2.5-3 in lift w/265's. What do i need?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by miniracer43, Dec 9, 2010.
  1. Dec 9, 2010 at 7:19 PM
    miniracer43
    miniracer43 [OP] Member
    06 prerunner
    should be getting my tacoma in a couple of weeks now and looking do lift it. First question is
    -looking at the pro comp 7032 17in wheels. what would be the best offset and backspacing for 265-75 tires?
    -General grabber AT2's. Best on/off road tire?
    -was reading a bit on lifts and vibration problems. I like the 5100's for the front but if i put them in the back, does it level it out if i set it at 1.75 or do i need something else for the leaf's?
    -How hard is the install for this? I have lots of tools and experience with working on dirtbikes.
  2. Dec 9, 2010 at 7:25 PM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    You'll need an add a leaf for the back. The 5100's don't lift the back at all.
    Maybe a 1.5 inch AAL in the back with yur 5100's up front set at 1.75...
    Install isn't too bad. Check the install threads around here.
  3. Dec 9, 2010 at 7:35 PM
    miniracer43
    06 prerunner
    If the 5100's dont lift the back, would it be a better idea to just to do the AAL in the back and upgrade later to a better shock later on?
  4. Dec 9, 2010 at 8:15 PM
    NamBam
    NamBam Member
    Birmingham, Al
    2014 DBSC SSM Off-Road
    5100 set at 2.5 in the front. with 1.5 aal in the rear. and yea you can always add new shocks in the back when you see fit. Good luck with getting a taco.
  5. Dec 9, 2010 at 8:18 PM
    JanBoothius
    JanBoothius Taco abuse specialist
    Jan (Pronounced Yon)
    Salt Lake City, UT/Upstate New York
    '10 TRD Off Road Access Cab, 6 speed
    OME lift, 886 coils, Dakars w/AAL ARB front bumper, Warn M8000 winch Toyo Open Country MT 285/75R17 (34) Leer 180CC cap etc etc etc $
    I know nothing about the General Grabber AT2, however the best on/offroad tire I am aware of, is the BFG All Terrain T/A. It is supposed to last forever. I see them several times daily, when driving in the Salt Lake City area of Utah.
  6. Dec 9, 2010 at 8:26 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    17x8 4.5" backspacing.
    Do it. Check the link in my sig for my suspension install.
  7. Dec 9, 2010 at 10:34 PM
    Lunercrab
    Lunercrab AKA "06tacosport"
    Beth
    Lehigh Valley area, PA
    2010 timberland mica dcab sport
    I had the grabber at2s on my 2006. I really liked the tire. But I decided to try the wrangler duratracs with my 2010 and lovin them so far as well.
  8. Dec 9, 2010 at 10:46 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    just out of curiosity, why a 265 and not a 285?
  9. Dec 9, 2010 at 10:50 PM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    285's will rub like mad onthe fender and the frame.
  10. Dec 10, 2010 at 5:56 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Not with proper backspacing (4.5") and a little trimming. 285's with a 3" lift is a very popular combo on here.
  11. Dec 12, 2010 at 12:51 PM
    Trackmaster
    Trackmaster Active Member
    TRD 4X4
    I RUN 265/75/16 with 5100's set a 1.75. I also have the rear Tsb. As long as I didnt haul any weight the truck set real level but put 200 lbs in the back and it raked back bad. I oredered the toytec add leaf for the rear tsb truck sets a little higher in the rear know but looks good with a load in it. I am always hauling something . I left the stock shocks on the back until last week just put a new set of billeys on the back and cant beleive the diffrence in ride shoud have don it when I put the fronts on.
  12. Dec 13, 2010 at 7:33 PM
    JCMINIS
    JCMINIS Well-Known Member
    Old fort NC
    07 sport,white 4x4,SR5
    Custom fr bumper,2.5 HBS front lift,rear TSB,K&N
    Agreed, mine came from factory with 265's. I added 2.5 level and tsb rear springs and 285's fit perfect,no rub with 16x7 steelies.
