2.5 in. Spacer question
Discussion in '1st Gen. Tacomas (1995-2004)' started by TACOTWENTY4, May 6, 2012.
  1. May 6, 2012 at 11:41 PM
    TACOTWENTY4
    TACOTWENTY4 [OP] USCG
    James
    Astoria, Or.
    '11 Tacoma Sport
    Alabama sticker on rear window.
    My son has a '98 Tacoma and wants to put the 2.5in Daystar spacer up front and the AAL on the rear to get some lift. I've read that the spacer makes for a crappy ride. If so, is that on rough terrain or normal driving? He'll basically be on the pavement and hardpacked logging roads.
    My original plan was Billsteins up front and rear AAL but, he has a little cash and is a typical 16 year old with little patience. Thanks
  2. May 6, 2012 at 11:47 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    On here you'll get a vast majority in opposition to spacers/blocks. Especially big ones. Billy's would be an upgrade. Spacer, downgrade. Shock + spacer will ride stiff on and off road from what I've read
  3. May 6, 2012 at 11:48 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    It will give him a rough ride on both pavement and off road.
    Safe up the $$$, not much more, and get the Bilsteins up from and rear AAL.
    With the spacer, you're preloading a stock spring and strut that won't have the dampening capabilities to handle that amount of preload on the spring. With the bilsteins, even though you're preloading the strut by setting the bilstein 5100 strut to 2.5 of lift, you'll have a much smoother ride because that strut can handle the preload with relatively superior dampening characteristics.
  4. May 7, 2012 at 7:46 AM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    Only downside to 5100s - they are on backorder till probably mid-June/July... I am waiting as well.
  5. May 7, 2012 at 8:35 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    X2
    this is most unfortunate..
  6. May 7, 2012 at 10:14 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    X10000 on what people have said about spacers. Tell him to save up and do it right the first time, or go back later to fix the mistakes he made.
    Bilstein 5100's are actually only slightly more expensive than a spacer kit.
    There is always OME if you dont want to wait. Its a bit more money, but many say those kits ride better then bilsteins.
  7. May 7, 2012 at 11:06 AM
    Rebel Taco Man
    Rebel Taco Man Well-Known Member
    Tyler
    Western Kentucky
    2002 Manual TRD SR5 4x4
    Bilsteins front and rear, Eibachs up front, 2" Toytec AAL in rear, Diff Drop, Grey Wire Mod
    I have a 2in spacer only up front that i bought off of ebay, it gives a decent ride, i like my ride better with the spacer cause its stiffer, but to some they may not, i go off road just about every weekend, not bad trails, but some mud holes, and 4-wheeler trails, it isnt bad plus its my daily driver. there is some things that worry me, and thats breaking the strut, or busting shocks, cause the spacers are bad about causin that.
  8. May 7, 2012 at 6:38 PM
    TACOTWENTY4
    James
    Astoria, Or.
    '11 Tacoma Sport
    He chocked, haha. Ordered the 2.5 inch daystar spacer and a 2 inch AAL. Says he rode in one with spacers and liked it. I say BS, he's going for cool. I'll post a picture when it's installed. Oh, they did say a few more months if you're waiting on the Billsteins.
  9. May 7, 2012 at 10:29 PM
    austinramsay
    austinramsay Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
    Im 16 with not much cash too, I got 3" spacer lift on mine just for a couple months until i can afford 5100s all the way around. Paid $60 with shipping on ebay ;) Rides fine, couldnt tell much of a difference.
  10. May 7, 2012 at 11:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    damn..oh well..he will come around..
    you obviously need to ride in a properly lifted truck.
  11. May 9, 2012 at 8:54 AM
    Phearson
    Phearson Taco or Die
    Brad
    Gresham OR
    1996 SR5 Tacoma. 33x10.5 Kevlar 3in lift
    I have a revtek 2.5 spacer with a block in the rear. It was cheap and gave me what i was looking for in ride height and that thing has sen many snowy trails
  12. May 9, 2012 at 10:03 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Do it right the first time, you and your kid will be glad you did:thumbsup: Just wait until june and save up some more money and get the 5100s for all 4 corners from Downsouth Motorsports. New front 2.5" lift shocks and new rear shocks for $295 shipped (with TW discount) with the 2" AAL lift for the rear. Pretty cheap but still pretty decent lift.
  13. May 9, 2012 at 10:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    true for just lifing it works just fine. Offroad..not so much.
    Your stock shocks are limited in travel. Thats whats the big inprovement over the 5100s set a 2.5''. Do they do the same thing as a spacer? yes, they precompress the coil BUT the 5100 shock is made for lift applications and can take the extra height.
    You spacers + stock shocks..do not do that..
    your jepordizing your suspention much more then if you had the proper length of shock.
    its cheap for a reason..will it work for a while? yes..but you should really get rid of it ASAP especially if you wheel a lot.
    Top mount spacers are the same story for the most part. Here you tend to over compress them with these type of spacers..other then if you use them on a properlly built shock. But even then, you shouldn't get to crazy with them.
    AALs are fine for lifting...for a while..AALs are basically just a bandaid for bad leaf packs. Our trucks leafs are notoriously bad after a time..and there are manny options for getting new packs. But a Good AAL will hold you off for up to over a year of hard driving and hauling sometimes. But again..it'll still wear out and you'll have flat leafs again. Only a bandaid
    as for my shocks leaking Ben..those are 5150s and that is also due to the wrong length of shock. So yes, perfect example. They are to short. So i over compressed them. Much like how you are over extended your stock shocks. Im already am lined out to fix them after Moab.
  14. May 9, 2012 at 11:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    they aren't popular..not on any toyota forum i am on...lol
    and i wouldn't put em on a truck with a 16 year old driving..that kid is just gonna push that truck so hard past its limits anyways...not a good idea..
  15. May 9, 2012 at 11:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ive had blocks..same damn thing. SUCKED!!
    and id say that the risk of breaking a shock is much higher then what MTs do or a lift does to the wheel bearings..
    and the 5100s alone will give you more articulation then a stock shock with a spacer..for not much more money.
    and yes, i suppose i will see...im not riding in you truck on a trail again tho..hahahaha
  16. May 9, 2012 at 11:26 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ben, you got spacers now you think they are freakin perfect! You are the new TW advocate for spacer lifts. You dont need high end suspension parts for a better ride, upgrades shocks/coils is a great medium.
  17. May 9, 2012 at 11:35 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    thats BASICALLY what you are saying. every spacer thread that comes up you are in it advocating spacer lifts and saying how all of the negatives are just panic responses and isolated incidents (like body lifts) lol. And that whole subjective ride is better argument is so tilted and you know it haha!
  18. May 9, 2012 at 11:42 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i hope you are not getting mad or defensive. you have had them for what? a month or two? So how much experience do you REALLY have with them. Let me know how great they are 2 years from now and if you would keep them over some new shocks or coils. Its subjective but its still comparing crap to slightly improved crap.
  19. May 9, 2012 at 11:52 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    k good, this is supposed to be a friendly debate.
    i dont really want to ask how many miles you have driven on what nor do i need to. Its just a fact that new shocks and,or coils are better. If not then why were you FREAKING out when you first got them. Its a chunk or metal stuck on top of the coil...the worst lift after body lifts...im secretly waiting for the proverbial foot in mouth when some fluke happens and you snap a shock.
  20. May 10, 2012 at 12:01 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    well its the long term that the ride gets real bad due to the stress the stock coils have been put on and the stock shock.
    and i better not break down lol and im sure you will make it over stuff i wont, that locker is a pretty big advantage..although who knows..
    i sure hope you don't have them on in 2 years..your trucks coils and leafs were soggy enough last year..this bandaid ain't gonna last that long..
