2.5in or 2.0in shocks in the rear?????
Discussion in 'Suspension' started by Country, Apr 21, 2011.
  1. Apr 21, 2011 at 5:59 PM
    Country
    Country [OP] Well-Known Member
    Country
    East Texas
    2010 Dbl.-Everyone says it looks like a tank
    Pro Comp 6in lift w/ Icon Coilovers,AllPro UCA's, AllPro Baja Leaf pack, Bilstein 5150's in the rear. Tires Mickey Thompson MTZ 275/70R18 w/ procomp 7089 wheels. ARB front bumper with mile marker winch, Custom made all quarter inch steel rear bumper. Demello rock crusher slider's. CoverKing neoprene seat cover's, AllPro trail armor All-pro U-bolt flip kit with Timbren bump stops and many many many other mods, way to many to list.
    I am buying new shocks for my 2010 dbl cab Taco, it is lifted 6in and I need new shocks for the rear, I need to know which size shocks will help give me a better ride in the rear so it doesnt bounce around as much. Any help with this will be much appreciated. Thanks
  2. Apr 21, 2011 at 6:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    2" shocks will be fine. If you off Road much, and run fast the 2.5's would be better...
  3. Apr 21, 2011 at 6:04 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    I always ride a half inch less in the back then the front so it levels out instead of slumping more forward
  4. Apr 21, 2011 at 6:10 PM
    Country
    Country
    East Texas
    I am talking about the shock tube size not the actual lift in the rear
  5. Apr 21, 2011 at 6:11 PM
    BlueTaco07
    Cody
    Looking
    Ohhhhh my bad miss reading
  6. Apr 21, 2011 at 6:13 PM
    Country
    Country
    East Texas
    Thanks dude, now for another question, I dont have spacers in the rear, since I have leaf packs that are made for a 6in lift, will I need to have the shocks made longer so it will fit the 6in's of lift in the rear.
    Also I still have my 6in spacer's in the front will I also need those extended as well. My end goal is to have a true suspension lift and take away the front spacer's. Thanks
  7. Apr 21, 2011 at 6:15 PM
    Country
    Country
    East Texas
    Its cool dude, happens to us all :D
  8. Apr 21, 2011 at 6:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your not going to have a "True" 6" suspension lift, unless you go long travel, or SAC. You have a drop bracket lift, so you are going to have to find shocks that are suitable for the lift kit you have.
  9. Apr 21, 2011 at 7:02 PM
    Country
    Country
    East Texas
    I was gonna get evan walker's shocks from all pro.
    But will I be able to completly remove my spacers if the shocks can be extended?
    what is an SAC?
    And what about the rear do I need to have those extended as well since I dont have spacers anymore?
    Thanks for the help dude.
  10. Apr 21, 2011 at 7:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The Walker Evans Co's are kinda on the low end. Better options are out there for not much (if any) more money. Yes, you will need to get teh rear shocks sized accordingly.
  11. Apr 21, 2011 at 7:05 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Rear shock, You'll need to get a shock specific to the length you need. You can't really get shocks lengthend, or if you can it would still be cheaper just to buy the right size.
    As for 2" or 2.5", if your talking about the same shock in 2 different sizes, htye should be valved about the same, the 2.5 could very well be firmer though. Generally the 2.5 just has a bit more surface area and fluid to help dissipate heat and so the dampening won't fade out as quickly in hard/fast runs. The 2" will be plenty, still much beefier than the stock shocks.
    As for the front, I'm just confused. 6" spacer? Are you sure it's not a drop-bracket style?
    Edit: what Chris said^
  12. Apr 21, 2011 at 7:22 PM
    singlefin
    singlefin Well-Known Member
    Hood River, OR
    Syncro
    Your gonna need to determine the length shock you want. Measure flexed eye to eye for compressed and extended. Then call DSM or a local off-road shop and see what they suggest in regards to model and valving. King, Fox, and Bilstein all make smooth body shocks an various applications. Total Chaos makes an adapter to run a eyelet to a stem.
    For you 6" lift, on DSM's page King has an option for a fabtech and procomp lifts (assuming thats the 6" stuff).
    http://downsouthmotorsports.com/i-1...05-2010-toyota-tacoma-4wd-2wd-pre-runner.html
  13. Apr 22, 2011 at 8:40 PM
    Country
    Country
    East Texas
    Ya I have a Pro Comp 6in lift, I guess I will have to go with Kings if I wanna getaway from those damn spacers, what about the rear? what type of shocks should I go with there? Thanks
