2.7 3rz supercharger kits
Discussion in 'Performance and Tuning' started by smmarine, Mar 14, 2016.
  1. Apr 25, 2018 at 5:11 PM
    #141
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Nice! Turbo or S/C?
  2. Apr 25, 2018 at 7:59 PM
    #142
    Texasdynaryder
    Texasdynaryder Well-Known Member
    Chance
    Paris, Tx
    Kings Built Engine All the other small goodies
    S/C more than likely. I want to turbo but don’t want to headache of tuning plus I DD mine. I’m having a fully ported F1 Head with SS valves and Stage one cam all installed with 10-1 Forged pistons all balanced.
    My end game is to park this and long travel for fun. But we all know how that goes lol
  3. Apr 26, 2018 at 4:19 AM
    #143
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    S/C and Turbo are both F/I... proper steps to have the engine run correctly is needed for both. Best "Pro" with turbo over the S/C, is that it gets and intercooler. Whereas the S/C doesn't.
    Even if only following the defficient status quo of just adding injectors, a fuel pump, and no tuning, then you'll at least have cooler charge air than with the s/c.
    Whichever is chosen, protect your investment with some form of tuning, and method of cooling the charge air, to prevent knock.
  4. Apr 26, 2018 at 6:13 AM
    #144
    Texasdynaryder
    Chance
    Paris, Tx
    In the diesel world where I live a lot. The tuning is so much more simple to me. Rail pressures, Timing, Boost, Drive Pressure, and EGTs can be documented so much more easily. No need for stand alone units etc etc. With that being said, On our trucks once you fabricate, add, build the harness, get everything talking it becomes a little bit easier if you know what you are looking at. Just call me lazy lol
    I still haven't kicked out the idea of a low boost turbo but with armor and such you are run out of real estate fast for intercooling.
  5. May 9, 2018 at 6:11 AM
    #145
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Man I was looking for a way to replace the stock rubber hose since mine was cracking from age. I ended up just getting a stock replacement, but maybe I'll do this in the future. With a stock setup I'd still need to connect the FPR to something since it connects to the resonator box thing on the stock intake. What size copper fitting did you use for the IAC connection?
  6. May 9, 2018 at 7:00 AM
    #146
    boostedka
    James
    NM
    I don't remember for certain off the top of my head. I want to say it was about 1/2", though. I essentially just took the IAC hose to Lowe's and looked for a 90* fitting that fit inside of it. If I had a stock intake to use, I would have liked to have just cut off the stock IAC tube and welded it onto the intake pipe.
  7. Jan 17, 2019 at 6:27 PM
    #147
    02-5Lug
    02-5Lug Active Member
    Christian
    Gainesville, GA
    2002 xtra cab 2RZFE 5sp
    I am so stealing your idea for this intake.
    ~$35 for the pipe and ~$5 ea. for the silicone bits. ~$50 all in, can’t beat that.
    boostedka[QUOTED] likes this.
  8. Jan 17, 2019 at 6:32 PM
    #148
    boostedka
    James
    NM
    It's definitely a lot cheaper than buying something aftermarket and gets rid of all the stock nonsense
