2.7 4cyl gear ratios
Discussion in '1st Gen. Tacomas (1995-2004)' started by smmarine, Nov 16, 2015.
  1. Nov 20, 2015 at 7:01 AM
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Bought the truck in 99. Manual trans, 2.7, Bridgestone 225/75/15 Desert Duelers. 4.10 gears (confirmed).
  2. Nov 21, 2015 at 1:00 AM
    neegdogdig
    neegdogdig Untrained with bad experiences go go go!
    3rd Gen DC V6
    image.jpg :worthless:
    My sr5 2.7l 5speed came with 4.2
    My 02 sr5 2.7l 5speed 4x came with 4.20 gears now upgrade to 5.29:D
  3. Nov 21, 2015 at 4:56 AM
    smmarine
    smmarine [OP] Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
  4. Jan 20, 2019 at 2:11 PM
    cwells35
    cwells35 Active Member
    Colby
    Edneyville NC
    1998 Sunfire Red Tacoma 4x4 SR5 5 speed manual
    K&N Cold Air Intake Custom Grille Winch Halo Headlights
    How do you tell your gear ratio from the door code
  5. Jan 21, 2019 at 1:31 PM
    Superjunkman
    Superjunkman Active Member
    1998 Tacoma ext can 4x4, 5sp, 2.7
    None
    I have pretty much that exact same equipment on my truck (1998). I’m guessing it’s geared pretty high. When they’re geared way down you can usually start easily in 2nd on flat ground. Mine requires 1st. Where does one find the gear ratio? Is there a mark on the rear end?
  6. Jan 21, 2019 at 2:34 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    It's an old thread but the only tacomas I've seen with 4.56 stock are 4cyl auto.
  7. Jan 21, 2019 at 4:15 PM
    beez
    beez Well-Known Member
    Nate
    04 single cab PreRunner
    My 2004 single cab 2.7l auto has 4:30 gears.
  8. Jan 21, 2019 at 4:32 PM
    smmarine
    Melbourne FL
  9. Jan 21, 2019 at 7:26 PM
    Superjunkman
    None
    Thanks for all the advice. Looks like I’ve got 3.54 gears.
  10. Jan 29, 2025 at 7:24 PM
    Dustie89
    Dustie89 Member
    Duck
    2004 tacoma regular cab 2.7 liter 4wd automatic base model
    Leveling kit adjustable bilstein struts
    I got a 2004 toyota tacoma base model 2.7 liter automatic... does anyone know what the stock gears would be ?
  11. Jan 30, 2025 at 2:35 PM
    beez
    Nate
    Mine was 4.30. You can check the sticker in the drivers door frame, there is a code you can decode.
  12. Feb 12, 2025 at 3:03 PM
    Dustie89
    Dustie89 Member
    Duck
  13. Feb 12, 2025 at 3:12 PM
    Dustie89
    Dustie89 Member
    Duck
  14. Feb 12, 2025 at 3:17 PM
    Dustie89
    Dustie89 Member
    Duck
    Can you tell what it is cause idk what I'm looking for. I had know idea u could find what ur gear ratio was from that tag
  15. Feb 12, 2025 at 3:20 PM
    #35
    oldgreg
    oldgreg Well-Known Member
    Greg
    2001 2.7 reg cab 4x4
