2.5 inch lift and 285s, these fit?
Discussion in 'Wheels & Tires' started by sambojee, Oct 2, 2011.
  1. Oct 2, 2011 at 6:43 PM
    sambojee
    sambojee [OP] Well-Known Member
    Sam
    Iowa
    2011 TRD OffRoad
    Bilstein 5100 all around set at 2.5. 1.5 AAL in the rear. 265/75/16 Hancook Dynapro MTs on Black Moto Metal 951s. Black badges. Aftermarket grill. TRD seat covers.
    Ive got a 2006 Tacoma and i have a 2.5 inch lift, i was wanting to run 285/75/16 bfg mt km2s, will these fit? how much rubbing will there be? what would i have to trim?
  2. Oct 2, 2011 at 6:45 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    What are the specs of your wheels
  3. Oct 2, 2011 at 6:47 PM
    sambojee
    Sam
    Iowa
    2011 TRD OffRoad
    16x8 4.5 backspacing and 0mm offset
  4. Oct 2, 2011 at 6:48 PM
    KPT
    09 Prerunner
    You'll need to trim some plastic from your wheel wells and possibly chop your cab mounts,
  5. Oct 3, 2011 at 10:57 AM
    sambojee
    Sam
    Iowa
    2011 TRD OffRoad
    Chop my cab mounts? U think I would have to trim that much?
  6. Oct 3, 2011 at 11:02 AM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    I thinks my DC2s are same specs and I had to trim quite a bit of plastic to run 265 Duratracs at 2" lift
  7. Oct 3, 2011 at 11:26 AM
    sambojee
    Sam
    Iowa
    2011 TRD OffRoad
    I have 265s with no lift and they fit fine on and off road, no trimming needed
  8. Oct 3, 2011 at 7:38 PM
    steveni70
    steveni70 Member
    CO
    07 TRD OR DCSB
    I'm running 265 Duratracs on stock suspension with no rubbing. You may look at 255/85s. I think they'll be fine with a 2.5" lift.
  9. Oct 3, 2011 at 7:43 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    you will need to remove your mud flaps, cab mount, pinch weld, and front fender lining trim if you ever plan on off roading,
  10. Oct 3, 2011 at 7:56 PM
    korslite
    korslite Well-Known Member
    Justin
    Bellingham, WA
    DCLB Sport
    FOX 2.5 RR's, TC UCAs, TC Spindle Gussets, Allpro Expedition leaf pack, Fox 2.O RR w/ Comp adjusters, 17" ATX Artillery, BFG AT 285's, de-scooped, custom sliders, custom bedrack, Brute Force Fab bumpers, Smittybilt XRC8 winch, ARB locked Rear diff
    Like people are sayin, they will fit but you will be trimming. I wish I had saved the pile of plastic I've cut off my truck to try to curb the rubbing. I've got 285's and I'm probably only running about 2" in front. I still rub the top of the fender flare at full compression and occasionally the pinch weld when stuffed and turning. I need to cut those back still. Can mounts are chopped and clear. Back of the fender flares have been butchered repeatedly with a hack saw blade. It seems like it doesn't end. If you don't wheel it at all the trimming will be muh less severe though. I don't get opportunity to wheel often but I don't like the tires rubbing when I do.
  11. Oct 3, 2011 at 8:42 PM
    sambojee
    Sam
    Iowa
    2011 TRD OffRoad
    Yea thats the problem, i do off-road and they cant rub
  12. Oct 3, 2011 at 8:50 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    Parker
    Birmingham, AL
    04 taco 4x4 TRD Debadged
    Shrockworks front bumper Shrockworks sliders Tacoma sport rims painted grey 285/70/17 BFG KM2 AEM cold air intake Grey wire mod Donahoe/Icon coilovers 4crawler 1'' BL CBI cutbed rear bumper Bud-Built skids Inchworm e-locker skid
    Just get in there with a sledge and start hammering shit :D
  13. Oct 3, 2011 at 8:52 PM
    907taco
    Bobby
    Alaska
    i was rubbing at 3" of lift with my 285's, KM2, 17 x 9 procomp 7089's, 0 offset and 4.5" back spacing.............see my above post.
