2.4L turns over fine, then dies
Discussion in '1st Gen. Tacomas (1995-2004)' started by seligman, Jun 4, 2010.
  1. Jun 4, 2010 at 3:58 PM
    seligman
    seligman [OP] Well-Known Member
    I have a 1996 Tacoma (2.4L 4-cylinder) that dies immediately after turning over. This started today, for the first time ever. When it dies, it does so very quietly. The check engine light seems to be on continuously.
    A week and a half ago, I removed the EGR valve, pipe, and hoses to clean them. Then I ran some Seafoam through the brake booster vacuum line to pass smog, which it did. Ever since the engine has been running fine, absolutely no warning signs.
    I backed out of the driveway today and it died. When I restarted it, I could tell it was ready to die again, but it lasted long enough to get back to the garage. Now it won't stay running at all.
    Thanks in advance!
  2. Jun 4, 2010 at 4:07 PM
    C17Guy
    C17Guy Well-Known Member
    Dennis
    Charleston, SC/ Charlotte, NC
    09 SR5 Access Cab 5 Lugger
    Readylift Kit, 245/75/16, HID's, Debadged, Kenwood DNX9960 Double Din Navigation, Image Dynamics Door Components, Pioneer Amp, Dynomax Super Turbo Muffler, Grillcraft Uppers and Lowers
    I'm no mechanic, is the fuel pump functioning?:confused:
  3. Jun 4, 2010 at 4:07 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Huh, it almost sounds like your out of fuel. Maybe check for spark first just to rule that out all though it definitely sounds like a fuel issue.
  4. Jun 4, 2010 at 4:12 PM
    seligman
    I have over 3/4 of tank of gas.
    Fuel pump maybe? Do these things die suddenly without warning? It's just puzzling how I brought it home last night running great, then today, it won't stay running to move 30 feet.
  5. Jun 4, 2010 at 4:15 PM
    C17Guy
    Dennis
    i'll shit myself if i'm right! :D
    i usually suck at working on cars, so def keep me updated on what the problem was!
  6. Jun 4, 2010 at 4:16 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    from what I know, fuel pumps usually die all at once. You can try turning on the key and listen for the pump by the fuel tank. I think it should make some noise if it's working.
    Edit: never mind, I just went out and checked and mine doesn't make any noise with the ignition on. Im not sure how else to check the fuel pump.
  7. Jun 4, 2010 at 5:08 PM
    seligman
    I made a recording of me attempting to start the truck. Let me know what you think.
    Thanks!
  8. Jun 4, 2010 at 5:13 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Sounds like no gas.
  9. Jun 4, 2010 at 5:16 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Check to make sure you vac lines are still hooked up to the EGR
  10. Jun 4, 2010 at 5:18 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    this,
    and great recording. You are much easier to help than most people who come on here with problems.
  11. Jun 4, 2010 at 5:20 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  12. Jun 4, 2010 at 5:23 PM
    seligman
  13. Jun 4, 2010 at 5:27 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    That hose that comes out of the bottom. That will return the fuel to the tank. If the fuel pump is gone, nothing will come out.
  14. Jun 4, 2010 at 5:28 PM
    seligman
    Thanks...I'll have an answer for you in about 10 minutes.
  15. Jun 4, 2010 at 5:43 PM
    seligman
    There's definitely fuel flowing. I put a plastic cup underneath, it was pushed back by the pressure. There was enough fuel present to fill up the cap of a plastic soda bottle.
  16. Jun 4, 2010 at 5:52 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    A soda cap bottle? It should have been streaming out. Let's try this. Put the hose back on and pinch it shut. Then try to start it.
  17. Jun 4, 2010 at 6:08 PM
    seligman
    Actually, it was a little more than that. Enough to fill the cap of a bigger Gatorade bottle.
    I pinched the hose with a pair of Vise-Grips. On the fifth try, it stayed running, but was rough. I shut it off after 30 seconds. Then I removed the Vise-Grips, tried starting again, and it was identical to the sound recording I posted above. In other words, it died immediately.
  18. Jun 4, 2010 at 6:13 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Yeah, sounds like the pump is gone.
  19. Jun 4, 2010 at 6:15 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You should have between 38-44 psi in the fuel line with the ignition on and the pump energized. Gas should have spewed everywhere
  20. Jun 4, 2010 at 6:15 PM
    seligman
    Those were the words I was afraid of.
    What am I looking at $$$ for a new pump?
