2.5 inch Spacer lift/33s
Discussion in '1st Gen. Tacomas (1995-2004)' started by ocaldwell332, Sep 26, 2016.
  1. Sep 26, 2016 at 12:59 PM
    ocaldwell332
    ocaldwell332 [OP] Well-Known Member
    Owen
    2004 Silver Tacoma V6 PreRunner
    I know this might get posted on here a lot but will a 2.5 inch lift clear 33x12.50r15? I've looked and can't seem to find a definite answer.
  2. Sep 26, 2016 at 1:41 PM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Physically yes, holistically no.
  3. Sep 26, 2016 at 1:57 PM
    ocaldwell332
    Owen
    And that means?
    520YOTA, Nimble9 and devinzz1 like this.
  4. Sep 26, 2016 at 2:05 PM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    It means you can physically fit the tires inside the wells but as a unit your trucks suspension will be far from operating properly.
    If you're set on doing it plan to spend a few extra dollars on beefing up all the adjacent systems on the front end.
  5. Sep 26, 2016 at 2:10 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    youl want wider wheels with less backspacing than the stockers. besides that you can fit them with no lift if you dont mind trimming the inner fender and the valance a little. (you should do this even with the 2.5" lift)
  6. Sep 26, 2016 at 2:11 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    You say you know it's been asked alot and yet you don't search? It's been asked a billion times
    digitaLbraVo and devinzz1 like this.
  7. Sep 26, 2016 at 2:38 PM
    ocaldwell332
    Owen
    "I've looked and can't seem to find a definite answer." If you would like for me to translate that for you it means that I've searched but everything I've seen is conflicting. You didn't have to read this thread or respond. I thought I prefaced it to avoid this but I guess it didn't work. Thanks for the input!
  8. Sep 26, 2016 at 2:39 PM
    ocaldwell332
    Owen
    So like a 15x10 instead of a 15x8?
  9. Sep 26, 2016 at 2:41 PM
    devinzz1
    devin
    2023 aclb trd or mt
    stock is 7" wide with about 4.5"bs. youl want atleast 8". 10" wide will be a bit harder to clear.
  10. Sep 26, 2016 at 2:43 PM
    ocaldwell332
    Owen
    Ok I've been looking at 15x8 didn't know if you meant wider than that. Thanks!
  11. Sep 26, 2016 at 2:49 PM
    devinzz1
    devin
    2023 aclb trd or mt
    to be honest this does get asked like every couple days. theres even stickies on the topic.
    youl have to do pinch weld mod and trim some even with a full 3" lift because the suspension will always compress and articulate so in reality NO 33s wont fit without modification (which is probably where alot of the confusion comes from). Dont panic is they rub a little after that. its nothing a BFH wont fix.
  12. Sep 26, 2016 at 2:51 PM
    ocaldwell332
    Owen
    Don't shoot me but BFH?
  13. Sep 26, 2016 at 2:52 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Big Fucking Hammer
    cruiserguy likes this.
  14. Sep 26, 2016 at 2:52 PM
    ocaldwell332
    Owen
    Ok I got you lol
  15. Sep 26, 2016 at 2:53 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Lmao, concise and to the point... You crack me up
    DustStorm4x4 likes this.
  16. Sep 26, 2016 at 3:02 PM
    devinzz1
    devin
    2023 aclb trd or mt
  17. Sep 26, 2016 at 3:03 PM
    ocaldwell332
    Owen
  18. Sep 26, 2016 at 3:07 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Don't think it has been mentioned but with that tire width and wheel unless your back spacing is at least 4.25"- 4" you will rub the uca pretty good.
  19. Sep 26, 2016 at 3:10 PM
    devinzz1
    devin
    2023 aclb trd or mt
    gona want even less with 12.5s. 3.75 or 3.5" should give decent clearance.
    FirstGen Jer[QUOTED] likes this.
  20. Sep 26, 2016 at 4:24 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    You don't have lie through your teeth. If you looked for even 10 minutes you would have found your answer 10 times over. There are stickies about it.
    But you didn't read them. Maybe the simple and organized information is too hard for your tiny brain to comprehend.
