2.7 3rz supercharger kits
Discussion in 'Performance and Tuning' started by smmarine, Mar 14, 2016.
  1. Apr 17, 2018 at 7:23 AM
    #101
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    I think for a DD with 31s doing a lot of highway driving I would be better off with the 4.10s. The same housing would work you think so I can just swap out the Ring/pinion? or do I have to get a full front/rear axle assy.
  2. Apr 17, 2018 at 7:40 AM
    #102
    smmarine
    smmarine [OP] Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    4.10s in your truck will put your rpm at 70mph at just over 2600rpm. 4.56 would be just over 2900rpm. For 31s I would probably stick to 4.10s but if you think you ever want to go larger, maybe 4.56 is the way to go. You can just do ring and pinion swap. East Coast Gear Supply can get you set up.
  3. Apr 17, 2018 at 8:01 AM
    #103
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    With 31's, I would try to find a set of OEM 4.30's. The closer you are to 3k rpm on the freeway, the more powerful the 3rz will be. Either way though, the gears will make a big difference. Also, you can correct your speedo with a Dakota Digital sgi-5e. I used one on my truck and it reads perfect now.
  4. Apr 17, 2018 at 8:10 AM
    #104
    Russianman92
    Dunwoody GA
    Talked to ECGS and the guy said I got a "reverse clamshell" for the front which is odd since the site says its for 05+ tacomas. Regardless if that is the case and I actually have that style they do actually sell a 4:30 ratio as well. Waiting for him to email me the links to the parts he described so I can price it out.
    boostedka likes this.
  5. Apr 17, 2018 at 8:17 AM
    #105
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Throw a TruTrac in there as well, if it is in the budget. Since you're pulling it all apart.
  6. Apr 17, 2018 at 8:20 AM
    #106
    Russianman92
    Dunwoody GA
    Nothing is truly "in the budget" LOL....I do suffer a very serious case of "While I'm In There" syndrome. So I may have to look at it.
  7. Apr 17, 2018 at 9:50 AM
    #107
    smmarine
    Melbourne FL
    Or a diff locker :D
  8. Apr 17, 2018 at 9:51 AM
    #108
    smmarine
    Melbourne FL
    Yeah the front diff is the 7.5” clamshell style
  9. Apr 17, 2018 at 9:54 AM
    #109
    smmarine
    Melbourne FL
    Honesty I think 4.10s would be fine with the 5 speed and 31s. Your final rpm will be 2600 at 70mph. Maybe if you plan to run 33s go 4.30.
  10. Apr 18, 2018 at 7:18 AM
    #110
    Russianman92
    Dunwoody GA
    Yea 5th gear 70mph Im sitting at 2450 RPM currently and in 4th at 3K RPM.
  11. Apr 18, 2018 at 7:20 AM
    #111
    Russianman92
    Dunwoody GA
    @smmarine and I would have to get a new carrier for the rear I'm pretty sure. The front is fine, according to the parts diagram the front carrier stays the same but there is a different part number between the the 2 pinion/ring sets....however for the rear...it looks like the carrier and pinion as an assembly are different part numbers between the 2.
  12. Apr 18, 2018 at 11:58 AM
    #112
    smmarine
    Melbourne FL
    I’m don’t really understand what you’re getting at.
  13. Apr 19, 2018 at 4:32 AM
    #113
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  14. Apr 19, 2018 at 8:04 AM
    #114
    Russianman92
    Dunwoody GA
    @Torspd
    If I'm gonna do it I would do high boost and call it a day. I'm building a new motor with all forged internals at the moment.
  15. Apr 19, 2018 at 8:28 AM
    #115
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Where is all of the eye candy man?!?!?!
  16. Apr 19, 2018 at 8:39 AM
    #116
    Russianman92
    Dunwoody GA
    Haha I have it disassembled at the moment bagged up and I'm soda blasting all the parts before I send them off to the machine shop. Haven't ordered a single part as of right now as I am cleaning everything. I'll post some pics up when I have a chance for sure ;)
    I am in the middle of disassembling an N26 BMW 2.0 Turbo motor (timing chain failure) which is taking up my engine stand and time as well as I am seeing if I can salvage it. No smashed valves so that's a start. Once I'm done with this one I'll be back on my 3RZ.
    P.S. The 3RZ out of my truck has 310K miles on it....and I can STILL see all the cross etching from the honing on the cylinder walls. Virtually no wear at all. Impressive if you ask me.
  17. Apr 19, 2018 at 8:50 AM
    #117
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Lucky on the N26. I had to replace every exhaust valve on my M52.
    The 3rz is a beauty of masterful engine building. Very little mods and can make gobs of power. Can't wait to see where your build goes.
    My close friend just picked up a 3rz Tacoma. Big plans in the works to handle the high boost kit as well.
  18. Apr 19, 2018 at 8:58 AM
    #118
    Russianman92
    Dunwoody GA
    That blows! Well the funny thing is nobody has done a rebuild on this motor as of yet (N26). These are JUST coming out of warranty and blowing up so even TIS doesn't have any torque specs or guides on how to rebuild it. Also, the Bentley manual lacks a lot of stuff as well. They expect you to take it to the dealer.
    I love the 3RZ. Just needs a little help to get a little more ass. LCE makes good build kits. I'm not doing anything crazy I am essentially building it for a bulletproof NA build so that if I wanted to SC it I will have 0 issues/concerns no matter how much boost I throw at it. I am planning on doing a full restoration on that truck in the future to get it to as factory as possible with a few upgrades that you can't see. Thing was built in 06/95 and I'm the second owner with all original paperwork so I want to keep the originality. Hence the lack of winch/armor setups.
    Torspd[QUOTED] likes this.
  19. Apr 19, 2018 at 4:02 PM
    #119
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I have yet to get mine to really have any punch, it has its moments here and there with the SC on but I still don't feel much punch. Still waiting for the ECU to do whatever it thinks it has to do. I did make an oil leak though haha, crankcase pressure definitely went up a wee bit.
    Russianman92[QUOTED] likes this.
  20. Apr 19, 2018 at 4:18 PM
    #120
    smmarine
    Melbourne FL
    Clutch fan on mine sucks up power. With the supercharger the under hood temps skyrocketed, and the clutch fan almost always engages at a stop in the summer time. And it sucks up a lot of power.
