2.5 inch lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by eb99taco, Apr 28, 2024.
  1. Apr 28, 2024 at 9:37 AM
    eb99taco
    eb99taco [OP] New Member
    Eric
    1999 ext cab Tacoma sr5
    I’m going to be doing a 2.5 inch lift on my 99 ext cab. My leaf springs are sagging so I will be replacing them. Do I need to get new springs and an add a leaf or just the regular leaf springs, or is there a leaf spring that stock can accommodate a 2.5 inch lift?
  2. Apr 28, 2024 at 9:56 AM
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    Really depends on how much you are carrying...
  3. Apr 28, 2024 at 9:58 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    If you're getting new leaf springs I'd suggest just getting a pack designed to provide the amount of lift you're looking for. As far as I know there's really only about 3 options out there:
    1) OME Dakar Leafs - typically provide about 1.5" of lift
    2) Alcan Springs (custom leaf pack)*
    3) Deavers Springs (custom leaf pack)*
    *Both Alcan and Deaver can make custom leafs that will provide the amount of lift you want and they can provide added payload capacity. They are priced accordingly. I have Alcans and they're worth every penny.
    SpokeWench likes this.
  4. Apr 28, 2024 at 10:00 AM
    Red_03Taco
    Jerad
    A potential cost cutting option would be buying General Springs HD leaf pack, and pairing that with an add-a-leaf. I suspect you'd get at least 2" or so of lift (if not more), out of that, and it'd be probably still under $1000 for that plus all the ancillaries (extended rear brake line, new Unbolts, new shackles).
    This would probably ride like crap unladen, so keep that in mind.
  5. Apr 28, 2024 at 2:35 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    OME Dakar are rated at 2.25" of lift. If you have no bed weight they'll probably be closer to 3" and settle to 2.5".
