2.5 spacer ride vs Bilstein 5100 at 2.5
Discussion in 'Suspension' started by MojoOffRoad, Apr 15, 2017.
  1. Apr 15, 2017 at 4:37 PM
    MojoOffRoad
    MojoOffRoad [OP] New Member
    2007 Tacoma DBCLB
    2.5 Inch front spacer lift and 2 inch rear block with Zone Shocks
    Wanna know how different the ride quality will be cause my spacer right now rides like a rock
  2. Apr 15, 2017 at 4:40 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Pretty similar, probably - they're both preloading the coil the same amount.
  3. Apr 15, 2017 at 4:42 PM
    MojoOffRoad
    2007 Tacoma DBCLB
    The spacer doesn't preload at all, a preloaded spacer does, this is a spacer on top of the stock set up you could also call a Strut Extention,
  4. Apr 15, 2017 at 7:01 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Its not causing the rough ride. You need better shocks and/coils.
    Tacomas don't have struts. :pccoffee:
  5. Apr 15, 2017 at 7:40 PM
    MojoOffRoad
    2007 Tacoma DBCLB
    But as soon as you ride in Tacoma when spacer is removed with same shocks and coils it rides nice and soft
  6. Apr 15, 2017 at 8:58 PM
    Justinlhc
    No, it doesn't. I seriously doubt you have actually done that and had the vehicle properly aligned before and after.
    Take the spacers out if you're sure they're creating this rough ride issue. Problem solved.
