2.7 4cyl gear ratios
Discussion in '1st Gen. Tacomas (1995-2004)' started by smmarine, Nov 16, 2015.
  1. Nov 16, 2015 at 12:22 PM
    smmarine
    smmarine [OP] Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I'm looking at getting a 1999 4wd Tacoma and the new one says it has 4.10 gears. It's a 4cyl with an auto trans. My current Prerunner is a v6 auto, and it also says 4.10 gears. Isn't the 2.7 supposed to have 4.56 gears?
    Only reason I ask, is my Prerunner has Detroit Truetrac in the rear diff and if it's the same gear ratio I want to swap 3rd members before I sell the Prerunner.
  2. Nov 16, 2015 at 3:10 PM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    2.7 trucks came with all sorts of different gears depending on the options. My '96 4x4 was stock with 3.58 gears and 28 inch tires.
    Reading your gear code and deciphering it is a good way to start figuring it out.
  3. Nov 16, 2015 at 5:38 PM
    smmarine
    Melbourne FL
    The code says 4.10 gears, same as my prerunner. But I read in a couple forums where the door code isn't the most accurate system in the world.
  4. Nov 16, 2015 at 5:43 PM
    smmarine
    Melbourne FL
  5. Nov 17, 2015 at 5:04 PM
    MrRiverMan
    WNC
    You can always jack up the rear end, put it in neutral, then spin the drive shaft by hand and count how many times the wheels go round.
  6. Nov 17, 2015 at 6:03 PM
    Toyomonkey59
    Toyomonkey59 Well-Known Member
    James
    Hedgesville Wv
    2012 toyota tacoma Trd 4.0 4x4 Doublecab
    I have a 03 2.7 and I think mine are 4.30's with 265/75/16's. I think the gearing is low which would be typical for a 4 cylinder. I am also a manual. Im wanting to put 285/75/16's and was worried about gearing but I think it will work out considering how low my gearing is.
  7. Nov 18, 2015 at 3:29 AM
    smmarine
    Melbourne FL
    Do you have your door code handy?
  8. Nov 18, 2015 at 5:02 AM
    Toyomonkey59
    James
    Hedgesville Wv
  9. Nov 18, 2015 at 5:13 AM
    Clearwater Bill
    Billy
    Largo Florida
    http://www.how-to-build-hotrods.com/gear-ratio.html
    To the OP, a bit more detail. Don't blame you for not particularly trusting stickers.
    smmarine[OP] likes this.
  10. Nov 18, 2015 at 5:28 AM
    Toyomonkey59
    James
    Hedgesville Wv
  11. Nov 18, 2015 at 8:02 AM
    smmarine
    Melbourne FL
    Yep. My door code says 4.10, same as my Prerunner. I'll confirm it but it looks like it should just be a simple 3rd member swap to keep my Truetrac. That will be sweet
  12. Nov 18, 2015 at 8:46 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    OP,
    Strange, I also have a 1999 4wd with the 2.7 and I have the 4.56 gears. I thought they all did. Maybe the size of the tires determined the axle ratios at the factory. You should be good to go.
    When you pull the third from the pre-runner, the ratio should be stamped on the ring gear (or at least the teeth counts so you can do your own division).
  13. Nov 18, 2015 at 12:06 PM
    smmarine
    Melbourne FL
    It has small tires, like 225/75/15. I'm gonna swap it to 31s tho since I have new A/T's
  14. Nov 18, 2015 at 2:31 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    I think it was pretty common for the autos to have a lower ratio like yours to make up for the power the auto trannys use up, where as the manuals got the higer gearing.
    FWIW both mine are 4.10
  15. Nov 18, 2015 at 7:33 PM
    smmarine
    Melbourne FL
    I got the truck!
  16. Nov 19, 2015 at 6:56 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    My 99 2.7 TRD Prerunner came with 4.56 as well. It came stock with 31x10.50r15 tires.
    EDIT: My truck actually came with 4.30 gears, I was incorrect when I posted this 10 years ago.
  17. Nov 19, 2015 at 11:17 AM
    smmarine
    Melbourne FL
    Maybe it's 4.10 because it came with 225s. I put 31s on it and it doesn't seem much different. And the speedometer is dead on with the 31s
  18. Nov 19, 2015 at 12:21 PM
    bry838
    oregon
    Just check your door code and check out the sticky thread at the top to figure oot whatcha got...
    Edit*** oh i see what you meant..you knew it has 4.10's , you werent asking..haha sorry!
  19. Nov 19, 2015 at 6:17 PM
    MrRiverMan
    WNC
    Just because a set-up is stock, that doesn't mean that's what it rolled off the lot with. Dealers will do crazy things like swap tires from one truck to another to make a sale, so the "stock" for your truck might not be what the original purchaser got.
  20. Nov 19, 2015 at 6:40 PM
    smmarine
    Melbourne FL
    Yeah but the door sticker says it came with 225 from the factory. So maybe that's why it has 4.10 gears. If it came with 31s from the factory maybe it would have got 4.56
