2.7 4 Banger Hesitation
Discussion in '1st Gen. Tacomas (1995-2004)' started by Layzboy, Mar 30, 2018.
  1. Oct 25, 2018 at 3:24 PM
    #141
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Let the engine idle. Remove the hose from the EGR valve diaphragm. Apply vacuum directly to the ERG valve with a hand vacuum pump. The engine should stumble and die. If it does then you know the passages aren't blocked too much and the EGR valve works.
    Layzboy[OP] likes this.
  2. Oct 25, 2018 at 3:24 PM
    #142
    Layzboy
    Layzboy [OP] Well-Known Member
    Rob
    Glendale,AZ
    99 Rerunner TRD Off Road Sunfire Red Pearl
    Just gettin started
    No Codes at all. Hesitation is Not Solved. But yet it Seems to be running Smoother overall. I will Check EGR Itself and EGR Temp sensor. This will get solved and everything I have replaced is for the Better. I want my Son to have something that Runs good for some time and not need to worry about it.
  3. Oct 25, 2018 at 3:25 PM
    #143
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Ok I will Do That as Well.
  4. Oct 25, 2018 at 3:27 PM
    #144
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
  5. Oct 26, 2018 at 12:15 AM
    #145
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    I'm out of town for the next month.
  6. Feb 20, 2019 at 7:53 PM
    #146
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    I Basically have to Shut it off at Stop Lights. If I do it will Run. If I let it Run at a Stop Light and acceleralte its Hesitates like Crazy. If I let it warm up in the Driveway it will heaitate when I pull away and accelerate. I am Not throwing and CEL's.
  7. Feb 22, 2019 at 3:15 PM
    #147
    SOMDTACO
    SOMDTACO Well-Known Member
    Sean
    Southern Maryland
    96 Extended Cab 4x4 2.7 MT
    New Taco: 96 DLX Extended Cab 4x4 2.7,MT, Bilstein 5100s at 2.5 and HS 3 Leaf AAL Old Taco: 11 Prerunner Maxtrac Spindles in the front, 2'' AAL with Bilstein 5100 extended in the back. 18'' Milanni Stellars wrapped in 265/70/18 General Grabber tires.
    Damn. What was the diagnoses on the EGR? I'd seriously consider just blocking it off completely for troubleshooting sake.
  8. Feb 22, 2019 at 3:17 PM
    #148
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    try using a different brand of gas or even premium or mid grade, I got a bad tank of gas at COSTCO last winter and my truck was running like sh*t
  9. Feb 22, 2019 at 4:36 PM
    #149
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    I have not had a Chance to check the EGR Valve. Outside Temps are Not a Factor as it will hesitate regardless. And on the freeway if I drive about 20 minutes at steady speed and I Try to accelerate many times it will hesitate so I have to make very Steady and Slow adjustments to my Gas Pedal. Then when I get off freeway and come to a Stop it will Hesitate as soon as I hit the gas. Shut it off for a Few and it will be Ok for a little while. And Then I Shut it down at all Stop lights after that.
  10. Feb 23, 2019 at 4:20 PM
    #150
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    I have changed fuel grades and different gas Stations. I still need to check temp sensor also
  11. Feb 28, 2019 at 8:26 PM
    #151
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    I am Going to try and test the EGR valve tomorrow.
  12. Mar 2, 2019 at 10:34 AM
    #152
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Tested EGR Valve 3 Times. Truck Died every time I applied Vacuum. Where to go Next?
  13. Mar 2, 2019 at 3:13 PM
    #153
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Possibly Idler Air Control Valve?
  14. Mar 2, 2019 at 9:19 PM
    #154
    bsb120
    bsb120 Well-Known Member
    Bradley
    Easley, South Carolina
    2016 DCLB TRD SPORT
    @Layzboy i was to lazy to read through all the pages lol. So maybe this has been addressed but worth a shot. Anyways i had a very bad hesitation when I stepped on the gas of my 2.7 and after many nights of troubleshooting turns out I had a bad plug wire. I’m not saying for sure that’s your problem, but when I changed my wires no more hesitation issue.
  15. Mar 3, 2019 at 7:34 AM
    #155
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Plugs, Wires and Ignition Coil packs were replaced a While back. Throttle position sensor, EGR Accuator, EGR VSV, vacuum lines as of late
  16. Mar 4, 2019 at 1:26 PM
    #156
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    What Else to look at? I am Going to check Temp Sensor by EGR. Possible Idler Air Control Valve as Well. I have not thrown any new CEL's.
    zztaco likes this.
  17. Mar 5, 2019 at 12:35 AM
    #157
    SOMDTACO
    Sean
    Southern Maryland
    i know I'm beating a dead horse, but I don't want you to miss something. When you checked the EGR you just put vacuum on it and confirmed the engine died. Did you do any other checks? Did you put some vacuum on it listen to it stutter and then see if it comes back? What I'm getting at is possibly the EGR when activated hangs open a little long, or has trouble seating back again. Or possibly is just getting activated too often. Just some thoughts. Fuel pumps new we know that, did you check the regulator? Have you done a fuel pressure test at all? Checked your engine ground?
    Really hoping its nothing like a cracked head or valve.
  18. Mar 5, 2019 at 12:48 AM
    #158
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Is it flooding itself? Or running lean What are your O2 sensors reading?
  19. Mar 6, 2019 at 10:50 AM
    #159
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    No I Have Not done any Fuel Pressure Check. Not Check engine Ground. No other EGR Checks. Im No Mechanic but try to do as much as I Can Myself.
  20. Mar 20, 2019 at 2:11 PM
    #160
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Any other thoughts before I Give up
