2.5 Daystar tire clearance
Discussion in '1st Gen. Tacomas (1995-2004)' started by Evan 213, Dec 3, 2016.
  1. Dec 3, 2016 at 6:20 PM
    Evan 213
    Evan 213 [OP] Member
    Evan
    01 sr5 trd
    2.5 inch lift in the front, 2012 Trd stock rims, flowmaster super 10, Camper Cover
    I'm putting a daystar 2.5 level on my Tacoma, I've seen people put 33s on a 2.5 level but the lift manufacturer recommends 32s Would I need to trim the wheel well to fit the 33s ? Or would it be better to go with a 32 and have no rub or trimming? Also for reference I'm running stock rims. I've also seen skyjacker leveling struts on carid and realtruck.com, How good are they, do they even level the truck out, because rough country has a leveling strut. Anyway the sky jacker leveling strut, are they even worth the money
  2. Dec 3, 2016 at 7:08 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I have the 2.5 " daystar spacer right now, im running 32s and could run skinny 33s with mild trimming. I am half way through switching everything to OME and 5100s right now. The back is done and the new front coils and 5100s are with the mail man. Spend the extra $ on OME...well worth the money
  3. Dec 3, 2016 at 7:50 PM
    bodhi armor
    bodhi armor 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
    Steer clear of spacers at all cost!!
    The damage they will cause in the long run wil cost much more than a bilstein lift $600, or even rancho 9000XL quick lifts $400. They are both FAR superior to shit balls spacers!!
    Do what i wish i had done to begin with, instead of buying new 32" tires, get a used set from a small tire shop. (I got 4 bf goodrich Ats w/ good tread for $160)
    Take the money you wouldve spent on spacers and new tires and get coilovers that lift correctly.
    You will be glad you did
