2.7 2wd to 4wd??
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gabriel Lemus, Mar 23, 2023.
  1. Mar 23, 2023 at 10:43 PM
    Gabriel Lemus
    Gabriel Lemus [OP] New Member
    Hey guys im new to the whole tacoma scene, recently picked up a 2002 2.7 4door 2wd tacoma.
    I wanna be able to take it off road so i was wondering if anyone knows if its possible to do a 4wd conversion, its a 6 lug
    Area51Runner and Yota X like this.
  2. Mar 23, 2023 at 10:50 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Welcome! Tip, go to Google type “2nd to 4x4 conversion Tacoma first gen tacomaworld” and you will get hits. The search engine in the forum it’s kinda mmmmm not that good.
    Gabriel Lemus[OP] likes this.
  3. Mar 23, 2023 at 10:54 PM
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    Are you a good mechanic and a decent fabricator?
  4. Mar 23, 2023 at 11:21 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    Possible? Yes. Easy and cost effective, no. If you really want 4wd I'd probably consider another truck unless you want to do something custom and money is no object.
  5. Mar 23, 2023 at 11:37 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Welcome to the forum !!
    Find a donor Truck it is a simple bolt on swap .A donor gives you all the parts in one package .
    Unless your mechanically Challenged it is a remove and replace grunt work job.
    Many have done this.
    Depending where you live a rusted out frame Tacoma donor might be a easy find.
    Always make sure to insure things work before starting.
    If you were close .
  6. Mar 24, 2023 at 5:51 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    You should read around the 1st gen section more. Many have completed this project, it’s more cost effective than you think. The hardest part is finding the parts…but if you do, it’s basically bolt on.
    @Gabriel Lemus
    Here’s some reading:
    https://www.tacomaworld.com/threads/4x2-to-4x4-conversion.779681/#post-27878669
    https://www.tacomaworld.com/threads...dicator-light-and-a-t-p-neutral-light.783875/
    https://www.tacomaworld.com/threads/4wd-swap-how-to-transfer-case-vss-speed-sensor-options.786403/
  7. Mar 24, 2023 at 6:03 AM
    Clearwater Bill
    Billy
    Largo Florida
    Curious why you would buy what you didn't really want? Screaming deal? Gift?
  8. Mar 24, 2023 at 6:52 AM
    Bivouac
    Perhaps the lust for off road exploring was brought about after the truck was in hand.
    Curious to know as well?
    Gabriel Lemus[OP] and Cucvfan like this.
  9. Mar 24, 2023 at 8:55 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    All the information you need has been posted here on TW and there are enough youtube videos out there that will certainly cover the majority of the work. I have a post here which has multiple links to content here on TW and lays out a few points to get you started.
    Make sure you take a look at this thread -
    https://www.tacomaworld.com/threads/4x4-conversion-2-7-doublecab.784492/
    Be aware hunting for the parts will take the most time. Prices have gone up over the last few years so it will cost more but you can still do it on a budget. Might take a bit longer - that's all.
    Will close with this -
    Don't let anyone tell you that you should just go buy a 4WD, it's too much money, you can't do it or it's a waste of time/resources. You want to do it, DO IT.
    Cheers and happy wrenching!
    :cheers:
  10. Mar 24, 2023 at 8:59 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    If you are doing the work yourself you MIGHT break even. Otherwise it is cheaper to sell what you have and buy what you want. I'd only consider it if I'd inherited the truck from grandpa and it had sentimental value.
  11. Mar 24, 2023 at 9:20 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    If you buy part by part its gonna eat you alive......
    certain older hard to get parts are sky high, highly inflated.
    Buying a donor truck would be best bet.....
    .....you should of waited and shopped a little longer and got what you really wanted.
    Now your gonna have to buy two trucks to make one.
    You could always try to run an ad....find someone who needs a daily driver with 4x4 that wants something better than 14mpg.....and avoid the other maintenance problems and expense....
    that's reasson I call em 4X$'s.......
  12. Mar 24, 2023 at 11:43 PM
    Bivouac
    I would love to see the numbers from your experiences.
    I had tried to sell my paid for 2000 Prerunner the difference that I could have sold it for and buying a 4x4 ( same vintage) was several thousand dollars I did not have to spend.
    I bought a donor for $500.00 4x4 5 speed 3.4
    I added new parts as needed so for less then $1000.00 cash spent I now had a viable 4x4 plus extra parts.
    By my accounting I came out several Thousand dollars ahead plus I know just what I have.
    Yes regional markets do vary quite a bit . Prices have increased across the board so have the 4x4 prices.
  13. Mar 25, 2023 at 5:02 AM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Bivouac likes this.
  14. Mar 25, 2023 at 11:00 AM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Best way to do it is to by a parts truck with everything you need. Part out the rest. If you are not mechanical and need some one to install the 4x4 parts pay them with the profit from selling extra parts.
    Gabriel Lemus[OP] and Bivouac like this.
  15. Mar 25, 2023 at 1:35 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I don’t think I ever finished my write up haha. I’ll answer any questions tho
  16. Mar 25, 2023 at 1:38 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    My whole conversion costs +/- $1,500. I made money back after selling my 2WD components. It’s not as hard nor difficult as people make it seem.
    If I could do it as a clueless 17 year old years ago, you can do it too.
    Yota X, Gabriel Lemus[OP] and Bivouac like this.
  17. Mar 26, 2023 at 10:16 PM
    Gabriel Lemus
    thanks for the links!
  18. Mar 26, 2023 at 10:19 PM
    Gabriel Lemus
    it used to be my dads, was is rough shape he said i can have it as long as i fix it up. im picking it up from the paint shop tomorrow, i fixed any problems it had under the hood, im looking into fixing up the transmission thats why im making this post, deciding if i should fix the current one or just go for a 4x4 conversion
    Bivouac and Area51Runner like this.
  19. Mar 26, 2023 at 10:20 PM
    Gabriel Lemus
    it was passed down to me, im fixing it up in hopes to be able to take it off road some day
    Bivouac[QUOTED] likes this.
  20. Mar 26, 2023 at 11:41 PM
    tacothuy
    tacothuy New Member
    can a 2000 4 runner 4x4 parts be used to convert a 2004 Tacoma crew cab two-wheel drive into a four-wheel drive?
