2.5" Lift Tire Size Choices
Discussion in 'Wheels & Tires' started by WreckedRooster, Sep 26, 2019.
  1. Sep 26, 2019 at 12:33 PM
    WreckedRooster
    WreckedRooster [OP] Well-Known Member
    Jake
    Oklahoma
    2020 MGM DCSB
    Going to be installing the OME BP-51 kit soon. With the SPC adjustable upper control arms. From reading other threads, this will yield ~2.5" of lift, possibly a little more or less depending on pre-load settings. Do you think the following will fit:
    • 315/75R16 = 34.5"x 12.5"
    • 295/75R16 = 33.5"x 11.5"
    • 285/75R16 = 33"x 11"
    The 285's seem to be the tried and true method. Just wondering how big I can go with this kit and a 1/4" HS spacer?
    Vehicle specs:
    • 3rd Generation
    • Automatic
    • Stock gearing (can re-gear)
    • 16x8 wheels with 4" backspacing and -12 offset
    • ~2.5" of lift
    • SPC adjustable UCA's
    • Don't mind trimming (cab mount chop max)
  2. Sep 26, 2019 at 12:35 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Your tire sizes are off...
  3. Sep 26, 2019 at 12:37 PM
    WreckedRooster
    Jake
    Oklahoma
    2020 MGM DCSB
    whoops. fixed
  4. Sep 26, 2019 at 12:38 PM
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    depends on how much cutting you'd like to do
  5. Sep 26, 2019 at 12:39 PM
    WreckedRooster
    Jake
    Oklahoma
    2020 MGM DCSB
    Let's go on a scale of no cutting to cab mount chop.
  6. Sep 26, 2019 at 12:40 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Which gen truck? AT or MT? I'd stick with 285s if you are staying with stock gearing.
    strongrob and 2ndGenOffRoad like this.
  7. Sep 26, 2019 at 12:41 PM
    WreckedRooster
    Jake
    Oklahoma
    2020 MGM DCSB
    I'll update the original post. Should have had that info to begin with. Apologize. 3rd gen AT. Re-gear can be done.
  8. Sep 26, 2019 at 12:43 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    I assume you're gonna wheel the piss out of it if you're considering 35s. If you are regearing, go with 35s...but you'll have to cut/trim/chop a whole bunch.
  9. Sep 26, 2019 at 12:44 PM
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    CMC would be necessary for all three if you're offroading at all
  10. Sep 26, 2019 at 12:46 PM
    WreckedRooster
    Jake
    Oklahoma
    2020 MGM DCSB
    Okay, lets skip the 35's, I really hate playing the "where is it rubbing now" game. 285's seem safe with no real issues I can see. How about those 295's? Tire cost, there's only a $20 difference. Gives you an extra 1/2" both ways.
  11. Sep 26, 2019 at 12:48 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    What doesn't rub on 285s, may rub on 295s. It's the same game, see where it rubs, cut/trim/chop/remove. Honestly I wouldn't go any bigger than 285s on our trucks, due to heavier weight expediting wear and tear on your factory components. 33s look great on a Taco!
  12. Sep 26, 2019 at 1:23 PM
    WreckedRooster
    Jake
    Oklahoma
    2020 MGM DCSB
    I was under the impression that with the SPC's I can move the wheel forward enough to alleviate most, if not all of the rubbing. I live on a washboard dirt road that usually points out stuff fairly quick.
  13. Sep 26, 2019 at 1:32 PM
    WreckedRooster
    Jake
    Oklahoma
    2020 MGM DCSB
    Thanks for the information/advice fellas.
  14. Sep 26, 2019 at 1:36 PM
    2ndGenOffRoad
    2ndGenOffRoad Well-Known Member
    Los Angeles, CA
    '14 SBDC OffRoad 4x4 '84 4Runner 22RE
    Schmell Fab Sliders ATH Fab Rear Bumper Icon Stage 3 Suspension Front Runner Outfitters Roof Rack Softopper Bed Cover 285/70/17 KM3's on T4R Pro Wheels
    I have a 2.5" lift, running SPC's and 285's. I did the CMC and removed some plastic. They clear from rubbing all day. But i'm also a second gen...
    cubie and jeff b like this.
  15. Sep 26, 2019 at 1:37 PM
    WreckedRooster
    Jake
    Oklahoma
    2020 MGM DCSB
    Good looking truck you have there.
    2ndGenOffRoad[QUOTED] likes this.
  16. Sep 26, 2019 at 1:39 PM
    2ndGenOffRoad
    Los Angeles, CA
    Thanks man! I love it.
    Tacoma Mty.MX likes this.
  17. Sep 26, 2019 at 1:40 PM
    WreckedRooster
    Jake
    Oklahoma
    2020 MGM DCSB
    Your lights are blinding me! haha
    jeff b[QUOTED] likes this.
  18. Sep 26, 2019 at 1:42 PM
    WreckedRooster
    Jake
    Oklahoma
    2020 MGM DCSB
    Found this (see quote above) in a 295/75R16 thread for a gen 2 with 3" of lift. Shines some light on what I would be in for trying to go with that size.
  19. Sep 26, 2019 at 1:49 PM
    2ndGenOffRoad
    Los Angeles, CA
    Yeah, wheel offset has everything to do with it as well. My T4R pro wheels have 0 offset, again no rubbing. And I'm running KM3s which are a bit beefier then most 285s
    TrailYeti likes this.
  20. Sep 26, 2019 at 1:58 PM
    WreckedRooster
    Jake
    Oklahoma
    2020 MGM DCSB
    Do you have your lift specs to share?
