2.7 3rz supercharger kits
Discussion in 'Performance and Tuning' started by smmarine, Mar 14, 2016.
  1. Apr 19, 2018 at 4:21 PM
    #121
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I could see that, it's like 80 today in Phoenix. I still like the extra power for sure. I'm just not sure if my SC is healthy or not. Gotta get a better boost gauge and clean up my intake since it is still stock.
  2. Apr 19, 2018 at 4:30 PM
    #122
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Hers a couple pics of one I made recently. It pretty simple and was pretty cheap. I kind of wish I would have painted it black. I also moved the crank breather to t into the big vac line that runs to the Intake box.
    02-5Lug and ChadsPride like this.
  3. Apr 19, 2018 at 4:34 PM
    #123
    Speedytech7
    Huh I don't have that huge vac line, I only have the plug on the airbox. But I could really use one of those pipes. What size of pipe and what was the angle of the bend?
  4. Apr 19, 2018 at 4:58 PM
    #124
    boostedka
    James
    NM
    3” 45*
    Used a 3” hump hose coupler at the air box since it’s a weird angle. I used a 3” to 2.75” coupler at the TB
    Russianman92 likes this.
  5. Apr 20, 2018 at 6:42 AM
    #125
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    I'm sure there's a way to put in electric fans.
  6. Apr 20, 2018 at 2:06 PM
    #126
    smmarine
    smmarine [OP] Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Is that a water/meth tank?
  7. Apr 20, 2018 at 2:07 PM
    #127
    smmarine
    Melbourne FL
    There is. LCE sells a kit for $400
  8. Apr 20, 2018 at 4:50 PM
    #128
    boostedka
    James
    NM
    It’s just a washer reservoir. I do, however, have a snow meth kit for it that will go on once I get time to install the 58mm pulley.
  9. Apr 21, 2018 at 2:19 PM
    #129
    smmarine
    Melbourne FL
    Nice. I’d really like to turn up the boost and install water/meth, but idk If I want to get into tuning.
  10. Apr 21, 2018 at 4:45 PM
    #130
    boostedka
    James
    NM
    Meth is supposed to be pretty easy. Talked to the guy with the 500k mile 3.4 about it and is seems pretty simple from what he said. I’ll let you know how it goes once I get it on to hopefully help you decide
  11. Apr 21, 2018 at 4:46 PM
    #131
    Speedytech7
    So is your truck SC or turbo now?
  12. Apr 21, 2018 at 4:47 PM
    #132
    boostedka
    James
    NM
    I recently bought a different truck that has a s/c already installed on it.
    Speedytech7[QUOTED] likes this.
  13. Apr 21, 2018 at 4:49 PM
    #133
    Speedytech7
    Neat, since you have the perfect mockup vehicle is there anyway I can bribe you to make one of those intake pipes for me. No one around me has a mandrel bender so getting a 45° ends up too kinked :/
  14. Apr 21, 2018 at 5:05 PM
    #134
    smmarine
    Melbourne FL
    I’d love to throw on the 10 psi pulley with a water/meth kit. It’d make the truck run amazing
  15. Apr 23, 2018 at 7:02 AM
    #135
    Russianman92
    Dunwoody GA
    Right, but if you go to the Supercharger page it says:
    WARNING!
    **Will not work with LC Engineering underdrive crankshaft pulley.**
    **Will not work with electric cooling fan. **
    Guess what I am saying is I am sure you can make it happen.
  16. Apr 23, 2018 at 8:43 AM
    #136
    smmarine
    Melbourne FL
    It says that idk why it wouldn’t. There’s plenty of clearance. In actuality, there’s probaly more clearance with the electric fans, cause you couldn’t slip a hair between my supercharger idler pulley and my fan blades.
    Speedytech7 likes this.
  17. Apr 23, 2018 at 9:56 AM
    #137
    boostedka
    James
    NM
    I can't find Mandrel Bends here either. I've ordered them in the past from Columbia River, but since I only needed one this time, I just bought this one from eBay: https://www.ebay.com/itm/3-45-304-S...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    Then I just drilled a hole on the side for the IAC connection. For this one, I used a copper threaded 90* fitting, but for the turbo IC piping I chopped the small pipe off of the stock intake and welded it on. If you're not able to make one, just lmk and I could probably do one for you.
    That's what I'm hoping! Hopefully I'll get some time in the next couple weeks to get it set up.
  18. Apr 23, 2018 at 10:07 AM
    #138
    Russianman92
    Dunwoody GA
    Well in that case IDK why...you keep the waterpump pulley on anyway. I can always ask the reasoning.
  19. Apr 23, 2018 at 10:13 AM
    #139
    smmarine
    Melbourne FL
    :pccoffee:
  20. Apr 25, 2018 at 3:06 PM
    #140
    Texasdynaryder
    Texasdynaryder Well-Known Member
    Chance
    Paris, Tx
    Kings Built Engine All the other small goodies
    I have Yota 1 building me an engine right now with hopes of LCE Low Boost here pretty soon. NICE Setup!
    boostedka[QUOTED] and Torspd like this.
