2.5 Coilover misalignment spacer??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tonyt915, Apr 7, 2015.
  1. Apr 7, 2015 at 3:21 PM
    tonyt915
    tonyt915 [OP] Well-Known Member
    My Name Is Toby!!!
    Tomball, TX
    2010 TRD Off-Road
    Pelfreybilt front bumper, SOS skis plates and rear bumper, Icon extended travel coilovers, Icon 2.5 w/resi's rear shocks, Dakar lead springs, Warn 9.5ti winch, Oem roofr rack
    Bought some ICON 2.5 coilover on Ebay but the seller didn't send the spacers. Called ICON and looking at $50 shipped to me. Was searching around and 4 Wheel Parts has a variety of misalignment spacers in different sizes locally. Anyone know if these are a universal or specific to ICON and what's the sizes needed? Also by chance anyone have some they don't need?
  2. May 17, 2017 at 3:01 PM
    Anteupp
    Anteupp Mega Member
    Bump lol I'm in the same exact predicament!
  3. May 17, 2017 at 8:27 PM
    x250f23x
    x250f23x Going in dry
    Lake Elsinore
    1.Figure out what size bearing you have in the shock rod end. Probably a 5/8"
    2.Measure the size bolt you have. 12mm?
    3.Measure the inside gap between the shock mounting tabs.
    4. Call your local suspension shop and give them these numbers :thumbsup:
    You don't need a misalignment spacers as the ball isn't over traveling. All the shock rod end needs is a straight shoulder spacer. And $50 for spacers is robbery. For $50 you could have someone custom lathe spacers. But thats Icon for you.. These should cost at the most $5 each
    If you get these numbers let me know and I'll look in our used spacer box
  4. May 17, 2017 at 8:45 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    I thought the misalignment was for avoiding contact with the sway bar(if still installed).
  5. May 21, 2017 at 10:21 AM
    x250f23x
    Lake Elsinore
    Please elaborate
  6. May 21, 2017 at 10:23 AM
    Justinlhc
    On mine, one side was larger and instructions said to place it on the front to shift the assembly back, preventing contact with the sway bar.
  7. May 21, 2017 at 10:25 AM
    x250f23x
    Lake Elsinore
    So you had a long and short spacer?
  8. May 21, 2017 at 10:25 AM
    Justinlhc
    Yes. I was under the impression that they all came like that?
  9. May 21, 2017 at 10:26 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Yeah, some shocks will specify a longer spacer up front.
  10. May 21, 2017 at 6:40 PM
    x250f23x
    Lake Elsinore
    If thats the case, still, find out your dims needed and call kartek, polyperformance or even ruffstuff. Let them know that you need a long and short spacer that fits within your application. They'll get you in the right direction or they'll be able to give you a better idea of what you need.
  11. May 22, 2017 at 7:12 AM
    themanbearpig012
    themanbearpig012 Well-Known Member
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Fox 2.5 Factory Series Coil-Over Reservoir (Front) Fox 2.0 Performance Series IFP (Rear) Method "Mesh" 17x8.5|6x5.50|0/4.75" wheels
    yeah i agree with @Justinlhc mine fox shocks came with a sway bar relocation bracket/spacer to it wouldn't be in the way if not deleted all together
  12. May 24, 2017 at 11:06 PM
    dsmdylan
    dsmdylan Well-Known Member
    Dallas, TX
    '17 DCSB OR Quicksand
    Same problem here. Lost one of mine when I had them off for a rebuild. Would be nice to have a definitive solution posted in this thread as it's a top result on Google.
  13. May 24, 2017 at 11:47 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oo.. That's tough, I would say 1.25" and 1.5" misalignments, but if it specifies for longer ones in the front than you may need different ones all together. Go on the Icon website and see if you can pull up a picture of them if at all possible. If one looks longer than the other than at least you know which direction you need to go in, if they are regular you can find them on Kartek or Polyperformance.
  14. Jun 4, 2017 at 7:04 PM
    dsmdylan
    Dallas, TX
    I don't think you can make any assumptions about the OD and IDs.
