2.5" Bilstein 5100 in front, ? in the rear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nitro1356, Jun 3, 2014.
  1. Jun 18, 2014 at 4:00 AM
    #81
    Phils514
    Phils514 Well-Known Member
    Phil
    Dcsb
    I found a 2" aal from top gun customz. They have the long leaves, for what I've heard they are less stiffer than short aal.
  2. Jun 18, 2014 at 8:11 AM
    #82
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Not true at all, the kit isn't that expensive and there is no need for a compressor. Semi trucks etc use them 24/7, why would you not be able to leave 15psi in them for daily driving? What are these "other things" you speak of? A bicycle pump will fill them in a couple minutes. Or if your truck has the outlet in the back a tiny compressor can be kept in the truck for when you need to air them up.
  3. Jun 18, 2014 at 8:27 AM
    #83
    06TacomaTRD
    06TacomaTRD Well-Known Member
    Brett
    South Carolina
    2011 MGM TRD OR PreRunner
    See Link --->
    It seems like the OP has already decided his route, but this is for anybody else who is wondering-- I have Bilstein 5100 all around with the front set at 1.75" with a 1" block in the back. I have been running this setup for a little than a year now with no issues (lift related) with a slight rake (1/2 of an inch or so). There's a couple pics in my build thread page that you can check out for comparison.
    Edit: 1 1/2" or so*
  4. Jun 18, 2014 at 8:49 AM
    #84
    Phils514
    Phil
    Dcsb
    How many leaves do you have in the back?
  5. Jun 18, 2014 at 9:40 AM
    #85
    jruba
    jruba Taco-rriendo
    South Texas
    14 TRD offroad , Magnetic gray .
    2014 TRD offroad , 265/75R16 duratracs on MB352's,Husky Liners , 5100's1.75,wheelers 1.5 add a leaf , digital camo wet okole's ..
    I got wheelers off road 1.5 ,for TSB leafs .... im 95% positive im going with 1.75 in the front . I like the factory rake , plus I load my truck quite often .
  6. Jun 18, 2014 at 9:44 AM
    #86
    Phils514
    Phil
    Dcsb
    I don't have the tsb on mine, so hopefuly the 2" leave with the 1.75 will give me a good stance. I hope it's not too much rake
  7. Jun 18, 2014 at 10:33 AM
    #87
    Yota64
    Yota64 Professional Threadjacker
    Sounds like you've got it figured out.
    If it is too much rake you can rely on the rear sagging after a while.
  8. Jun 18, 2014 at 12:23 PM
    #88
    jruba
    jruba Taco-rriendo
    South Texas
    Yes I do , parts will be here Friday , im gonna pay to do the front end and do the rear myself , don't wanna deal with manual spring compressors ..
  9. Jun 18, 2014 at 12:34 PM
    #89
    Yota64
    You sure you wanna pay? There are usually TW members local to you that can help for a MUCH lower price. Not that they charge, but you would normally buy them lunch or beverages. I'm having all my work done like that. Also, if they are coilvers, you can just bolt them on. If they need to be compressed that is a different story.
  10. Jun 18, 2014 at 5:08 PM
    #90
    CVTejas
    CVTejas CVTejas
    Charles
    Fort Worth, TX
    2010 Taco 4x4 TRD Sport
    Farad Cold Air Intake, BFG All Terrains, ARE Z-Series Deluxe Fiberglass Top w/ Keyless Entry and LED interior lighting,Road Armor front bumper w PIAA 510 driving lights, Edlebrock adjustable shocks w factory coils, road Armor front bumper. Kenwood DDX8901HD
    I agree w RiderX.. Set them lower.. My 2010 is running just below 2.5 and I have the SkyJacker leaf springs in the back and it rides like a 3/4 ton Chevy...
    My wife's Wrangler with a 4" lift is almost the same ride quality as this...
  11. Jun 18, 2014 at 6:52 PM
    #91
    jruba
    jruba Taco-rriendo
    South Texas
    Local shop charges me 90$$ for everything or 50 just to replace the shocks .. I usually do my work om my old cars but I rather pay this time ..
  12. Jun 19, 2014 at 5:24 AM
    #92
    06TacomaTRD
    Brett
    South Carolina
    See Link --->
    I have 3 including the overload spring.
    Edit: My OP has been edited--it's 1 1/2" rake not 1/2"-- I apologize for my lack of ability to press the 1 on the keyboard*
  13. Jun 19, 2014 at 6:17 AM
    #93
    Phils514
    Phil
    Dcsb
    Oh ok. Now you got me thinking of setting it to 2.5 since I'll be putting a 2" leaf
  14. Jun 19, 2014 at 6:48 AM
    #94
    Yota64
    Then heck go for it! $90 is not bad especially when you've already got the DIY bug out of your system
    I agree, 1.75 would increase your rake but it depends on what rake you want
  15. Jun 19, 2014 at 6:57 AM
    #95
    Phils514
    Phil
    Dcsb
    I want as little as possible.
  16. Jun 19, 2014 at 6:59 AM
    #96
    Yota64
    then 2.5 is the way to go
  17. Jun 19, 2014 at 7:07 AM
    #97
    Phils514
    Phil
    Dcsb
    I guess I'll install the leaves first then measure how much I gained with them since my current 3 leaves are old. How much sag and how long does it take usually for it to settle?
  18. Jun 19, 2014 at 7:16 AM
    #98
    Yota64
    I wouldn't be able to answer your truthfully. I have only heard this from many people here, I haven't experienced it. I have heard some people say they sagged after 10k miles, I have heard others so there's no sag at all if you don't put a load in.
    :notsure: I think it would be appropriate to ask around or search for a sag rate. Search AAL and try and find someone who has documented their experience. Hope this helped.
  19. Jun 19, 2014 at 7:28 AM
    #99
    Phils514
    Phil
    Dcsb
    Thanks man. Will try to search when I get down time.
  20. Jun 19, 2014 at 7:39 AM
    #100
    Yota64
    To preserve your downtime and to keep me from doing actual work:
    http://www.tacomaworld.com/forum/suspension/322979-not-quite-what-i-want.html
    That's some pretty good info. Right there on the first page you have a good review, a bad review, and alternative suggestions!
    I forgot to suggest you just go ahead and get a progressive 3 leaf AAL. it is supposed to maintain comfort and apparently not sag as much but don't quote me on that. If I did not already have an AAL I would sure as hell buy a 3 leaf.
