2.7 bogging, backfires and bad idle !!
Discussion in '1st Gen. Tacomas (1995-2004)' started by silvertoysurfer, Nov 1, 2015.
  1. Nov 1, 2015 at 1:13 PM
    silvertoysurfer
    silvertoysurfer [OP] Member
    Richard
    1997 2.7 Tacoma
    wheels & suspension
    Hi all.
    I have a 1997 model Taco with 2.7 3RZ-FE engine with automatic transmission.
    She is driving me to distraction though.
    Recently she has started running really badly. When setting off she will not pull away cleanly and instead bogs, coughs, backfires and nearly dies, then sets off like a rocket . If I have been using the engine for braking by downshifting descending hills she is even worse. Idling is awful starts off smooth but drops off and hunts and is like a roller coaster, the tacho needle jumping up and down. Compressions are all good, new plugs, new leads, rotor arm, dizzy cap cleaned idle control valve, all to no avail.
    Can anyone help ?
  2. Nov 1, 2015 at 1:14 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Maybe check fuel pressure and have the injectors professionally cleaned.
  3. Nov 1, 2015 at 1:19 PM
    silvertoysurfer
    Richard
    1997 2.7 Tacoma
    wheels & suspension
    Has anyone else had injector problems on the forum.
    Thanks for the tip Speedytech.
  4. Nov 1, 2015 at 1:21 PM
    Speedytech7
    I can say that I know of anyone with a 3rz that has had injectors probs, but some 5vz owners do. Simple maintenance always is a good place to start. Clean the throttle body, change PCV valve, check fuel pressure, make sure plugs are gapped properly.
  5. Nov 1, 2015 at 1:36 PM
    bsb120
    bsb120 Well-Known Member
    Bradley
    Easley, South Carolina
    2016 DCLB TRD SPORT
    I know it sounds stupid but I had really similar problem, change the plug wires
  6. Nov 1, 2015 at 1:48 PM
    mannyhernz
    mannyhernz Well-Known Member
    SoCal
    Im having a similar issue..but only after i wash it..weird
  7. Nov 1, 2015 at 2:33 PM
    KGN
    KGN Well-Known Member
    2011 Tacoma 2.7L
    Isn't that a symptom of bad plugwires? Does it do the same when it rains heavily? I had a VW golf that ran like shit when it rained, changed the wires and then no problem.
  8. Nov 1, 2015 at 2:36 PM
    mannyhernz
    SoCal
    Yea it gets the same way when it rains. Changed wires recently too because i read that too.
  9. Nov 1, 2015 at 11:51 PM
    silvertoysurfer
    Richard
    1997 2.7 Tacoma
    wheels & suspension
    Well guys I have replaced the leads with NGK leads and she was no better so I took a mortgage and bought some oe leads and it was still no better. Cleaned AFM, IAC, no difference !!!
  10. Nov 2, 2015 at 3:03 AM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    What about the distributor cap and rotor?
  11. Nov 2, 2015 at 3:35 AM
    silvertoysurfer
    Richard
    1997 2.7 Tacoma
    wheels & suspension
    Cap and rotor replaces with oe parts.....
  12. Nov 2, 2015 at 8:25 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Might be time to start checking sensors (CAM, crank, TPS, temp, etc).
  13. Nov 2, 2015 at 10:52 AM
    TJF
    TJF Well-Known Member
    NM
    01 xtra cab 2.7 4x4
    My 2001 was doing the same thing, Changed the coil packs and she runs like a champ now. Test your coil.
  14. Nov 2, 2015 at 12:06 PM
    silvertoysurfer
    Richard
    1997 2.7 Tacoma
    wheels & suspension
    My truck has a coil built into the distributor I think. Has anybody else had problems with the distributor ?
  15. Nov 2, 2015 at 9:03 PM
    RustyVT
    RustyVT Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    Sort of a long shot here, but are you on the original cats? I had a crown vic that did exactly what your truck is doing. Turned out to be a clogged cat on the right side bank. It idled okay for the most part but under light load it would want to stall out, and it had no power at all. Here's what mine sounded like, skip to 15 seconds in https://www.youtube.com/watch?v=a3lJQ71Nld4 Before I found out it was the cat I replaced everything ignition related on the car, and I do mean everything. Also had the fuel rail pressure tested, new fuel filter, all sensors except for the left bank o2 sensor and MAP sensor, egr valve, etc. Over 750 bucks in parts and the problem was solved with a sawzall...
  16. Nov 2, 2015 at 9:28 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    i had a similar issue with a dodge stratus. broke the cap and distributor during a tune up. ran like shit while I drove it to the mechanics. sounds a lot like your situation.
    you have to have a code or 2 with that kind of behavior. which ones?
  17. Nov 3, 2015 at 3:42 AM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    MAF sensor, plugs, wires are done, water in the fuel?, plugged cat, bad o2 sensor(s).....
  18. Nov 3, 2015 at 6:02 PM
    CodeSeven
    Serge.
    Coachella Valley
    nobody accidentally put diesel in there, right?
  19. Nov 4, 2015 at 12:29 PM
    silvertoysurfer
    Richard
    1997 2.7 Tacoma
    wheels & suspension
    Hi Guys, fuel is good, cat good plugs and leads etc good MAF clean, original O2 sensors though. That could be my next port of call. I have owned her for 16 years and this is the first trouble I have had.
  20. Nov 4, 2015 at 12:31 PM
    silvertoysurfer
    Richard
    1997 2.7 Tacoma
    wheels & suspension
    When on the freeway she will sit at 80 mph all day long !!!
