2.7 4 Banger Hesitation
Discussion in '1st Gen. Tacomas (1995-2004)' started by Layzboy, Mar 30, 2018.
  1. Apr 2, 2019 at 11:08 AM
    #161
    Layzboy
    Layzboy [OP] Well-Known Member
    Rob
    Glendale,AZ
    99 Rerunner TRD Off Road Sunfire Red Pearl
    Just gettin started
    What else should I look at Next
  2. Apr 3, 2019 at 4:08 AM
    #162
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    You said you haven't checked fuel pressure. Could be a bad FPR. Also check ALL of your vacuum lines make sure there is no leak. At idle pop the hood and get yourself a can or 2 of flammable brake cleaner. start spraying around intake manifold and all vacuum lines. Perhaps you have a vacuum leak that is apparent only after it warms up. If you spray around and engine revvs up you have a vacuum leak there. just an idea. strongly suggest checking your fuel pressure.
    SOMDTACO likes this.
  3. Apr 3, 2019 at 5:02 AM
    #163
    Markcal
    Markcal Well-Known Member
    I have not read through this whole thread but did read you used some fuel injection cleaner. Are you sure it's not dirty fuel injectors and would it be worth having them cleaned professionally? Are you using the original PCV? How does your air filter look? Rule out leaking head gasket? Positive no vacuum leaks? This could also be caused by a worn timing chain and camshaft lobes too.
  4. Apr 3, 2019 at 2:13 PM
    #164
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    I've heard of people having something along the lines of your hesitation problem on oldish vehicles be fixed with Techron complete fuel system cleaner. Sounds like your problem is a lot more serious, but after all you've bought and done, I think it's worth a shot to try out the fuel system cleaner that costs like 10 dollars at a local parts store.
    Additionally, make sure your coolant is not too old, your water pump is working fine, and that your engine is in good condition (spark plugs, valve clearances, good compression, no coolant leaks), and no emissions leaks from both the engine area and fuel tank area(recommend a smoke test).
    Also take a look at this video
  5. Apr 23, 2019 at 8:02 AM
    #165
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Truck is Going To a Mechanic this morning. Hopefully nothing major is wrong. I am Done.
  6. Apr 23, 2019 at 9:54 AM
    #166
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Mechanic is taking it for a Drive right Now. I am Hoping its Nothing to Major as I really want my Son to enjoy this Tacoma the way I have. Its been a Great truck. Got it with 27k in 2001. It now has 195k on the Clock.
    zztaco and Russianman92 like this.
  7. Apr 23, 2019 at 11:17 AM
    #167
    Russianman92
    Dunwoody GA
    Keep us posted
  8. Apr 23, 2019 at 4:34 PM
    #168
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    He says Fuel Pump...OEM Pump Shot in a Year WTF. Pressure out of Spec. 1st thing I put in. Only messes up when Hot I Don't get it. Not sure how long parts are Warrantied for but it was Brand new in the Box
  9. Apr 23, 2019 at 8:00 PM
    #169
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    1 year from purchase for oem
  10. Apr 23, 2019 at 8:01 PM
    #170
    Reh5108
    Idaho
    I'm assuming the filter has been replaced already?
  11. Apr 24, 2019 at 1:19 PM
    #171
    Russianman92
    Dunwoody GA
    Yup my aftermarket pump went out after 1 year as well. It happens. That's why I was saying you should check fuel pressure. Glad you got it sorted.
  12. Apr 24, 2019 at 2:12 PM
    #172
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    No I Had Not replaced Fuel Filter Yet. It was on my list for sure. I'm getting the new fuel pump and a fuel filter replacement at the same time this time around.
    zztaco and Reh5108 like this.
  13. Apr 24, 2019 at 3:35 PM
    #173
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  14. Apr 24, 2019 at 5:11 PM
    #174
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Yes it was OEM and Not Cheap.
  15. Apr 25, 2019 at 8:00 AM
    #175
    SOMDTACO
    SOMDTACO Well-Known Member
    Sean
    Southern Maryland
    96 Extended Cab 4x4 2.7 MT
    New Taco: 96 DLX Extended Cab 4x4 2.7,MT, Bilstein 5100s at 2.5 and HS 3 Leaf AAL Old Taco: 11 Prerunner Maxtrac Spindles in the front, 2'' AAL with Bilstein 5100 extended in the back. 18'' Milanni Stellars wrapped in 265/70/18 General Grabber tires.
    Really interested to see if this is the fix. When I had my hesitation issue, the fuel pump and filter were the first thing I changed out as I thought my pressure was low. It went up some but ultimately wasn't the problem.
    Layzboy[OP] likes this.
  16. Apr 27, 2019 at 5:37 PM
    #176
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    OEM Fuel Pump $338 through Camelback Toyota at a Discount. Rock Auto has a Denso Fuel Pump for $67. What am I Missing.
  17. Apr 28, 2019 at 10:48 AM
    #177
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Denso may not be the OEM supplier. Toyota has had many suppliers for different fuel parts.
  18. Apr 29, 2019 at 4:56 PM
    #178
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    I have seen Huge Price variations with these Fuel Pumps. OEM Failed on me within 4 Months. Would the Denso be a good option compared to OEM?
  19. Apr 30, 2019 at 9:34 AM
    #179
    SOMDTACO
    Sean
    Southern Maryland
    I've had the Denso one in my truck for over a year now. Works great. The fact that yours failed so prematurely may be a sign of something else though. Blockages (FPR) causing the pump to overwork or poor circuitry to the pump etc.
    zztaco likes this.
  20. May 2, 2019 at 10:30 AM
    #180
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    I may go for the Denso Unit.
