2.5 Gen Tacoma Diode Dynamics Backlight
Discussion in 'FBC Harness Solutions' started by chadley11, Nov 22, 2024.
  1. Nov 22, 2024 at 7:22 PM
    chadley11
    chadley11 [OP] Member
    2013 Tacoma
    Hi Dave,
    I have a 2.5 Gen Tacoma with Diode Dynamics SS3 Fog lights. I am looking to hook up the fog light backlight into the OEM Halogen headlight DRL without using the T-Taps that Diode Dynamics includes. Do you have a harness which I could use to do that? Thanks!
  2. Nov 22, 2024 at 7:46 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
  3. Dec 1, 2024 at 1:09 PM
    Smokescreen53
    Smokescreen53 Member
    Hey Chadley. Same here. What did you end up using?
  4. Dec 1, 2024 at 6:27 PM
    chadley11
    2013 Tacoma
  5. Dec 1, 2024 at 6:29 PM
    chadley11
    2013 Tacoma
    Planning on installing this week without the backlight for now. I'll add the backlight using the sidemarker T harness that dave suggested once it arrives.
  6. Dec 1, 2024 at 6:33 PM
    Smokescreen53
    Then I should order one. Dave how can I place my order
  7. Dec 1, 2024 at 6:44 PM
    daveeasa
    David
    PNW
  8. Dec 1, 2024 at 6:54 PM
    Smokescreen53
    Thank you. Order has been placed. You made my day
  9. Dec 1, 2024 at 7:04 PM
    Smokescreen53
    Should I have ordered a pair?
  10. Dec 1, 2024 at 7:31 PM
    caribe makaira
    Caribbean, Puerto Rico
    I would've purchased the combined turn (DRL) and parking version for the lightstalk control.
  11. Dec 2, 2024 at 5:23 AM
    Smokescreen53
    Yes. But do I need 2, one for each side
  12. Dec 2, 2024 at 6:43 AM
    daveeasa
    David
    PNW
    The two options indicate what you can expect. The bare wire is a single side, the ss3 is a pair.
    I will update the photo once I build your set.
  13. Dec 2, 2024 at 7:25 AM
    Smokescreen53
    Ok. I just want to be sure I have all that i need to install them. Please let me know if i need to order anything else. I just want to connect to the parking lights
  14. Dec 2, 2024 at 7:37 AM
    daveeasa
    David
    PNW
    This is all you need for backlight injection. You’ll also need power and ground for the fog itself which is typically from the OEM harness to the DD adapter harness.
  15. Dec 2, 2024 at 11:55 AM
    daveeasa
    David
    PNW
    If you are Sean then you ordered the bare wire not the SS3 version. Would you like me to cancel your order? If so please DM me your order number to confirm.
  16. Jan 3, 2025 at 4:34 PM
    chadley11
    2013 Tacoma
  17. Jan 3, 2025 at 4:53 PM
    daveeasa
    David
    PNW
    Sidemarker for 3rd gen is a different connector than the sidemarker for 2nd gen. That’s why I list the years in the title.
    chadley11[OP] likes this.
  18. Jan 3, 2025 at 4:58 PM
    chadley11
    2013 Tacoma
    @daveeasa I see that your store says that it's closed indefinitely. Is there any way I could still order the harness or are you done producing them?
  19. Jan 3, 2025 at 5:08 PM
    daveeasa
    David
    PNW
    https://www.corsa-technic.com/item.php?item_id=663
    And
    https://www.corsa-technic.com/item.php?item_id=983
    But I should check or someone else like @Puppypunter or @caribe makaira that I’m not confusing two similar connectors.
    then a 1.5mm flathead and some small needlenose. Make sure to get polarity correct.
  20. Jan 3, 2025 at 5:14 PM
    caribe makaira
    Them be the ones...at Corsa
    daveeasa likes this.
