2.5 fox coilover
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Arturoaguilar95, May 28, 2018.
  1. May 28, 2018 at 6:39 PM
    Arturoaguilar95
    Arturoaguilar95 [OP] Member
    Arturo
    2016 Tacoma trd sport 4 4
    6 inche lifted kit , Fox shocks coil over with reservoir, trd pro grill
    Is there a way to adjust the 2.5 coilover fox shocks i just put them on my 2016 Tacoma with a 6 inch lift kit i did not get the smooth ride that i was expecting
  2. May 28, 2018 at 6:48 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    6” lift + smooth ride is gonna be a tough battle. Do the Fox’s have dampening adjusters? What lift kit?
    Rainoffire and dYL0n like this.
  3. May 28, 2018 at 8:48 PM
    Riderfan
    Riderfan Active Member
    Doug
    RCI Sliders / Fox 2.5 + Fox 2.0 /
    I put fox 2.5’s on my ‘17. I bought them through Accutune who custom tuned them for my truck and driving conditions. They took about a month to soften and loosen up. They are awesome now.
  4. May 28, 2018 at 9:54 PM
    Ruger Inferno
    Ruger Inferno Well-Known Member
    Louie
    2016 Toyota Tacoma
    stock at this time, would like a quality suspension leveling lift, performance exhaust system, offroad tires, off road lights ect....
    what size tires were you able to install with your 6" lift?
  5. May 28, 2018 at 10:37 PM
    barcelona7568
    barcelona7568 Well-Known Member
    CO
    16 DCLB, Stock
  6. May 28, 2018 at 10:55 PM
    Arturoaguilar95
    Arturo
    i got a 6 inch from rough country and i put 35 with 18s
  7. May 28, 2018 at 11:52 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    A good ride starts with good tires.
    Next, a good ride is predicated on good springs. Last is good shocks.
    Stocklocker and WPNZ like this.
  8. May 29, 2018 at 12:35 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I would argue all of these factors can have an equal effect if not tuned or spec’d correctly. Shocks with high compression damping will negate the plushness of compliant springs, and vice versa. Tire and wheel weight (unsprung weight) also plays a huge role.
    Only when everything is dialed, or at least at a proper level of compromise, can you have a good ride.
    hiPSI[QUOTED] and WPNZ like this.
  9. May 29, 2018 at 7:42 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    yeah....... probably, but it seems like you can't fix tires. a cold, hard tire just makes your ride suck, no matter what you do. You are right though, you can tune shocks to help the springs and vice versa. But tires? Never been successful at that.
    Stocklocker[QUOTED] likes this.
  10. May 29, 2018 at 8:41 AM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    A ride with 6” blocks is not the way to go if you’re looking for a smooth ride.
    Look into BDS Suspension, they have fox coil overs for a 6” lift.
  11. May 29, 2018 at 8:53 AM
    Ruger Inferno
    Louie
    2016 Toyota Tacoma
    Thank you, I'm interested in a true 3"lift?? still considering a smooth ride. I know type of tires also make the ride.
  12. May 29, 2018 at 12:56 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Blocks in the back + fox (im sure theyre cranked all the way) will not get you a smooth ride. Thats why most here do 2-3” lift.
  13. May 29, 2018 at 3:45 PM
    Arturoaguilar95
    Arturo
    I did put the 6 inch coil over from BDS
  14. Oct 22, 2020 at 9:08 PM
    dviz4x4
    dviz4x4 Active Member
    2008 Toyota Tacoma 4x4 V6
    Did this improve your ride quality? I'm under the impression that the 6 inch fox 2.5 from BDS doesn't actually change the suspension travel from normal fox 2.5. I'm thinking that more of the strut is just covered by a longer spring and it's just a marketing tactic to make it appear that there's more travel?
  15. Oct 22, 2020 at 11:08 PM
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    Was just watching Mad Max: Fury Road
    That is the same lift Immortan Joe was rocking. He seemed pretty pleased with it.
    The Doof warrior had Kings I believe.
  16. Oct 23, 2020 at 4:43 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    OP never came back,,,,, years ago
