2.7 3rz supercharger kits
Discussion in 'Performance and Tuning' started by smmarine, Mar 14, 2016.
  1. Mar 17, 2016 at 6:45 AM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    i cant say this with 100% certainty but im gonna say yes. i dont remember having to do anything out of the ordinary to get them on.
    smmarine[QUOTED][OP] likes this.
  2. Mar 18, 2016 at 3:54 AM
    smmarine
    smmarine [OP] Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    You know what kind of mpg you were seeing with your supercharger setup?
  3. Mar 18, 2016 at 5:49 AM
    mjbtaco
    Michael
    Montclair , so cal
    Wouldn't be comparable since I was running a larger fuel pump and 440 injectors. Also drove it like an asshole so it wasn't good lol
  4. Mar 18, 2016 at 7:21 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  5. Mar 18, 2016 at 4:07 PM
    smmarine
    Melbourne FL
    mjbtaco likes this.
  6. Apr 4, 2016 at 1:14 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    My 2002 double cab 2wd pre runner has a 3RZ 4 cylinder and running the 2nd gen " black case" TRD low boost 4.5 supercharger . Along with a K&N CAI , Doug Thorley header and Gibson cat back it runs very well
    You can really hear the blower once it's making boost and even and low idle rpm you can tell it's a blown motor LOL!!!! . I think I'm putting out close to 255hp with those minimal mods
    I'm looking at making more boost with a 8lbs pulley but with Calif smog laws not sure it will be legal . I like what I'm reading though about some of you getting away with just a aftermarket fuel pump and pink injectors
    As for fuel mileage last tank with mostly city driving I got 15.8mpg and that was with the transmission power mode on
  7. Apr 4, 2016 at 4:07 AM
    smmarine
    Melbourne FL
    Sweet
  8. Apr 4, 2016 at 4:25 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    That's a misconception. The turbo can be sized for instant boost if that's what you want. Turbo is a more efficient and effective method for boost and cheaper too.
    http://www.ozboost.com.au/product/3rz-turbo-kit/
  9. Apr 4, 2016 at 7:34 AM
    smmarine
    Melbourne FL
    Eh, I don't feel like dealing with oil lines etc. I'm just after a little more oomf on the bottom end. If I had goals of massive hp, turbo not doubt. But just something to add a bit more torque, and easier to bolt on, I'll go supercharger.
    black coffee likes this.
  10. Apr 4, 2016 at 12:17 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    You'll definitely like the supercharger even if it's only the low boost set up , that alone will get you just over 200fwhp
  11. Apr 4, 2016 at 3:51 PM
    smmarine
    Melbourne FL
    Yeah, I'm gonna do supercharger and a header
  12. Apr 4, 2016 at 4:30 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Do a K&N CAI and a good flowing cat back and you should be just over 250 fwhp with the 4.5 pulley . Going with a 8lbs pulley you'll be well over 300fwhp
  13. Apr 6, 2016 at 2:49 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    I've got pink injectors so if I go up to a 8psi pulley from my 4.5 psi set I should be fine , I'm running the stock fuel pump
    I'm not going to be racing or beating on it just looking for more hp . Also any idea on power increase from 4.5psi to 8psi , could I easily get well over 300 hp ???
    EDIT ....
    Never mind just found out the Aeromotive A340 Stealth pump is 89gph and the stock pump is 33gph but both are capable of 90psi
    Looks like I will need to install the Aeromotive pump to keep up with fuel demand
  14. Apr 10, 2016 at 4:09 PM
    smmarine
    Melbourne FL
    LCE states their 8psi kit makes 217-225hp
  15. Apr 10, 2016 at 4:11 PM
    #35
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    I'm running the SC for the 2.7l
  16. Apr 10, 2016 at 6:15 PM
    #36
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    This isn't a supercharger from LCE , this is a gen 2 (black case) supercharger from TRD mfgd by Magnuson
    Should be 35-40% increase .... 217 - 220hp
    Add ...
    Doug Thorley header ... 20hp
    High flow cat & Gibson cat back ....15-20hp
    K&N CAI set up ..... 10 hp
    So about 250hp plus
    Torspd likes this.
  17. Apr 10, 2016 at 6:51 PM
    #37
    smmarine
    Melbourne FL
    The LCE supercharger is the same as what you have. LCE bought the rights to it. I'm not sure the header, exhaust, and K&N are doing much for you. The stock exhaust and intake on these trucks are pretty good. I'd have to see dyno sheets.
  18. Apr 10, 2016 at 6:52 PM
    #38
    smmarine
    Melbourne FL
    What do setup?
  19. Apr 10, 2016 at 7:16 PM
    #39
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    LCE recommended that I go with the Doug Thorley header since I'm running a power adder such as a supercharger . The tech @ LCE told me I would see very noticeable gains in hp & torque . He also mentioned after a talked with him that K&N CAI compliments the supercharger and will get more air into the motor to make more hp
    Bmann88 and Torspd like this.
  20. Apr 11, 2016 at 5:20 AM
    #40
    smmarine
    Melbourne FL
    It'd be interesting to see it on a dyno. I know for N/A trucks, exhaust and intake does nothing.
