2.7 4 Banger Hesitation
Discussion in '1st Gen. Tacomas (1995-2004)' started by Layzboy, Mar 30, 2018.
  1. Mar 30, 2018 at 3:59 PM
    Layzboy
    Layzboy [OP] Well-Known Member
    Rob
    Glendale,AZ
    99 Rerunner TRD Off Road Sunfire Red Pearl
    Just gettin started
    Truck was off the Road for a While. Been Running Good after new Fuel Pump. After about 5k miles. Seems to happen more when its been driven for longer periods of time than Short little runs. I am Having a Lot Of Hesitation Issues. Replaced Plugs and Wires, and Fuel Pump. Run Some Fuel Injector Cleaner through as well. Fuel Filter was Next on my List. Any other Ideas or directions I should look at. Throttle position sensor?
  2. Mar 30, 2018 at 4:02 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    what brand fuel pump?
    Layzboy[OP] likes this.
  3. Mar 30, 2018 at 4:03 PM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    OEM Toyota.
  4. Mar 30, 2018 at 5:32 PM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Fuel Filter is 1 Job that just does Not look easy at all.
    96degreesindashayd likes this.
  5. Apr 2, 2018 at 8:46 PM
    Sreppep
    Sreppep Well-Known Member
    Philip
    Fort Worth, TX
    2001 SR5 4x4 V6 5spd 264k - 2005 T4R V8 4x4 139k
    5100/Toytec, F5s/w KO2 285s, ARB, 4x skids/sliders
    On my 97 4cyl I was having issues with it cutting out pretty bad to the point I thought it was going to die while driving, I replaced the throttle position sensor and It fixed it.
    I noticed the cutting out/loss of power around 50-65 mph.
    Layzboy[QUOTED][OP] likes this.
  6. Apr 3, 2018 at 6:58 PM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    I am Noticing after sittting in Rush Hour traffic it starts Acting up once traffic starts moving again. Hesitation gets Bad.
  7. Apr 4, 2018 at 6:22 PM
    Sreppep
    Philip
    Fort Worth, TX
    If you do the TPS sensor I believe it was a bitch getting out and I ended up breaking It while pulling it out but the new one went in easily.
    2 Phillips head screws hold it in place.
  8. Apr 5, 2018 at 1:50 PM
    Trapperpete52
    Trapperpete52 Well-Known Member
    Pete
    98 Tacoma 4 X 4 5 speed 93 Tacoma 4 X 4 5 speed 95 Tacoma 4 X 4 5 speed
    roll bar and lights
    Sreppep Just did mine and the bottom screw sucked. Bad thing is it tries to run wide open on start up. How do you reset that?
  9. Apr 5, 2018 at 2:28 PM
    Pervy
    Pervy Well-Known Member
    East Texas
    2.4 Tacoma, 3.4 4Runners
    Could you explain in more detail of how the truck hesitates when you drive it? For example like when you press the pedal down does it not feel like theres much acceleration overall at all rpms, or does it not have much acceleration until after a moment with pedal down then it kicks in. Also when was the last time your fuel filter was change and the mileage of your truck? More detail of the issue the better.
    Hard to diagnose the issue atm with the info given, but going by what you have said I kind of doubt it would be the fuel filter (at least not just the fuel filter alone).
  10. Apr 5, 2018 at 4:35 PM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Its Kind of Crazy. 166k And Fuel Filter has Never been Changed. When I Am around town driving or I’m driving on the freeway at freeway speeds it seems fine. Its When I have been in Stop and Go for a Good Half hour or so and traffic starts Moving freely is when the problems seem to start. As I Press the Gas it seems to get to a Certain point and the RPMs Start jumping and truck Starts hesitating and Bucking. At that point it hesitates on the Freeway and Side Streets as well. My Gas Gauge also dropped to almost empty and it went back up again. I get home and let it Chill for a while and its Fine again.
  11. Apr 5, 2018 at 5:37 PM
    Pervy
    East Texas
    Hmm, darn I see it seems more serious then I was imagining. It certainly lines up with a number of possible issues which include both the TPS and Fuel Filter and doesn't perfectly fit just one of them and the symptoms blend together.
    For disclosure I really am not to experienced with the TPS system, so take my advice with a grain of salt haha. But, what tips me off though is the fuel gauge jumping around makes me lean toward the fuel filter as the TPS alone shouldn't cause the fuel gauge to act up unlike the fuel filter which does do so (Please correct me if anyone else thinks/knows differently).
    Last thing I would want to do is to get you tossing money out for new parts willy nilly, so here is some advice to see if may be a clogged/dirty fuel filter. Haha this is just what I did to diagnose and isn't exactly the professional thing to do.
    What I did was loosen the left side of the fuel filter (left being the side of the fuel filter facing the front of the truck). You'll need two open wrenches to do so. When you loosen that side of the filter gas will come out of the fuel line that has already went through the filter itself - catch that fluid in a cup or a pan as best you can. If it is dirty, brown,or filled with foreign material then its a sure sign you have a dirty fuel filter. If the fuel comes out looking relatively clean then its not the fuel filter (at least) and you can tighten the nuts back up and diagnose elsewhere further. -- when you do run the engine again you'll have to hold the key on ignition to get lines filled with fuel again. Haha this is how I found my 136k Tacoma needed a new filter. Honestly not as difficult as it may seem changing it out with the right tools and right approach (I recommend going through the top of the engine in between the intake pipes for the left of the filter, and the wheel well for the right side). Be careful though as the fuel starts coming out of the line almost the instant the bolts are loosened. - Also do this on a cold engine.
  12. Apr 5, 2018 at 5:50 PM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Any Help is appreciated for sure.
  13. Apr 5, 2018 at 8:34 PM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Took a Different Route today other than Freeway Bumper To Bumper. Took side streets. Normal City driving and Not Sitting at Idle for 30+ Minutes to an Hour. No Hesitation Issues at all. Very Strange
  14. Apr 5, 2018 at 9:58 PM
    SOMDTACO
    SOMDTACO Well-Known Member
    Sean
    Southern Maryland
    96 Extended Cab 4x4 2.7 MT
    New Taco: 96 DLX Extended Cab 4x4 2.7,MT, Bilstein 5100s at 2.5 and HS 3 Leaf AAL Old Taco: 11 Prerunner Maxtrac Spindles in the front, 2'' AAL with Bilstein 5100 extended in the back. 18'' Milanni Stellars wrapped in 265/70/18 General Grabber tires.
    Is your engine coil over plugs or distributor?
  15. Apr 5, 2018 at 11:31 PM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Distributor. Plugs and Wires replaced with OEM Wires and OEM Denso Plugs properly Gapped.
  16. Apr 6, 2018 at 6:48 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Have you cleaned the MAF sensor lately. You could start getting misfires from that without getting any codes before it gets worse and does eventually throw one. If you do clean it make sure you do a reset on the ECU and let it adjust again.
  17. Apr 6, 2018 at 7:47 AM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Yes Sorry Cleaned MAF sensor also.
  18. Apr 7, 2018 at 10:11 AM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    New TPS will be here Monday. OEM Part. Any Tricks to that install.
  19. Apr 7, 2018 at 12:02 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Unplug, unscrew and remove. Reverse for install.
  20. Apr 7, 2018 at 1:03 PM
    SOMDTACO
    Sean
    Southern Maryland
