2.7 5 speed tranny noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by 552Jrider, May 3, 2013.
  1. May 3, 2013 at 10:22 PM
    552Jrider
    552Jrider [OP] Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    I have a 2004 tacoma with a 2.7 5 speed. The truck started to make a weird noise so i took it to toyota after me coming to the conclusion that it was probably the release bearing. I took it to toyota they were going to replace the clutch and all the bearings for 1200 so i did the clutch myself. After completing the install of the new clutch and bearings (release bearing being pretty worn) the niose is still present. Any ideas on what the noise is or whats causing it? Im thinking a bearing in the tranny. I took a video of the noise but its crappy... iphone. Thanks for the help in advance.
    http://youtu.be/BHvMob5ja1k
  2. May 4, 2013 at 1:58 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That is either a bearing or a damaged gear. Does it do it in all gears?
  3. May 4, 2013 at 6:52 AM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    Yea all gears and neutral.
  4. May 4, 2013 at 7:42 AM
    blknblubkrdude
    blknblubkrdude Well-Known Member
    Gillette, WY
    96 Taco. 4X4, 5MT, 2.7
    Oil field truck with 250k miles...original powertain. Wheelers 881's/5-pack, Energy bushings throughout.
    The clutch release bearing will only make noise when your clutch pedal is pressed in... any noise with clutch engaged is transmission internals.... usually input shaft bearing. :-(
  5. May 4, 2013 at 7:54 AM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    Yea. Thats what i figured.
  6. May 5, 2013 at 9:42 PM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    any one know where i can get a rebuild kit and maybe some guidance on the rebuild if needed.
  7. May 6, 2013 at 6:13 AM
    Bmack04
    Bmack04 Active Member
    Ohio
    04 DC trd 4x4
    deck plate mod, grey wire mod, 5100s front w/OME 881s, 5100s rear w/wheelers 5 leaf, 265/75R16 Firestone Destination A/Ts
    did u change the pilot bearing? If the noise is present with clutch pedal pressed, it could be the cause.
  8. May 6, 2013 at 8:01 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
  9. May 6, 2013 at 8:10 AM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    I changed the pilot bearing and i lookedd marlin doesnt show a rebuild for the w59 tranny
  10. May 6, 2013 at 8:11 AM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
  11. May 7, 2013 at 8:41 AM
    tan4x4
    Rick
    Folsom, CA
    Hey, if you have the tools and ability to pull and re-build it, then that is certainly the best way to go. :cheers:
    Marlin does offer the W59 on their web-site.
  12. May 7, 2013 at 8:50 AM
    scottg918514
    scottg918514 Well-Known Member
    2013 DC, TRD 6-spd Manual, 4wd
    I was thinking pilot bearing
  13. May 7, 2013 at 9:41 AM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    They have the rebuilt tranny but they do not have a rebuild kit. I already dropped the tranny. Just need to get a kit and start the rebuild.
  14. May 7, 2013 at 10:00 AM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    I replaced the pilot bearing when i did The clutch
  15. May 29, 2013 at 7:38 PM
    450rider
    450rider Well-Known Member
    Oregon
    98 4x4 SR5 Maroon
    Leveling Kit, K&N Filter, Rockford Fosgate speakers, mono block amp, 4 channel amp, capacitor, sub and both amp kits and a Pioneer DVD player By-passed
    Have you fixed this yet? My truck is doing the same thing.
  16. May 29, 2013 at 7:45 PM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    I called marlin they have a kit but its just not on their site. So i got that kit i have the tranny appart and couldnt get any of the bearings off. Just got a puller to try this weekend. Still not sure whats making the noise everything looks fine in the tranny.
  17. May 29, 2013 at 7:52 PM
    450rider
    Oregon
    98 4x4 SR5 Maroon
    How much did the kit cost, if you don't mind me asking?
  18. May 29, 2013 at 7:56 PM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    I think it was 299 and with tax and shipping was like 340 ish.
  19. Jun 13, 2013 at 10:25 PM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    I finally got the tranny rebuilt at a local shop. Hoping to put it in tomorrow. I get the feeling its not going to solve my problem though. might have to replace the gears in the tranny. Anyone else have this issue with their w59 or is it just me?
  20. Jan 17, 2022 at 8:28 AM
    Ikeatlien
    Ikeatlien Active Member
    2003 tacoma regular cab 4x4
    Did you ever solve this issue?
