2.4L and 2.7L share the same valve cover gasket?
Discussion in '1st Gen. Tacomas (1995-2004)' started by GreatWhiteTacoma, Apr 22, 2024.
  1. Apr 22, 2024 at 10:20 AM
    GreatWhiteTacoma
    GreatWhiteTacoma [OP] Active Member
    2000 silver tacoma 2.4l 5 lug
    I ordered a valve cover gasket set for my 2.4L and they sent me one for a 3.4 and a 2.7L so I have an extra.
    they refuse to acknowledge that it says right on the packaging, that its for a 3RZ-FE, 2.7L engine. They also refuse to acknowledge that they sent me an extra kit for a 3.4L engine…. Ok? Your loss I guess.
    since they aren’t being any help, will the 2.7L gasket fit my 2.4L engine? Just holding it next to the engine it looks the same size but it doesn’t quite look like it will follow the contour of my valve cover. Hard to say though.
    autopartsway.ca if you are wondering. Horrible customer service.
  2. Apr 22, 2024 at 10:25 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Rock Auto shows the same part numbers for the 2.4 and 2.7L so I would say yes.
    I've found that some aftermarket gaskets don't fit well though.
    I'd reccomend doing the spark plug tube seals as well.
  3. Apr 22, 2024 at 10:50 AM
    GreatWhiteTacoma
    ok good stuff. Yeah the kit came with the spark plug gaskets as well.
  4. Apr 22, 2024 at 6:30 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Everything is identical on the two engines at same year...with the exception of:
    oil pump gear, the balance shafts and support gear....extra timing chain., gears, guides, and that tensioner....
    and bottom pan is different....because they fit in different chassis.
    2rz's get the brown injectors....and the 3rz's get the pinky's
    As far as that gasket, I'd buy a new modern silicone gasket one......a good one...not a cheap one
    sorry dont have a good link there...
