2.5" wanting to go to 3" up front
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 757southpaw, Feb 24, 2011.
  1. Feb 24, 2011 at 8:55 AM
    757southpaw
    757southpaw [OP] Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    So I'm looking for some feedback as to what I should do to achieve 3"'s of lift up front utilizing the 5100's @ 2.5" I already have installed. My thoughts are to by new coils and set the billies back to 0 but not too sure which ones to get. I also still have the OEM billies in the shed as well What say you TW?
  2. Feb 24, 2011 at 8:55 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    885 coils and 5100s?
  3. Feb 24, 2011 at 9:02 AM
    757southpaw
    Jay
    757
    Nice wheels man! Can I use the the top and bottom plates with the 885 coils?
  4. Feb 24, 2011 at 9:03 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    you sure u wanna put that much angle on your CV axles?
  5. Feb 24, 2011 at 9:06 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    I run the OME shocks and OME 885s with a spacer - 20k miles and CVs are going strong.
    Not sure on the OME spring and 5100s for total lift though - do a search. I'm pretty sure there is all sorts of info on that..
  6. Feb 24, 2011 at 9:06 AM
    757southpaw
    Jay
    757
    Wouldn't think so but I've got the diff drop.
  7. Feb 24, 2011 at 9:19 AM
    757southpaw
    Jay
    757
    Search result indicates that it's not what I need.
    Old Man Emu Front Coils (2)/ FJ Cruiser Tacoma 4Runner (OME2885)
    THIS IS A SET OF 2 COIL SPRINGS
    Springs are formed on precision mandrels. Scragging before and after shot peening to prevent sagging, Cesigned to exact specifications guaranteeeing perfect fit to your vehicle. OME front coils can only be installed with OME nitrocharger struts and coils seats. Approx. lift 2.0 inches. (PIC SHOWS 4 SPRINGS BUT THIS IS A SET OF 2 COIL SPRINGS) THESE FIT FJ CRUISER (heavy load 70-180lbs) & TACOMA (stock/light load 0-110 lbs), AND 2003-2011 4RUNNER (Medium Load 70-180lbs).
    For vehicles with KDSS, you MUST also put in the OME95PF5 trim spacer on driver side to maintain correct trim.
  8. Feb 24, 2011 at 9:21 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    I love the way my 5100's set at 0 with the 885x springs ride. But you are not going to get 3" out of this setup with a 4x4 Double Cab Long Bed. With my Access Cab prerunner I get slightly over 2.5". I would expect you to get 2.25" of lift. If you got some 1/2 top plate spacer it should get you pretty darn close to 3".
  9. Feb 24, 2011 at 9:24 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You can run a 1/4" thick top-plate spacer on the the billy's. That will give you an extra 1/2" of lift, and it's only $20 or so.
  10. Feb 24, 2011 at 9:32 AM
    757southpaw
    Jay
    757
    Isn't this top plate spacer used to adjust for the taco lean on the driver's side? Also does it install between the top of coil and top-plate?
  11. Feb 24, 2011 at 9:36 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    That's a CYA statement by ARB because they have never officially tested the OME coils on Billies. Several members have run them without issue.
    That's if you are at stock height and only put the one in on the driverside. But yes they are the same.
  12. Feb 24, 2011 at 11:15 AM
    KPT
    09 Prerunner
    Yes but if you use one on each side, it will lift both sides 1/2". Similar to the OME setup.
    And you shouldn't have too bad of a taco lean if you are using the stock coils because the drivers side coil is stiffer than the passenger side.
  13. Feb 24, 2011 at 11:23 AM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    this is easiest and cheapest way to do it.
    I have 5100's set at .85 with 884's. sits a little over 3", but i also have Camburg uca's and no cv's to worry about.
  14. Feb 24, 2011 at 12:36 PM
    757southpaw
    Jay
    757
    So are the 884's producing most of the lift assuming you aren't using the 1/4" spacers?
    Edit: Hold on, I see conflict. Do you have 884's or 885's?
  15. Feb 24, 2011 at 12:46 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    884's no top spacer.... the thing under my avatar is a typo, if thats what your referring to. too lazy to fix it :D... the 884's a lone provide about 2.5" so i set the bilstein's to .85, but you would want 885's since your a DC
  16. Feb 24, 2011 at 12:49 PM
    757southpaw
    Jay
    757
    Gotcha. How's the ride!
  17. Feb 24, 2011 at 12:53 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    the front rides silky smooooth :D... but the rear rides like shit cause its still stock. i plan on fixing that soon with Icon AAL's and Fox shocks though.
  18. Feb 24, 2011 at 3:36 PM
    757southpaw
    Jay
    757
  19. Feb 24, 2011 at 3:39 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Add top plate spacer or replace with eibach or OME coils
  20. Feb 24, 2011 at 3:44 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    we already told you your options to achieve a full 3" with 5100's. only other way is to go all out and buy coilovers.
