2.7 BASE AUTO TRAN QUESTION
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacotruck 2.7, Oct 17, 2016.
  1. Oct 17, 2016 at 10:38 AM
    tacotruck 2.7
    tacotruck 2.7 [OP] Well-Known Member
    Katy TX
    09 cab and a half 2.7
    09 2.7 base acces taco auto tran 139k question for the transmision savy ; I did a atf fluid filter change yesterday and overfilled a bit 3/16" past the hot full notch on the dipstick*** (@ 190°F and driven) Will it burn up or can I leave as is ? sidenote: then I read the note on the atf dipstick "under NORMAL driving conditions the transmision fluid need not be changed" or the like lol.
  2. Oct 17, 2016 at 11:11 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    The official (and technically correct) answer to your question: drain a bit of fluid and correct the fluid level.
    My answer: The system holds a lot of fluid, like 12 quarts or something like that. So 1/4" overfull is nothing. My 2006 2.7 automatic is currently about 1/2" above the full notch and it drives perfectly. Don't worry about it.
  3. Oct 17, 2016 at 1:06 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    when I drained my automatic I measured exactly 4 quarts taken out and that's what I put back in, dipstick reads on the money
