2.7 cat-back system for 2014 access cab?? Does it exist?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NotSoFastEddie, Mar 27, 2020.
  1. Mar 27, 2020 at 6:26 AM
    NotSoFastEddie
    NotSoFastEddie [OP] Member
    Ed
    2014 charcoal grey Tacoma Prerunner
    I've used the search function with no success. Besides the Magnaflow $650 Performance system, is there a more reasonable bolt on system for the 4-cylinder? I've checked Gibson, Dynomax, MBRP, and Magnaflow, with no luck; everything is for the 6 cylinder engines. I want a more aggressive sound, but no drone in the cabin. Am I just going to have to go to a muffler shop and have something fabricated, and hope for the best? Wouldn't have thought it would be this hard to find a system.... Any help would be appreciated!
  2. Mar 28, 2020 at 11:35 AM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    It's kind of strange that most of the exhaust systems are listed for the 4.0 V6 but if you go to Summit Racing and search and select the 2.7 4 cyl, a lot of the same systems come up as fitting. I think the muffler and tailpipe section would be the same for the V6 and 4 cyl systems, it looks like the intermediate pipe going from the cat-back to the muffler might be different. Some of the systems have the hangers welded to the intermediate pipe so if you picked a system and the I-pipe needed to be shortened, that might result in cutting off the hanger section. The Dynomax system looks like you could cut the I-pipe down to the length you need without messing up the hanger section that goes in front of the muffler. Someone here put the Dynomax 39447 on their 2.7 AC. It sounds like he had to elongate the flange holes but it bolted up https://www.tacomaworld.com/threads...access-cab-exhaust-help.330994/#post-14252455 and the rear tailpipe hanger needs to be rotated 90 degrees for the 2012-2015 trucks.
  3. Mar 28, 2020 at 5:20 PM
    Mongoose
    Mongoose Well-Known Member
    Catskill Mts. NY
    Yes, that Dynomax system will work on a 2.7 liter. I ordered one, but it kept being put on backorder, so I cancelled the order. Ended up buying this stainless steel system at a decent price off of eBay.
    https://www.ebay.com/itm/192292172715
    It's also made for the 4.0 liter, but it fits the 2.7 liter (no modding needed), with the flange being only a little different in size. Sounds quite nice too.
  4. Mar 28, 2020 at 6:03 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  5. Mar 28, 2020 at 6:43 PM
    NotSoFastEddie
    Ed
    thanks for the info. I wound up ordering a 14" Magnaflow and extension pipe, and am just going to have it welded in
  6. May 26, 2020 at 11:01 AM
    Gordon-Gekko
    Gordon-Gekko Member
    Fort Lauderdale, Florida
    08 2.7 PreRunner SR5
    Ivan Stewart Wheels, RollBak Tonneau, Hellwig Rear Sway Bar, URD Short Throw Shifter, LC Engineering Header, Fumoto F-103, WT SW Deflectors
    The " Stainless" AFE muffler I received with theAFE cat back kit started rusting one week after I installed it...! VERY poor quality and most likely manufactured in China...That is my bet! That AFE muffler is also an empty can that does not mitigate any sound on a 2.7 Tacoma. At full open throttle it puts out the worst blood curdling shriek I've ever heard!!
