you are on any kind of noticeable hill and you are trying to accelerate you will probably want to down shift. Dont forget on the 2.7 our torque curve does not really start to become available until 3k RPM.
    EDIT: Dont forget, try taking your truck up to highway speeds in 3rd gear. If the spring bolts on the exhaust start to compress and you hear it start hissing than your CAT is likely starting to clog. Of course if you get the P0420 dont even bother wasting your time with a bunch of snake oil....you have a 99% chance your Cat is clogged.
    Otherwise just accept the 2.7L for what it is in our trucks....requiring the lower gears somewhat often for all the power available to be utilized for torque. Other than that its mostly bullet proof.
  13. Nov 14, 2022 at 8:24 PM
    lbaldwin22
    lbaldwin22 Active Member
    2006 Silver Access Cab
    To reiterate what others have said here, you just get used to downshifting pulling up hills on the highway with the 2.7. Mines an access cab 5sp 4wd running 265/70/16’s and it’s just part of life. You aren’t gonna win any drag races just beat them out in longevity. Lol
  14. Nov 15, 2022 at 10:51 AM
    Chicago77
    Thank you everyone this is very helpful, I love this community! I actually love the truck too (even with the lack of power). I will do some temp checks on the cats and see if that is causing an issue, otherwise, I will chalk it up to normal. Off to find parts for a new front end lol.
  15. Nov 15, 2022 at 3:23 PM
    kidthatsirish
    Also if it really becomes an issue for you, you can always check out URD...they make a bolt on supercharger kit for our engines...but it is very pricey.
  16. Nov 15, 2022 at 3:33 PM
    Chicago77
    Ha I have looked at that. I would instead move to a 4D v6 I think.
  17. Nov 15, 2022 at 3:51 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Is there any oil seepage/sweat where the valve cover meets the head?
  18. Nov 15, 2022 at 3:52 PM
    fb40dash5
    11 V6 AC 4x4
    The best part of this is that after owning a 2.7, you won't be one of the ones who says the 4.0 is totally gutless!
  19. Nov 15, 2022 at 4:03 PM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    …don’t go to any States with mountains.
  20. Nov 15, 2022 at 4:04 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    They are not blazing performers brand new. Had two of them run forever but not a drag racer
