2.4l RWD Lower shock bolts
Discussion in '1st Gen. Tacomas (1995-2004)' started by moistytaco617, Sep 9, 2024.
  1. Sep 9, 2024 at 4:48 PM
    moistytaco617
    moistytaco617 [OP] Member
    Edgar
    97 Tacoma 2.4 Reg Cab
    CAI, Exhaust, Sound System,
    Switching over to Blisteins and passenger side bolt broke off and the other bolts keep stripping, went to o reilleys and found bolts but they also keep stripping, ideas?
  2. Sep 9, 2024 at 4:51 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    My assumption is that the nut itself is stripped.
    Any and all crud and gunk built up in there will aid in stripping any bolt you attempt to run through it.
    I'd suggest cutting off and welding a new nut, and utilize a new bolt for mounting your shocks. If this is not an option for you, maybe attempt to clean out the nut completely and run a chaser to clean up the threads for your new bolts to run through.
  3. Sep 9, 2024 at 8:34 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Is this the nuts welded inside the control arms....
    the ones that strip out super easy.
