2.5 inch strut spacer, will these tires fit?
Discussion in 'Wheels & Tires' started by alexxooo, Jul 13, 2011.
  1. Jul 13, 2011 at 9:56 AM
    alexxooo
    alexxooo [OP] Member
    hows it goin guys i just joined this forum, theres alot of good info on here! but anyways i have a 2000 tacoma 2wd 5 lug 4cy im about to order some new tires, rims and a leveling kit
    my stock tire size is 225-70-14
    with a 2.5 leveling kit would i be able to fit a 30x9.50 15 under there? i think it would be a preety tight fit. i called a guy at 4 wheel parts and he said i should have plenty of room lol, what do you guys think? thanks in advance
  2. Jul 13, 2011 at 11:32 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I generally believe the opposite of anything 4wp says.
  3. Jul 13, 2011 at 12:31 PM
    alexxooo
    yea lol, it was almost like he was just saying it would fit so he wouldnt have to help me out.
    i measured my wheel wells in the back and a 30 would fit on the back but im preety sure it would rub in the front even with the 2.5 inch spacer. the 225-70 stock tire is almost 4 inches smaller then the 30 inch tire so technically that spacer wouldnt allow enough room for the tire.
    whats a good tire and rim size for my application? again its a 5 lug 2wd 4 cyl stick shift any other help would be great
  4. Jul 13, 2011 at 12:48 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    22's on a 195/55/22 :O
  5. Jul 13, 2011 at 12:54 PM
    alexxooo
    hahah come on! that would be to much bling bling for me ;)
    i seriously cant find a tire smaller then the 30-9.5-15, my coworker thinks that this setup would work i think i might just get it and see what happens, hopefully they have a good return policy lol
  6. Jul 13, 2011 at 12:55 PM
    BlueTaco07
    Cody
    Looking
    Wait i thought you were running a 14?
  7. Jul 13, 2011 at 1:02 PM
    alexxooo
    the stock rim size is a 14. the tire i have on there right now is a 225-70-14
  8. Jul 13, 2011 at 1:03 PM
    BlueTaco07
    Cody
    Looking
    But your saying you want to know the biggest tire you can run with a 15 inch rim and 2.5 spacer?
  9. Jul 13, 2011 at 1:04 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    There are TONS of tires smaller than 30/9.5/15, where are you looking?
  10. Jul 13, 2011 at 1:04 PM
    BlueTaco07
    Cody
    Looking
  11. Jul 13, 2011 at 1:10 PM
    alexxooo
    oh woops kinda confused you, im getting new 15 inch steel rims. and yes i want to know the biggest tire i can fit under there with a 2.5 strut spacer.
  12. Jul 13, 2011 at 1:11 PM
    alexxooo
    im looking on 4wheelparts.com. i get dealer discount through the shop i work at
  13. Jul 13, 2011 at 1:11 PM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    There's actually a good chance they'll clear even without trimming, depending on what offset he ends up with.
  14. Jul 13, 2011 at 1:12 PM
    alexxooo
  15. Jul 13, 2011 at 1:16 PM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    You need to cut that 3.59 in half. 3.59 is the total difference, you will only see half of that height actually apply, so you're gaining less than 2" in tire height.
  16. Jul 13, 2011 at 1:19 PM
    alexxooo
    ohhhh sweet! thanks for the help guys! makes total sense. if i have to trim anything what would i trim? also what determines the offset?
  17. Jul 13, 2011 at 1:48 PM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    The offset is determined by whatever wheel you choose. What wheels and tires are you looking at?
    As far as trimming, it would be the lower corners of your bumper. I doubt you'll have to do much trimming though, if any, with 2.5" of lift.
  18. Jul 13, 2011 at 2:18 PM
    alexxooo
    im going with the 15x8 flat black steel rims with toyo AT 30-9.90-15. itll stick out about an inch or two.
    and sweeeet ill probly be ordering these up tomarow :) ill defiantly post pics in a new thread when its all done too!
  19. Jul 13, 2011 at 3:30 PM
    alexxooo
  20. Jul 13, 2011 at 4:43 PM
    TexasTacoma37
